Jonny
Steel Bed Floor?
Has anyone ever put a truck together with a bed and used a steel floor? How did you or would you build the floor? I was thinking about doing this and using a 73-87 bed floor.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
Re: Steel Bed Floor?
Mine has a steel floor... but its not out of another truck... its just two sheets of steel.
1961 Apache SWB/SBW for now... Built 327 You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40. |
Senior Enthusiast
![]() Join Date: Feb 2007
I used diamond plate aluminum for mine, although there have been times I wished I'd used steel diamond plate instead just to increase the weight on the back half of the truck.
To build the floor I used a piece of 3/4" marine plywood the same width as the floor, then split it down the middle so I could slip it under the angle rails on the sides, leaving a joint down the middle. Before installation I coated the wood on all sides with fiberglass resin (no cloth just resin) to completely seal the wood. I then rested 48" wide diamond plate on top and bolted it in place. I didn't have any way to get it under the angle rails, so it's centered and just touching the edges of the rails. For 10 years I had a Gaylord bed cover installed so nobody could see it anyway. It's certainly not show worthy, but for a working truck it's easy and looks nice. The only pictures I have are very poor quality but show how it looks. ![]() ![]() I've crawled under and looked at it and other than having 10 years of road dirt on it, the wood looks good as new with no deterioration. |
![]() Join Date: Aug 2005
You can use the floor out of later trucks. I do remember that they can be used their is a little problem but they do work. I will try and remember
Jonny
I guess I should have mentioned that I'll be doing it in a lwb fleet side. That diamond plate bed looks awesome, but the reason I was thinking of doing a steel floor was to be able to have it rhino lined and use it for some light work duties.
60-66 Nut
![]() ![]() Join Date: Mar 2007
With some checking and measuring that I've done, the steel floors from the '67-'72's would be a nearly perfect fit into a '63-'66 bed. I have yet to do one but this is what I would suggest.
Someone put this in years ago (before i was even born):
![]() I'm getting ready to cut it out. I want to go to wood.
64 Stepside.. A work in progress.. ![]() |
#8 | |
there are some goofy things that go on when the 2 are put together but i did it with free parts that were in so so shape to start with. |
TX:
Here are a few photos of a '64 GMC lwb fleetside truck with a steel diamond plate bed, done by the previous owner. It is not show-quality, but super durable. I like your idea of a factory steel bed floor, as a donor. I think, if done correctly, would look nice. |
I used a 70 lwb fleetside bed floor in my 66 the only thing I found was a spacer about 3/4 inch is needed at the front panel/ or you could move the lip up to accomidate. I will try to post some pics tonight.
Yes pics would be good! This is what i've been wanting to do.
www.louisianaclassictruckclub.com 1964 c-10 short fleet 86 chevy c20 05 chevy trailblazer 02 gmc 2500 hd 4x4 duramax |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
put the wood in it! Rhyno line the sides, front and tailgate. then when you need to haul something, roll out your trusty bed mat. this is what I do, the bed mat doesnt stay in the bed, I like my wood and this has kept it nice for years.
Clyde65 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#13 |
If you're looking into spray in liners go with Line-X. It may cost a little more than Rhino, but I promise you it's worth it.
#14 |
![]() ![]() this one shows the body lines after the steel floor ![]() |
#15 |
From the pic the body lines look good, did you have to ajust the bed to get them right?
#16 |
That floor looks like it was made to go in there. I need to find one for mine.
#17 |
surprisingly no it lined up fine. I did however have to slightly drill out the holes in the frame. But that may be due to the hitch I welded in the frame.
#18 |
Cool! I've been looking for awhile but had no luck finding one, yet.
#19 |
I got mine off craigslist and then just hoped it was going to fit. I had a lead on a 73-87 bed but thought the 67-722 would line up better due to the frames being almost identical. .
#20 |
Jonny
Awesome info guys thanks for the input.
ob1monkey: Can yopu take some close ups of the spacer to show where and how itwas installed?
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 11-09-2009 at 03:49 PM. |
#21 |
Custom Builder
![]() Join Date: Jun 2003
I also have a 67-72 Long Fleet Floor that is going in my '66 Long Fleet Bed. I will take pictures when we are assembling it.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
#22 |
I did not install it, but if I remember correctly the PO said it was out a 73-87 truck, looks like it lined up perfectly. I would get better pics but my truck is back at the parents while I'm at school.
#23 |
I am interested in putting in a steel floor in my shortbed stepside.... figured I would have to get a bed floor and cut it down. Just found a listing on Craiglsist for a "70's 80's stepside bed for sale or trade" for $85. Is it possible to just switch the fenders and run that bed? (it will have metal floors, right?) I won't buy it just for the floor; poor college kid.
#24 | |
Yes... you can swap out the fenders but you also need to swap out the correct steps also as they match the fender style, No.... I think all step-sides in the era you mention had wood floors. My '65 had a '67-72 bed when I bought it and it had a wood floor. I put 58-66 fenders and steps on it. |
#25 |
It goes under the steel floor between the lip on the front panel and floor pics would be very dificult to see from underneth. it's to make up for were the wood should be.
Thread Tools | |
Display Modes | |
