Old 11-01-2009, 12:14 AM   #1
Back in Black 66
Back in Black 66's Avatar
Question Lifting a 2wd
I have a 1974 long bed chevy c10 2wd. coil springs up front and leafs in the back. i am looking to lift the truck 2in and use 33/12.50R15's. i have been looking into lift spindles for the front and lift blocks in the back. is this a good route as far as parts and tires wear is considered and if so what places should i start looking for the spindles? please help!
Here she is hope it works
Back in Black 66 is offline   Reply With Quote
Old 11-01-2009, 12:23 AM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Lifting a 2wd
they dont make lift spindles for theses kinds of trucks anymore
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-01-2009, 12:31 AM   #3
Back in Black 66
Re: Lifting a 2wd
any other ideas. i dont really wanna do taller coils. cause i dont wanna deal with control arm length and never being able to align the truck and bad tire wear or would i not have troubles because of it only being 2in?
Old 11-01-2009, 11:47 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Lifting a 2wd
you can get a ball joint spacers and a 3" body lift
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-01-2009, 11:51 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Lifting a 2wd
i would do the body lift
Bob
1979 Chevrolet C20 LWB
1980 Chevrolet C10 SWB
1998 Chevrolet K2500 LWB
1971 Chevrolet Monte Carlo
1966 Ford Mustang
2018 Subaru Forrester (wifes ride)
2014 Ram Bighorn SLT 4X4 Longbed Diesel
1992 Ford Superduty flatbed tow truck
2004 Dodge reg cab swb 2wd
2014 Harley Davidson Heritage Softtail
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-02-2009, 01:00 AM   #6
Mike_D
Re: Lifting a 2wd
balljoint spacer and a 1" taller coil will allow you to run 33's.
Mike_D is offline   Reply With Quote
Old 11-05-2009, 12:29 AM   #7
Back in Black 66
Re: Lifting a 2wd
mike d
how reliable is a ball joint spacer and will it affect the alignment?
and
flamingbig 10
how difficult is a body lift compared to a suspension lift?
Old 11-05-2009, 01:56 PM   #8
Mike_D
Re: Lifting a 2wd
I don't have any alignment problems. Ill snap a picture this weekend. I know there is a moog spring that works great, I'll look for that part number as well
Old 11-05-2009, 02:59 PM   #9
Prerunner1982
Prerunner1982's Avatar
Re: Lifting a 2wd
I ran 1 ton coils on my 82 c10 and was able to fit 32"s with only slight rubbing. I did not need any lift on the rear as the truck sat level with the 1 ton springs. You could do the 1ton front coils and then a small (1") body lift. I do not like body lifts but a small one isn't too bad. I know my 32x11.50s almost hit the lower edges of the front fenders.. I had less than 2 fingers width at the closest point. The tires rubbed the inner fenders at the top.
Spindles are the best option but as previously mentioned not currently available for our trucks. I have heard and seen a couple people running the 88-98 front lift spindles but have not seen a write up on what particular parts are needed.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1987 GMC Sierra Classic 305/700r4.....RIP 01/11/2007
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
1997 Jeep XJ 4 door 2wd 4.0ltr/AW4 (auto)
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-05-2009, 04:36 PM   #10
JohnC
JohnC's Avatar
Re: Lifting a 2wd
When I bought my truck it had 3" lift coils with the ball joint spacer in it. Then it had the blocks in the back. It had 31x10.50's on it with plenty of room. I can't tell you how it was on tires, or alignment because I changed back to stock pretty soon after I got it.
JohnC is offline   Reply With Quote
Old 11-05-2009, 04:37 PM   #11
JohnC
JohnC's Avatar
Re: Lifting a 2wd
When I bought my truck it had 3" lift coils with the ball joint spacer in it. Then it had the blocks in the back. It had 31x10.50's on it with plenty of room. I can't tell you how it was on tires, or alignment because I changed back to stock pretty soon after I got it. Here is a pic of it.
Old 11-19-2009, 06:42 AM   #12
Back in Black 66
Re: Lifting a 2wd
prerunner 1982 - With the 1 ton coils did you need longer control arms or were you able to use the stock ones?
And does anyone have a pic of a ball joint spacer? i want to know how it works.
Thanks guys for all the assistance.
Old 11-19-2009, 09:40 AM   #13
Prerunner1982
Re: Lifting a 2wd
No I did not need longer control arms, I believe the same coils were available in diesel equipped trucks whether they were 1 ton or not. Since they were a stock option, no mods were needed.
