11-08-2009, 10:57 PM | #1 |
Need some engine advice and suggestions...
I finally got my chassis and suspension squared away, now I need some suggestions/advice from all you motor gurus, . I'm trying to get my truck as streetable as possible (I drive it to work several times a week, ), yet still be very "salty" at the strip.
Here's a link to the chassis/interior updates: http://www.67-72chevytrucks.com/vboa...d.php?t=358692 First, let me say that I didn't build the motor or transmission. Here's a list of what I have done myself or have been able to determine that had been done by the previous owner. The motor was built by T&L Engine Development out of North Carolina (http://www.tandlengines.com/) and appears to be very well built. I have a lot of paperwork so I'll answer any questions the best I can. What I'm looking for are suggestions or recommendations about what has already been done or what should be done in the future to make this setup as efficient as it can be. Here's a list of what I know: Vortech V2 Supercharger (8" crank pulley) 50 mm Blow-off valve: http://www.vsracing.net/catalog/prod...43aaf05a7d8c53 383 stroker motor (1 piece rear main seal) All forged internals 9:1 Compression Carrillo forged crank and rods - http://www.carrilloind.com/LinkClick...vg%3d&tabid=60 SRP pistons - http://www.jepistons.com/Catalogs/SR...0-400_inv.aspx Dart Pro 1 Platinum 200 aluminum heads with roller rockers, chamber port volume 69, intake port volume 200, 2.02 intake, 1.6 exhaust, 3425 springs, PBM seals, CompCam pushrods in/exh 7809-16 http://www.dartheads.com/products/cy...num-heads.html PRW Stainless steel roller tip rockers (1.5 3/8) - http://www.performanceracingwarehous...cker-arms.html Competition cam - XR276HR-12 ----Operating Range:1800-5800 ----Duration Advertised:276° Intake/281° Exhaust ----Duration @ .050'':224° Intake/230° Exhaust ----Valve Lift:.503° Intake/.510° Exhaust ----Lobe Separation Angle:112° MSD 6BTM ignition box with adjustable boost retard and 6K rev limiter MSD billit mechanical distributor (blue/silver springs 36 degrees) 8MM wires Edelbrock Performer RPM HPC coated intake QFT 750 Ban Blow through carb Aeromotive boost adjusted FPR, http://www.aeromotiveinc.com/products.php?prod=20) Aeromotive A1000 fuel pump, http://www.aeromotiveinc.com/products.php?prod=165) 10 AN lines from tank to FPR, 8AN return, 8AN carb Custom aluminum tank with sump and return SS headers (1 3/4" primaries) 50 Series flowmasters, 2 1/2 exhaust Factory recommends Autolite AR3933, it seems to run better with NGK 45 spark plugs (.0045 gap, is this a good plug and is the gap good?) 180 Thermostat (to high or to low?) PVC valve installed Sid Neal TH350 SFI flexplate 2800 stall torque converter (to high/to low?) 31' rear tires, 4.11 Yukon gears with Eaton posi and moser axles They dyno sheet I got shows 631.1 TQ @ 4900 rpm and 622.7 HP @ 5400 rpm. The run was only to 5500 rpm. Supposedly it's built to go to 7500 RPM..... This is my first really high performance engine (and supercharger) and I want to make sure I don't break anything because something is incorrectly setup or something is missing. I'm open to any suggestions, recommendations, and/or changes to make this a strong running combination. Fire away at what you think is good, bad and ugly.........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-16-2011 at 10:02 PM. |
11-09-2009, 12:48 AM | #2 |
Re: Need some engine advice and suggestions...
I couldn't tell if you had an intercooler or not, but maybe you could look into spraying meth. I knew a guy with a whipple that would change the pulley at the track and spray the methanol to allow for the extra boost.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 11-09-2009 at 12:48 AM. |
11-09-2009, 08:28 PM | #3 |
The V2 is designed to not have an intercooler. Don't you have to have an all stainless fuel system to run methanol as well as a particular carb?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-20-2009 at 11:40 PM. |
11-09-2009, 08:49 PM | #4 |
Its a sweet ride Rob I wish I new more about that type of combo. I can't help much.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-09-2009, 10:42 PM | #5 |
If T&L built it with the forced air in mind then you dont need to do anything. I have heard nothing but good about them. If you have a question call them.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
11-09-2009, 10:58 PM | #6 | |
http://www.snowperformance.net/products.php?p_cat=319
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
11-09-2009, 11:08 PM | #7 |
I've tried calling them but all I get is a voice mail. I'm sure the motor is put together correctly, I guess I'm wondering about some of the stuff the PO did when they put the motor in the truck like spark plugs and gaps, no bypass valve, no thermostat, no boost regulated FPR, no PCV valve, stall, fuel pump size, gears, tire size.......I guess I'm just trying to figure out if there's anything that doesn't belong with this setup or anything that can make this setup more efficient.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-09-2009 at 11:10 PM. |
11-09-2009, 11:14 PM | #8 |
any videos of it running??
