Old 11-02-2009, 01:01 AM   #1
61superman
61superman's Avatar
1956 las vegas or bust build
Hello fellow junkies
this is a 1956 chevy 3100 build. I have had this truck a little over a year, i sold it in february then bought it back in march because i couldn't see it go. Then i got a wild hair up my arse and decided to build it for the Viva Las Vegas rockabilly show April 1-4 2010.
MY plans for the build are a traditional hot rod/ rat rod:
Front suspension
* CPP's 3 inch drop straight axle
* CPP's 3 inch drop mono leaf spring
Rear suspension
* CPP's 6 inch reverse drop mono leaf spring
Engine compartment
* Original 235 inline 6
* Offenhauser dual carb manifold
* Fenton cast iron dual exhaust headers
* Manual exhaust cut outs
Well here goes nothing
currently not letting me upload photos but soon to follow
sorry
61superman is offline   Reply With Quote
Old 11-02-2009, 10:46 AM   #2
Kim57
Kim57's Avatar
Re: 1956 las vegas or bust build
Sounds like a cool project.
We do need to see pics.
Kim
Kim57 is offline   Reply With Quote
Old 11-02-2009, 10:50 AM   #3
61superman
61superman's Avatar
here are some pics of the truck:
Old 11-02-2009, 11:52 AM   #4
rwolf9653
more ideas than money
rwolf9653's Avatar
Looks like it has good patina. Are you planning on paint or not?
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 11-02-2009, 04:04 PM   #5
61superman
61superman's Avatar
no paint thats how its going to stay as long as i own it
Old 11-02-2009, 05:14 PM   #6
blackdiesel
blackdiesel's Avatar
sounds like a whole lot of fun. should be a fast, easy, and "cheap" (if you consider this hobby "cheap") build. look forward to seeing this one
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 11-02-2009, 05:36 PM   #7
Kim57
Kim57's Avatar
Was it originally a military truck?
My 57 was a Navy truck and had a tag on the firewall.
Kim
Old 11-03-2009, 04:34 AM   #8
61superman
61superman's Avatar
yes it was an army vehicle.
My brother bought it from the old man that purchased it from the army in 1965. my brother has had it for 13 years and i aquired it last summer.
Old 11-03-2009, 11:57 AM   #9
sgtusmc
sgtusmc's Avatar
Very nice truck. Please keep the pics coming as you progress.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-03-2009, 08:09 PM   #10
61superman
61superman's Avatar
alright did some work here are some photos
Old 11-03-2009, 08:20 PM   #11
61superman
61superman's Avatar
When i was getting ready to put in the mono leaf I noticed that the driver's side rear bracket had 2 of the 4 factory rivets, so I air hammered them off and put it back with grade 8 bolts.
Passenger side front bushing the goes thru the frame only took 2 hours but man prevails once again
Now on to installing mono leafs
Old 11-03-2009, 08:24 PM   #12
61superman
61superman's Avatar
yesterday i received a package from old dominion trucking company all the way from michigan
i was so excited but diesel didn't care
these i think will look SICK !!!!!!
Old 11-03-2009, 08:31 PM   #13
61superman
61superman's Avatar
Today was a good and bad day. First the good
Starting the spindle and drop axle work, old king pins a breeze to remove. New king pins even easier so i installed them on the axle.
Old 11-03-2009, 08:54 PM   #14
61superman
61superman's Avatar
Now the BAD
after installing the axle on the truck i was looking over everything and noticed that the holes in the brass bushings no longer matched up with the grease fittings. After further investigation the bushing were spinning inside the spindle. NOOOOOOOOO!!!!!!!!!
well we all know what that means.... spindles are no longer good, i knew as much but i didn't want to accept the fact. but the show must go on and i finished installing the axle on the truck then called it a day, figured i needed to get on a computer and start looking for replacements.
I called every major player but to no avail then i remembered reading about a guy that converts straight axles to drop axles you might know him as www.droppedaxles.com or Nostalgia Sid's. I called him and he rebuilds worn spindles YAHOOOOO!!!!!!!!! we talked for a minute about how he goes about it and even told me how to do it but i thought this time around i would leave it to the professional and ordered me a set of rebuilt spindles.
now we play the waiting game
but there is still plenty to get done before they arrive
thanks Sid you rock
Old 11-03-2009, 09:01 PM   #15
mylow53
mylow53's Avatar
very nice work i like the old school approach to lowering. what's the plan for the bump stop? the original was very tall. i used a piece of conveyer belt rubber sandwiched between the ubolts. in an upside down u..
GT?
ps what's the dogs name
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 11-03-2009, 09:17 PM   #16
61superman
61superman's Avatar
thanks
the bump stops are on order thru napa went with 11/16 of an inch from energy suspension.
the brindle is Diesel and the apricot is Semilla (ce-me-ya) they are both English mastiffs thats just long for lap dog.
Old 11-03-2009, 09:28 PM   #17
terd ferguson
terd ferguson's Avatar
You, sir, go fast. I like the way you work. Can't wait to see it lowered with the new wheels and tires.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 11-03-2009, 09:53 PM   #18
bensimmons_05
bensimmons_05's Avatar
Sid is an awesome man. I love this build, can't wait to see more.
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 11-03-2009, 10:04 PM   #19
1956cameo
1956cameo's Avatar
This is going to be a very interesting build to watch! I can't wait to see more of it.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 11-04-2009, 08:41 AM   #20
samdjr74
Ok, I'm digging these wheels, care to share some info on them?
Thanks,
Sam
samdjr74 is offline   Reply With Quote
Old 11-04-2009, 08:49 AM   #21
twcarman
twcarman's Avatar
Nice work.
twcarman is offline   Reply With Quote
Old 11-04-2009, 03:12 PM   #22
mylow53
mylow53's Avatar
you must have a big lap if those are lap dogs!!!
keep the picts comming!!!
GT
Greg
Old 11-04-2009, 03:27 PM   #23
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
That's the way to do it. I wish I would have done that with mine. Oh well, live and learn.
From the looks of your thread so far your already half way done. You'll be driving that thing around even before '010 even gets here.
Keep those updates comin'!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 11-04-2009, 04:06 PM   #24
OrrieG
OrrieG's Avatar
Tell me about it. 10 years ago when I took my truck apart to start the build rat rods and patina were not a factor, everything was shiny. Looking at my before photos I could have just done the cab corners and lower hinge pockets, reprimered those parts and let the rest stay as is. I'm watching this progress too.
OrrieG is offline   Reply With Quote
Old 11-04-2009, 04:35 PM   #25
jchav62
1962 C-10
jchav62's Avatar
Nice build! I can't wait to see it all come together...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
2003 Silverado 2500HD LB7 Duramax
jchav62 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
