#51 |
Re: LS1 into a 73 cheyenne
3r!c84
The little guy was $240 in the polish $200 for the natural finish |
#52 |
Re: LS1 Swap to a 73 cheyenne
#53 |
#54 |
gas tank
#55 |
I'm not a big fan of Airtex or Carter Fuel pumps. I would have grabbed a Delco. They just seem to out last the rest.
'83 swb 2wd '74 K5 Blazer '91 s10 swb 2wd '02 T/A 6 Spd. '63 Riviera 401 |
#56 |
You may already know but you need different clamps and high pressure hose between the pump and sender, The low pressure hose will blow or the plastic clamps will give, causing a major fuel leak inside the tank.
1985 Chevy C20 Suburban with a 2004 5.3/4L60E 2006 Chevy 2500HD Crew Cab 6.6 LBZ/Allison 1000 Last edited by clinebarger; 12-12-2009 at 05:45 PM. |
#57 |
Future: 86 on GenIV power!
![]() Join Date: Jun 2009
x2............change to high pressure hose and plastic to stainless clamps
#58 |
thanks for the input will upgrade the clamps
#59 |
new bumper
#60 |
nade shifter
#61 | |
Still Learning
![]() Join Date: Jul 2009
#62 |
looking good man! you arent messing around!
btw, what mount plates are you going with for the LSx?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list
#63 |
btw, what mount plates are you going with for the LSx?[/QUOTE]
the motor mount plates are from S&P, allows you to bolt LS-1 to original V-8 motor mounts |
#64 |
Still Learning
Looking Good!
#65 |
Boomer Sooner
Sweet!
#66 |
Keep it cool, so i got my electric fan today and I just finished mounting it. The fan is from Jegs its their dual 12'' S-blade reversible but im going to run it as a puller, sweet fan it eavan had a rubber type cushion. For the wiring i used the Perma Cool's adjustable prope type Kit. Dual fans require a 30 Amp relay sold separately, 160°F - 210°F "Vari-Cool" adjustable electronic fan control. To mount it i used Perma Cool's metal strap kit, had to bend to custom fit.
#67 |
more pics
#68 |
#69 |
nice....very nice
#71 |
right on man... the pics say a thousand words! good stuff!! thanks for the reply also
#72 |
I apologize for the deleted double posts, my thread got moved and caused double posts
#73 |
Very cool build i keep debating on putting the ls into my truck as well. I was at half off sale a few months ago and saw a ls motor out of a camaro getting wheeled up to the cash register. I was sick to my stomach.....if only i was there earlier.
#74 |
This is how it sits now, after the swap the front will rise about 2" +or- due to the lighter aluminum block. I will have to adjust the front suspension to have it sit like this again.
#75 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