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
11-09-2009, 11:15 PM | #9 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-09-2009, 11:25 PM | #10 |
Pull the plugs and regap to recommended for forced ind. You have Dart heads so you will want to get the recommended spark plugs for those heads. You really should have a temp for the eng and a boost reg. For the Fuel pump, is it internal? look at it and pull some # if any are on it. A fast way to find out Gear ratio, but not exact, mark the drive shaft and tires (top or bottom) roll the truck fwd and count the 3 of rotations on each. This is lots easier then pulling off the cover.
11-10-2009, 12:34 AM | #11 |
motor exploder
I agree with the bypass valve (especially if you ever wind it to 7500rpm) and boost referencing the fuel pump. But since you have over 622hp by 5400rpm, no need to wind it that tight! As for the plugs, I'd call Vortec and Dart and see what they say about the gap. Seems like you have a stout ignition system, so I'm sure they will need to know exactly what you're running so they can recommend the right gap.
As for converter/gears, I'm guessing that 2800 stall is probably a little higher behind that 6xx ft-lb, and maybe a little over 3000-3200? For that 276 cam, that is probably about right and easier to deal with on the street than a 4000rpm stall, which would be a beast. I would leave that alone as long as you're happy with the launches. Again, with over 600ft-lbs 3.73's are fine in my opinion, since it's not a race only truck. I know you just put pipes on that badboy (I'm subscribed to your build thread), but maybe later a 3" exhaust is in order? That's a LOT of ponies huffing out those 2.5" pipes! Then again, you may not want to deal with the extra noise? What size are your header primaries?? They should probably be in the 1.75"-1.875" range with all that muscle. what headers was it dynoed with?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
11-18-2009, 12:11 AM | #12 | ||
R/
11-18-2009, 12:18 AM | #13 |
Sunburst C10!!!
Gage 1967 C10 Shortbed Stepside |
11-18-2009, 01:43 AM | #14 |
In regards to the fuel pump, I dont think you need a boost referenced fuel pump or regulator for that particular setup. Seems like I remember reading that somewhere, due to the fact that the whole carb is enclosed and under the same pressure(boost), so the fuel pump doesnt have to overcome the extra pressure differential. Setups with the blow-thru "hat" do need to be boost referenced.But DO NOT take my word for it. Call Vortech to verify. Just something to check out before you possibly waste and money. Hope this helps and im not way off base here.
11-18-2009, 01:45 AM | #15 |
Sweet truck BTW!!! What size tires you got on the back?
11-18-2009, 09:03 AM | #16 |
You don't need a PCV since this is a supercharger. You may need a vacuum system to keep pressure down in your crank case. Otherwise you could experience blow-by.
BOV, as stated in the FAQ section of the vortec website. "When should a standard air bypass valve be used? A standard air bypass valve should be used on all supercharged applications where the supercharger is making more than 6PSIG. The advantages of using an air bypass valve includes eliminating compressor surge (the noise heard during deceleration) for quieter supercharger operation, and reduced heat soak in the discharge tube and the supercharger." I would either move the air filter or block the header heat and run an air duct to it. Hot air isn't good for a SC setup, it only gets hotter. I see the fan mounted in front of you radiator. Is that a pusher or puller fan? Fuel Pump, as stated from the vortech website: "On early engines, a high-performance, boost referenced mechanical fuel pump will provide the necessary fuel in most applications. Late model motors may require an electrical fuel pump and a boost referenced fuel pressure regulator providing 6 lbs. of pressure." Again contact vortec. As far as gearing what is your tire size? I would run it first and see what rpm you are turning through the traps. That will tell you if you need a different gear. Don't just go adding things just because others have it. Check with the manufacture first, not that they always know best, but it's a good place to start. I don't want to discourage you or others from asking questions, but take a few minutes and do some research before asking questions when the answers are already available. The forums are great for information, but sometimes you may get the wrong information from someone that doesn't know what they are talking about and you could end up with something broken as a result of someone’s bad advice. The truck and the combo look awesome. I am sure you will enjoy it for a little while, at least until that guy on your shoulder tells you to throw on the smaller pulley. Good Luck
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
11-18-2009, 11:45 AM | #17 | ||
Working on it, .
