Old 10-21-2009, 06:55 PM   #1
originalJD
James
originalJD's Avatar
Whats my gear ratio in this gm 12 bolt???
I bought this GM 12 bolt from a guy for 20 bucks. Couldnt pass it up cause the price. So I got it home, cracked open the case and counted the teeth. RING 43 AND PINION 13. My problem here is I can't find this count on the chart I use. So I thought maybe one of you guys could help me. Thanks. The chart I have is all I have. See below.
http://www.drivetrain.com/parts_cata...d_pinions.html
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 10-21-2009, 07:08 PM   #2
cableguy0
Re: Whats my gear ratio in this gm 12 bolt???
normally you just divide the ring gear teeth by the pinion teeth which in your case comes out to 3.30 but i have never ever hears of that ratio in a 12 bolt. a recount might be in order. also there should be a stamp on the edge of the ring gear that will say the tooth count. the most common gear would be 3.07 which comes to 40-13
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-21-2009, 07:11 PM   #3
originalJD
James
originalJD's Avatar
Thanks. I'm pretty sure I have the right count. But I'll check again. I looked for stamps but didnt have a whole lot of time. It started to rain.
Old 10-21-2009, 07:37 PM   #4
cableguy0
Is this a 12 bolt car rear? if it is it could have that gear from the factory i was thinking truck rears
Old 10-21-2009, 08:34 PM   #5
originalJD
James
originalJD's Avatar
Yes. I do beleive it is a car rear. It is has five lug axles too. Kinda the main reason I bought it. I have a 12 bolt in my 66 pu. But it is a 4.11 (I think) and 6 lug. So I may use the gears and axles in my truck
Old 10-21-2009, 08:37 PM   #6
cableguy0
The problem your going to have is car and truck lug patterns dont match. so if you upgrade to front disc brakes and 5 lug the wheels would have to be different front to rear. car is 5 on 4 3/4 and truck is 5 on 5. car and truck parts arent interchangable. the ring gear size is different as well as the axles.
Old 10-21-2009, 08:44 PM   #7
originalJD
James
originalJD's Avatar
I realize that the patterns are different. I have a set of front disk brakes for a camaro. And one day when I win the lotto or something, I can get me some drop spindles to hang them on. I'm just kind of gathering parts as I go. Who knows, I might get this thing done one day.
Old 10-22-2009, 07:38 PM   #8
LONGHAIR
i'm gfoing to go out on a limb and guess....
It is more likely that you mis-counted the pinion than the ring, so....
43 is correct along with a 14 tooth pinion, you get 3.07
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-22-2009, 11:00 PM   #9
Captainfab
60-66 Nut
Does the cover look exactly like the one under your '66 or is it a little different? If it is in fact a passenger 12 bolt, they were available with 3.31 gears. Otherwise you may have mis-counted
Old 10-22-2009, 11:51 PM   #10
Dooley
Dooley's Avatar
I had a 3.31 in a 1968 Camaro.
Dooley is offline   Reply With Quote
Old 10-23-2009, 06:49 AM   #11
dznucks
dznucks's Avatar
My 12 Bolt out of a '78 3/4 chevy truck had 3.42's.
dznucks is offline   Reply With Quote
Old 10-23-2009, 10:32 PM   #12
BarryB
BarryB's Avatar
Instead of counting teeth, does it not have the number stamped into the ring gear. That is where I look first, Spin the ring gear and look for the numbers, If it is 43 ring 13 pinion, it will have a number like 43:13 stamped on it. That will end all the cornfusion. find those numbers divide them, and that will be what your ratio is.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
