Old 11-30-2009, 11:28 PM   #1
GMCMG
GMCMG's Avatar
Can I fit 8.875 12-bolt car ring/pinion in truck rear end?
Don't laugh if this is a stupid question, but will the ring/pinion gears from a GM 12-bolt 8.875" car rear end fit in a GM 12-bolt 8.875" truck rear end? I am trying to achieve good gas mileage, without swapping complete axle/leafs/etc.
GMCMG
1964 GMC 1/2 ton LWB project
- 1982 GMC 6.2 diesel engine/suspension donor
- 1966 Chevy 3/4 ton frame/doors/fenders donor
- tons of parts - cause you can't build a truck without 4 of everything!
2001 3/4HD Duramax Diesel extended cab lwb4x4
1984 Chevy C30 6.2 diesel lift truck (project)
1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!)
glascock.m@hotmail.com
GMCMG is offline   Reply With Quote
Old 11-30-2009, 11:31 PM   #2
bhoeger70
bhoeger70's Avatar
Re: Can I fit 8.875 12-bolt car ring/pinion in truck rear end?
No, the carrier is the same if I am right, BUT the pinion bearing is larger on the car 12 bolt. The truck pinion bearing is the same diameter as the 8.2" car 10 bolt.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 11-30-2009, 11:31 PM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Nope = pinion bearings and a few other key components are the wrong diam
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 11-30-2009, 11:45 PM   #4
GMCMG
GMCMG's Avatar
Any ideas how I get something around 2.41 gears in my 78 truck axle? Or am I just stuck finding a car axle to stick under it? (I'm going for mpgs here)
GMCMG
Old 12-01-2009, 12:51 AM   #5
Captainfab
60-66 Nut
A while back there was a guy on the Racing and high performance forum here that put a set of passenger 12 bolt gears in his truck 12 bolt. He said that he found the pinion bearing to make it work. I don't remember his user name, but you might try a search or a post over there.
Here I just found the thread.....
http://www.67-72chevytrucks.com/vboa...ight=car+gears
Captainfab is online now   Reply With Quote
Old 12-01-2009, 03:28 PM   #6
cableguy0
Believe it or not using a 2.4x gear doesnt automatically mean you will get better mpg. your really going to be lugging the engine around town just to get the truck moving with that gear. chances are on the highway your rpm will be out of the engines powerband causing it to lug and causing you to keep your foot in the throttl just to keep moving down the road. i'd hate to see you go through all the trouble of doing this to find out your mpg gets worse. what gears do you have now?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-01-2009, 09:13 PM   #7
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
I'm with Cableguy. I just swapped from a 2.73 and I -think- my mileage has gotten better because I'm in the cam's zone.
83 GMC 406 700r4/3.73 posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly.
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 12-01-2009, 09:56 PM   #8
GMCMG
GMCMG's Avatar
Cableguy0 / Philatruck,
I really don't have anything in it right now. This is a build, and I'm starting from scratch. The 6-lug 10-bolt that's under my frame is a 3.54, and I think the 5-lug 12-bolt in the donor truck is a 3.73 (haven't opened it yet). I've got a 2.73 ring/pinion that will fit the 10-bolt, but it doesn't do me much good since I'll be swapping out to the 12-bolt. I was hoping to pick up a set of car gears to go to 2.56 or 2.41, but I think you guys have talked some sense into me. I'm dropping a 6.2 diesel in the truck, and using a 5-speed OD tranny with a .73 final ratio. I was hoping that with the torque the diesel can put out, that I could run low rpms, but I may be shooting too low. After reading your responses, I ran some calculations based on larger tires and 2.73 gears (something a little more rational), and I think I'll be able to pull close to 65 or 70 at 1600-1700 rpms, which is really probably all the lower I should plan on running the engine. I think (?) I can get truck 2.73 gears for the 12-bolt, so I may start there. I'm doing a frame-off, so I really wanted to get everything right the first time, as I won't be able to try it out until it's pretty well done, and this is my first project. Thanks for the input!!! I have had a lot of help in a short time from members here on my various questions.
GMCMG
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