29 x 15.5 Quote:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-18-2009 at 11:46 AM. |
11-18-2009, 01:37 PM | #18 |
Rob,
You will need a boost referenced pump. You need to have fuel pressure rise [from your base fp setting] 1 lb for each lb of boost. The box and a carb hat function the same way. They both pressurize the carb. The hat also pressurized the bowls through the vent tubes. The box just makes fuel leakage from the throttle shafts a non-issue. I do not believe that the black pump is capable of supplying enough fuel. If you run, say 8 psi boost, and a 7 psi, you'll need a pump that'll give you enough fuel flow at 15 psi fuel pressure. The pump will probably go 15 psi, but it will not flow well at that pressure. Most experts will say that a high pressure pump setup with a return style regulator is the best setup. Nice truck, btw. Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. |
11-18-2009, 01:39 PM | #19 |
If you are getting blow bye you need a vacuum pump to pull pressure from the crank case. There are a few ways to go about this. You can spend $500+ on a belt driven vacuum pump/system or you can try an electric vacuum pump similar to what the mustang cobras run or you can see if a simple PCV system will work (closed valve cover breathers with a hose connected to a oil seperator then connect that to a port on the intake hose before the SC).
I imagine vortec should have included a BOV (blow-off-valve) but it doesn't appear they do. I would recommend a 50mm X02 BOV, they are cheap and they work. This should keep you SC happy and your carb. When the throttle blades close the SC is still spinning and building boost, but the boost has no where to go so it will try and exit from somewhere by pushing passed your throttle blades or other parts of your carb, it will also build up back pressure on the SC. As far as a boost reference fuel pump or regulator it doesn't matter if it's a mustang or a chevy pickup. For every pound of boost you need more fuel. I would imagine you need a boost referenced pump or reg. Call vortec back and tell them you have a 351 cleveland in a 89 mustang with this SC setup and you want to know what fuel pump they recommend. Then just buy one that has similiar specs. Do you have an AFR guage? I highly recommend one. Yes I would install some type of "cold air" setup. If the engine runs cool and no over heating issues then I wouldn't change anything. Adding the thermostat was a good move, 180 is probably the best temp. 29" tall tire is a decent size tire and you may need 4.11, but I would drive the truck and run it at the track first before making any gear changes.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 11-18-2009 at 01:43 PM. |
11-18-2009, 01:43 PM | #20 |
From the Vortec site:
http://www.vortechsuperchargers.com/product.php?p=138 Read the "please note" section.
11-18-2009, 01:47 PM | #21 |
You "could" run a this pump, or a similar mechanical dead-headed [non return style system]. They offer a boost reference fitting option. Imo, this would be marginal, as you would be at the edge of the pump's pressure capacity at 7 psi fp and 7 psi boost.
http://www.robbmcperformance.com/pro...chevy1100.html Fwiw, I would buy more pump that you need, and do a return style system. A few seconds of detonation from running lean will destroy a supercharged engine quicker than it will a mild N/A'd deal. Dave
11-18-2009, 01:51 PM | #22 |
Here is a good site for blow-through info, both turbocharged and centrifigul super-charged.
Beware: Study and search, and study more before asking questions. I would start with the newbie forum. http://www.theturboforums.com/smf/index.php Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-18-2009 at 01:52 PM. |
11-18-2009, 03:36 PM | #23 | |||||
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-18-2009 at 04:07 PM. |
11-18-2009, 03:53 PM | #24 |
Aeromotive makes some good stuff.
The x02 BOV can be purchased from VSracing.net AFR: look at the Innovate LC1 w/digital gauge or the AEM model If you want to learn more theturboforums is a good rescource also checkout yellowbullet.com/forum
11-18-2009, 03:59 PM | #25 |
Sorry for the bad info.
