Old 11-12-2009, 10:06 PM   #1
rennat_2006
rennat_2006's Avatar
400 small block timing help
What do you guys recomend timing wise for a small block 400. It has a mild cam,headers,roller rockers, and a edelbrock intake. Book says 4* and thats what im at right now but another member said i should bump it up for performance. ive had it at 8* before and with my headers heating up the starter i had a bad hot start problem coupled with the timing. Ive wrapped the starter and ran bigger battery cables so i may not have that problem to the same degree now.
1977 Chevy K10
4" lift,Bald 37x12.50 Super Swamper TSL's, 400sb,Compcams camshaft,Compcam Roller rockers,Edelbrock performer intake,Edelbrock valve covers,Long tube headers,Dual 2.5" Summit Race mufflers,NP203 with part time kit with manual hubs, and a rust hole in the drivers floor!
rennat_2006 is offline   Reply With Quote
Old 11-12-2009, 11:28 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: 400 small block timing help
Check out the timing FAQ:
http://67-72chevytrucks.com/vboard/s...d.php?t=290498
83 GMC 406 700r4/3.73 posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly.
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 11-13-2009, 12:39 AM   #3
rennat_2006
Id rather not go into it that far yet with replacing parts in the distributor and stuff.
Just kinda looking to see what others with similar 400's are running theirs at.
1977 Chevy K10
Old 11-13-2009, 10:36 AM   #4
Ticker
If you don't want to change weights, then you can at least set the static timing correctly by the FAQ. You won't get the best power, but it should address your hot start issue.
Ticker is offline   Reply With Quote
Old 11-16-2009, 07:56 PM   #5
dallon
dallon's Avatar
well my 400 has nothing more than a larger carb and headers and a mechanic i work with said to bump it up to about 6 or 8 degrees (wherever it sounded like it was idling better) now this guy i would trust to do anything on any of my vehicles. but you dont know him so haha you can take my advice or leave it. just thought i would put it out there.
69 GMC 3/4 ton, 4x4, 400 SB, work in progress
dallon is offline   Reply With Quote
Old 11-16-2009, 11:24 PM   #6
rennat_2006
Im gonna bump it back up to 8* and see how it does starting when warm, If it has bad hot start again ill split the difference at 6*.
1977 Chevy K10
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
