Old 11-28-2009, 04:18 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My 63 farm truck build thread
I have posted some pictures here and there but I figured I'd go ahead and make a single thread detailing all of the work.
It's a super solid truck. I gave 500 for it and it has been well worth it. This truck needs zero rust repair. Not a rocker or a cab corner or anything. It had sat 20 years in a field nearby. My buddy owns a towing and impound yard and he bought it for scrap metal price. He knew my weakness for kneeknocker trucks so he came by my shop on the way to the scrap metal yard. As soon as I saw it, I bought it. It took 45 days for me to get it though because he had to impound it and go through the channels to get a title for me. Once that was done, he delivered it to me and I got to work.
Here we start at day 1:
I found grandpa's old vintage porn under the seat.
I bought an 84 Suburban front clip off of Craigslist for 100.
Rebuilt the whole thing. Everything stripped and powdercoated and rebuilt with all new Moog hard parts and Energy Suspension bushings. KYB front lowered shocks and Summit (Ground Force) lowering springs. I also installed a front sway bar with ECE lowered truck brackets and Energy Suspension greasable bushings.
more in next post...
Kevin -
My Instagram
Old 11-28-2009, 04:22 PM   #2
Tx Firefighter
Re: My 63 farm truck build thread
In the rear, I installed a 5 lug rearend from a Suburban They have the bigger brakes and 3.08 gears for good mileage. While doing this, I rebuilt the rear trailing arms with new Energy Suspension urethane bushings. Finish off with ECE 5 inch drop springs, shock extender brackets, KYB shocks and ECE super track bar. I just cut the old stuff out, it's faster.
Suspension all done and lowered, 5 lug front and rear..
Kevin -
My Instagram
Old 11-28-2009, 04:24 PM   #3
Bazooka
Keepin it old school
Bazooka's Avatar
This is a neat old truck. Lots of patina..
Bazooka is offline   Reply With Quote
Old 11-28-2009, 04:28 PM   #4
Tx Firefighter
I bought a used engine and trans from Scoti for a great price. He even strapped it to a pallet and loaded it with his fork lift for me.
Scoti is like a ninja, you're not going to get a picture of him.
I took the engine and spent a few days freshening it up. I cleaned it top to bottom and painted it grey. All new gaskets, distributor cap (HEI), wires, plugs, belt, rebuilt carburetor, air cleaner off a 327. I powdercoated the little nicknack brackets on the engine, pulleys, etc..
I did the Summit aluminum radiator that Chief Rocka detailed in his thread. I mounted mine a bit differently than he did and I spent some time coming up with nice fitting molded radiator hoses.
New battery tray and hold down, new battery and cables.
more...
Kevin -
My Instagram
Old 11-28-2009, 04:35 PM   #5
Tx Firefighter
The seat is some kind of 73-87 seat, I think Suburban middle seat. I lowered the brackets a bunch when I welded them together to set the seat as low as possible. I used an ebay saddle blanket cover.
In the interest of budget, I decided to restore the existing gas tank. So, I ordered a new sending units, insulating pads and gas cap. I spent some time cleaning the tank inside and out using my formula of acid to get the gunk dissolved.
I found some pin holes along the lower seam so I brazed them up.
Then powdercoated it...
I'm still waiting on my POR15 gas tank sealer. It will be here Monday. That will assure the tank is sealed inside and guard against little leaky areas. The stuff flat works !
I took an old heater and rebuilt it. New heater core, blower motor and resistor. I powdercoated everything in silver vein with clear.
more...
Kevin -
My Instagram
Old 11-28-2009, 04:40 PM   #6
Tx Firefighter
This morning, I removed the rally wheels and busted the tires off of them by hand. I'm sure most will poo poo on my choice of wheels but I like the classic look from the 70s and 80s. They are 15x8 on all 4 corners with 235/60/15 front and 275/60/15 rear tires.
I have new bed wood and strips on order from Mar-K (holiday special 10 percent off and free shipping). They should be here Tuesday or Wedensday.
Right now I am finishing up on building new front brake lines for the disc brakes. Monday I will seal the gas tank and get it in. Currently I m running it with a hose stuck into a gas can. Then come powdercoated grille and bumpers and it will be done. All I wanted was a solid beater. No plans for painting it or any restoration, just drive it a lot.
So far, I have been working on it 1 month and 8 days.
Kevin -
My Instagram
Old 11-28-2009, 04:47 PM   #7
lolife99
lolife99's Avatar
Subscribing.
My kind of truck build.
Took a while to load every picture with my dial-up,... but worth it.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 11-28-2009, 05:16 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Like the wheels, they really fit the character of the truck.
