Old 12-15-2009, 11:16 PM   #1
amnima
1962 chevy 10 brake help.
I know it has been asked alot before but I can't find anything during search.
I have a 1962 10 chevy truck 2 wd. Completly restoring the truck and I am down to the brakes. I want to use the stock drum setup, but none of it is in good shape. Basically all i have good is the spindles. Where can you buy the whole brake setup, need brake booster everything... and is it worth it.
If the price is the same i guess i would upgrade to disc brakes. I get confused reading all the articles. Can anyone simplify all this for me. Thanks Guys --Jimmy--
amnima is offline   Reply With Quote
Old 12-15-2009, 11:32 PM   #2
DPowers
DPowers's Avatar
Re: 1962 chevy 10 brake help.
In the FAQ's section
http://67-72chevytrucks.com/vboard/s...d.php?t=209956
http://67-72chevytrucks.com/vboard/s...d.php?t=215980
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
http://67-72chevytrucks.com/vboard/s...d.php?t=163387
I just got done redoing the brakes all around on my '66. Got parts from NAPA and Advance Auto Parts. Am keeping the manual drum brakes for now, but will be switching to power drums in the future. Using a PB booster from a '72 and CaptainFab's bracket that he makes.
DPowers is offline   Reply With Quote
Old 12-16-2009, 12:48 AM   #3
62gmc910
62gmc910's Avatar
the wider drum brake parts from a '73-87 ish 4x4rear should fit, u need the whole assembly backing plate shoes drums etc but get an old backing plate from a wreckers or parts truck to make sure every thing clears first.
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-16-2009, 08:59 PM   #4
amnima
Thanks guys. IS there anywhere i can just buy all this stuff new... i have been trying to find old donor trucks but kinda hard to find around here and not alot of time to look. I would just assume buy it all new.
Old 12-16-2009, 10:10 PM   #5
amnima
Here is basically what I don't know.
On the front axel where the brake shoes are. The plunger/valve that pushes the shoes against the drum... Can you replace it? I have new drums and shoes.
On the Firewall where you fill up with brake fluid, i guess the resevoir. Mine is rusted way to bad and lines are gone. I don't know what i need there, i guess i need the whole thing? (its hard to explain when ya don't know what things are called lol).
How does the brake petal connect and apply pressure to the brakes??
Old 12-16-2009, 10:40 PM   #6
brawley
Easy Does It
brawley's Avatar
Try early classic enterprise, I bought brake kits from them in the past, they use good parts, and complete set-up conversions, they may be a bit pricer than others ,but use good products.
brawley is offline   Reply With Quote
Old 12-17-2009, 12:59 AM   #7
Captainfab
60-66 Nut
You should be able to get these parts from your local auto parts store. Depending on your area, you might have to go to Napa.
Those are called "wheel cylinders". I would suggest replacing the hoses while you're at it.
That is called the "master cylinder" The '60-'62's had a combination brake master cylinder and clutch master cylinder all in one unit. Since you're new to this you might consider investing in a repair manual for your truck. That will tell you a lot, plus have pics and illustrations.
Old 12-17-2009, 11:57 AM   #8
amnima
Thanks for the reply. I am learning this stuff, I know it is simple but i Have just never done it before. thanks again.
Old 12-17-2009, 07:49 PM   #9
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 1962 chevy 10 brake help.
The Self Adjusting brakes were a pain to me on my 62.
Never could get those jokers adjusted right.
Glad I swapped the front end out to a IFS.
Here you go Bud!
You can get them here:
TRUCK BRAKE OVERHAUL KITS
Each kit contains Everything you need
•4 Wheel Shoes and Linings
•3 Hydraulic Hoses
•Hardware (most models)
•4 Wheel Cylinder Kits
•1 Master Cylinder Kit
http://www.kanter.com/truck/trbok.html
Kanter Auto Products -
Classic Antique Auto Restoration Parts
76 Monroe Street
Boonton, NJ 07005
U.S.A.
1-800-526-1096
Replacement mechanical and interior parts for American cars 1920-1986.
Kanter Auto Products is a world-wide supplier of new mechanical auto parts for antique 1930 - 1990 American cars & trucks.
Their catalog is arranged as follows:
Accessories & Manuals
Brake System Parts
Carpets & Upholstery
Convertible Tops
Engine Kits & Parts
Fuel, Clutch & Exhaust
Shock Absorbers
Front End Kits & Suspension
Other Restoration Parts
Truck Parts
Packard Parts
A free catalog is available.
Hope this helps!
1Bad62Pro/Street
One Bad Mamma Jamma
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-17-2009, 08:40 PM   #10
62 mark
62 mark's Avatar
just get you a shop manual for your truck..these old trucks are strange to someone who hasn't worked on them much,but they built stuff back then so the average joe could work on 'em, not like cars today!
62 mark is offline   Reply With Quote
Old 12-17-2009, 10:08 PM   #11
amnima
Cool. Thanks guys I got all the parts ordered.
Only thing left is the Master Cylinder... Any special kind I need, it is an automatic truck. Any ebay cheaper one anyone has used?
Old 12-17-2009, 10:16 PM   #12
LILRED66
LILRED66's Avatar
Your FLAPS will have a single chamber master cylinder for your truck. Tell them what year and after they get up off the floor, they will check with the sage veteran behind the counter and he will know what you need.
LILRED66 is offline   Reply With Quote
Old 12-18-2009, 12:52 AM   #13
Captainfab
60-66 Nut
If your truck is an original auto truck, then just get an original master for a '62 with an auto trans. They are available, I've seen them listed. I believe it is the same master as for a '63 truck with manual or auto. If you need more help just holler.
Old 12-18-2009, 11:46 AM   #14
DPowers
DPowers's Avatar
You can also try Rockauto.com
http://www.rockauto.com/catalog/raframecatalog.php
My Advance Auto Parts will match their prices too. They just figure in the shipping- have saved alot of $$ that way on my '66.
Old 12-19-2009, 11:44 PM   #15
amnima
Thanks I got all the parts and installed the shoes and drums tnite.
How tight should the drum be on the pads? It has an adjuster don't want them to tight.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