Ball joint spacers: Though the pics below are for a Toyota the concept/design is still the same. It spaces the ball joint away from the upper control arm and helps reduce the angle the ball joint operates at. Also some of the aftermarket tubular control arms have the ball joint mounting area angled to help reduce the angle of the ball joint.
Jon
Oklahoma Roll Call
Old 11-19-2009, 07:10 PM   #14
sailed2japan
Jonny
sailed2japan's Avatar
Re: Lifting a 2wd
I am currently running 3" coils and ball joint spacers in mine. The spacers are no where near as thick as the ones shown above, only about 1/2" you also chage the mounting from above the control arm to below it. this set-up is designed to eliminate the exact problem you mentioned.
Edit: to clear up any possible misconceptions ball joint spacers do not provide any lift, they simply allow you to get a proper alignment with a huge shim stack and provide room for more droop as the lift coils change the position of the a-arms. I also plan to install a 1 1/2" thick droop stop istead of the stock 2 1/4" one to provide suspension travel closer to stock.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-19-2009, 07:27 PM   #15
sailed2japan
Jonny
Re: Lifting a 2wd
If you really want spindles:
Originally Posted by suicide 63
The recipe is
73-87
upper control arms any <c10-c20-c30>
lower control arms c20-c30
88-98
spindles for 1-1/4 inch rotors any exended cab will have them
rotors or a light dudy 3/4 ton they were six lug
upper and lower ball joints
outer tie rod ends
brake hoses
calipers
What makes this work is the 88 up ball joint presses into the 73 up 3/4 ton lower a-arm
Yuo will have to cut about a 1/4 inch off the new tie rod ends to get proper alignment.
Dont forget abought 88-91 square body stuff it all interchanges.
good luck
classic performance products has six lug rotors that go on 73-87 1 1/4 inch spindles about $120 for a pair.
Use this with a pair of lift spindles from Fabtech and 4" rear springs
-AEC Hundley USNR
Old 11-22-2009, 11:10 PM   #16
Back in Black 66
Re: Lifting a 2wd
holy cow had no idea it would b such a hassle. i never really like body lifts but it is looking like i might go that path. just seems easier. thanks for all the suggestions and ideas. hopefully soon i will get it lifted and i will post pics of what i came up with.
Old 11-24-2009, 03:15 AM   #17
longbedrick
longbedrick's Avatar
Re: Lifting a 2wd
ever see those "donk cars"? I always wondered how they lifted gramma's 4 door grocery getter to clear 30"rims. I saw a kit for $495 in one of the DONK magazines for a 3" kit for a c10. the kit had front spacer cups, ball joint spacers, rear blocks, hardware, and shock absorbers. or you could try some big block or 1-ton coils up front and blocks in the back.
longbedrick is offline   Reply With Quote
Old 11-24-2009, 10:48 AM   #18
Prerunner1982
Re: Lifting a 2wd
This combination would give it a raked look. 1ton coils alone would level out the truck.
However, what are you doing looking in a "Donk" mag long enough to find an ad for a c10 lift kit?
Jon
Oklahoma Roll Call
Old 11-24-2009, 09:33 PM   #19
longbedrick
Re: Lifting a 2wd
it was one of those things where you see the magazine cover at 7-11 and go "WTF?!" and pick it up. good marketing... sparked my interest for sure.
Old 11-24-2009, 11:38 PM   #20
3r!c84
Badass
3r!c84's Avatar
Re: Lifting a 2wd
yeah its hard to get passed the girls (well car) on the front of them mags
-00 Saturn 5spd
1/4:13:90
Old 11-25-2009, 12:03 AM   #21
longbedrick
Re: Lifting a 2wd
girls? they have girls in those mags? I musta' looked right passed them (my ole' lady's in the room)
Old 11-25-2009, 12:08 AM   #22
3r!c84
Badass
3r!c84's Avatar
Re: Lifting a 2wd
what magazines are you looking at then?
-00 Saturn 5spd
1/4:13:90
Old 11-26-2009, 05:47 PM   #23
Back in Black 66
Re: Lifting a 2wd
Think i am gonna do 1 ton coils and leafs. just seems easy.
Old 11-26-2009, 06:06 PM   #24
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Lifting a 2wd
On a C20, how much lift would I get with 1 ton coils up front? Or are the springs the same on a C20 and C30?
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 11-26-2009, 08:34 PM   #25
flamingbig10
6.0 powered square
Re: Lifting a 2wd
about a 1 1/2
Aaron
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
