Old 11-25-2009, 09:20 PM   #1
iluvmy72
Can I flip my transfer case?
I have a 1991 burb that I am working on...I put a 98 454 vortec in it and will be putting in a 97 4l80e tranny. I have been unsuccessful at finding a np 241c with a 32 spline for under 100 bucks. So I will use the one currently on the tranny which is electronic. Since it is a drivers side mount, can I flip it to make it work with the passenger side? I have to at least get this on the road for now and if I have to, just use 2wd. Can I do this? I know the speedo won't work.
iluvmy72 is offline   Reply With Quote
Old 11-25-2009, 10:03 PM   #2
msgross
msgross's Avatar
Re: Can I flip my transfer case?
running a transfer case upside down doesn't sound like a good idea to me. Why not just install it as normal and not hook up a front driveshaft?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-25-2009, 11:07 PM   #3
iluvmy72
hmm....mabee I will do that
Old 11-26-2009, 12:20 AM   #4
AJs72K5
AJs72K5's Avatar
No, you can't flip it over....at least not without a good bit of modification. In its stock form, the vent would be on the underside...and would drain all your fluid out. But, more importantly, the pickup for the pump would then be pointed to the top of the case and out of the fluid.
- AJ
Cruiser Crawler Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-26-2009, 08:51 AM   #5
b454rat
Why not get a dime-a-dozen driver drop 241 from a 1/2 ton, swap the input/output from the pass drop 241??
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