Old 11-28-2009, 05:23 PM   #9
62gmc910
62gmc910's Avatar
sweet truck, awsome baby moons, happy we're not the only ones running the original look
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 11-28-2009, 05:50 PM   #10
ratrod67
ratrod67's Avatar
PERFECT! Lots of work in a short time. Your a busy man.
ratrod67 is offline   Reply With Quote
Old 11-28-2009, 05:54 PM   #11
protrash64
Resistance is Futile
protrash64's Avatar
Nice work Tx. All of these threads keep pushing me to get one for a DD.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-28-2009, 05:59 PM   #12
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i didnt know there was a build for this
awesome truck
Gage
2003 Duramax Efi live, 4" straight
1999 Mustang GT Turbo 5.3/Glide Build
1996 RCSB Nitrous 5.3/T-56 Build
jgh64pkup is offline   Reply With Quote
Old 11-28-2009, 06:08 PM   #13
LILRED66
LILRED66's Avatar
I really like to original look with the upgraded suspension. I also like the stance and wheel/tire combination.
Great work and keep us posted.
LILRED66 is offline   Reply With Quote
Old 11-28-2009, 06:12 PM   #14
Rich 5150 69
Rich 5150 69's Avatar
Thats a lot of work for a month TX, great job for inspiring us, just one question, what oven you using for your powder coating, I havea friend that used a oven in his garage that someone had thrown to the trash from thier kitchen...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-28-2009, 06:19 PM   #15
joe231
joe231's Avatar
Cool!!
Looks super sweet!
But I still think you should have kept the rallies..
CHEVY ONLY
Old 11-28-2009, 07:00 PM   #16
62 short step
62 short step's Avatar
Very nice! Stance is perfect!
www.louisianaclassictruckclub.com
1964 c-10 short fleet
86 chevy c20
05 chevy trailblazer
02 gmc 2500 hd 4x4 duramax
62 short step is offline   Reply With Quote
Old 11-28-2009, 07:07 PM   #17
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man that is a cool truck, I really like it.
Friend of mine in highschool had one with a 327, man that truck was a screamer.
"He used to be a pretty nice feller, now he's a welder!"
My Build: 1980 GMC "Farm Truck From Hell"
MrBeast is offline   Reply With Quote
Old 11-28-2009, 07:12 PM   #18
Tx Firefighter
I have a big custom made oven for my powdercoating. It's 6 feet long so I can do bumpers, grilles, core supports, and most importantly antique motorcycle frames.
I've got a fresh 327 with Dart heads on my engine stand if I ever want to put it in. I doubt it though, I want fuel mileage for my daily drivers.
Kevin -
My Instagram
Old 11-28-2009, 07:21 PM   #19
Tx Firefighter
I appreciate the compliments from everyone. I figured since I didn't choose twenty something inch wheels and air bag suspension that no one would notice. When I was young, I was very, very poor. We went years without gas in our house, never a phone or even a working TV, all of that. When I was a teenager, I watched the better off kids fix up these old trucks for their first vehicle and always wished I could do that too. Now that I'm grown and past my hardships somewhat, I choose to build my trucks like I drooled over back then. In my time, you ran 15 inch wheels and fat tires.
Kevin -
My Instagram
Old 11-28-2009, 07:43 PM   #20
lolife99
lolife99's Avatar
Kevin,... everyone on here, (including myself) can learn from your build(s).
You Half-a$$ NOTHING.
Everything you touched on this truck was done with extreme detail and forethought. Not just a bunch of parts thrown together. And you use quality parts.
I am a fan of big wheels and air ride,... but your truck is what my '69 is modeled after. Cool stance. Dependable driver. Hot Rod truck.
The sheetmetal and patina on that truck is perfect.
COOL ride.
I'll be watching this one.
Keith
Old 11-28-2009, 07:49 PM   #21
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Yeah that 327 looks bad, bet it is gonna scream in what ever its in.
Old 11-28-2009, 10:00 PM   #22
northern 85
northern 85's Avatar
Nice Job, Love the stance!
northern 85 is offline   Reply With Quote
Old 11-28-2009, 10:32 PM   #23
spr85gmc
spr85gmc's Avatar
subscribed lovin it I need the inspiration and info to get crackin on my 66
spr85gmc is offline   Reply With Quote
Old 11-28-2009, 10:39 PM   #24
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
how much would it cost for me to get my heater powder coated like that
Gage
Old 11-28-2009, 10:49 PM   #25
SCOTI
SCOTI's Avatar
I've been waiting for this specific build thread. Any specific data on the engine paint? Looks similar to one of the OE colors available for V8's.
I also love the big wheels..... but I love 15's just as much when 'done right'. What I don't like is either choice w/non-optimal tire size and/or back-spacing. You did a nice job; the wheel tire combo compliment the stance well.
This is a 'farm truck' that the majority of people on this site wouldn't mind parking in their driveway.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
