Old 12-17-2009, 05:56 PM   #1
Thealien
Thealien's Avatar
Old power steering hoses to the new LS Pumps
I had read mentioned that the fitting on the back of our pumps can be removed and screwed into the newer pumps on the LS engines.
This is a better and cheaper alternative to having new lines made, AN fittings etc.
Today while at the garage I swapped my old fitting into the newer pump. Just thought I would let some of you know that are doing these swaps and might not know this.
Old 12-17-2009, 06:19 PM   #2
faribran
Re: Old power steering hoses to the new LS Pumps
Thank you sir.... i am sure many will appreciate this...good tip
faribran is offline   Reply With Quote
Old 12-17-2009, 07:48 PM   #3
Thealien
Thealien's Avatar
I think there should be an LS FAQ with this kind of info in it?
Old 02-10-2010, 07:40 PM   #4
Hart_Rod
Hart_Rod's Avatar
I don't have an old pump to pull the fittings. Do you have a part number? Does anyone know what adapters are needed to install the LS hoses onto the factory gearbox? TIA.
Hart_Rod is offline   Reply With Quote
Old 02-10-2010, 08:04 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
This also works for the old 1972 pump when going to the newer metric pumps like the 90 91 pumps that fit the belt drive setups and hydraboost pumps.
dwcsr is offline   Reply With Quote
Old 02-10-2010, 09:05 PM   #6
mbgmike
You check with Mullins. They made adaptors
mbgmike is offline   Reply With Quote
Old 02-11-2010, 06:47 AM   #7
Larry S
Larry S's Avatar
I have a 96 5.7 vortec sitting in my frame, with the ps pump and hoses connected. I was wondering if there are fittings available to put in my steering box to make those hoses from the 5.7 hook up. Im not to that point yet, but I'll follow this thread.
Larry S is offline   Reply With Quote
Old 02-11-2010, 07:50 AM   #8
eagleuh1
eagleuh1's Avatar
Great info, I'm just a few days from getting to that point myself. Been slowed by the snow. Can't pull my 68 out of the way to get my 327 out of the garage to make room to pull the 68 into the garage to put 5.3 in. I'll probably try and find a trashed pump somewhere before I trash a good working assembly that I'll probably want to sell sometime down the road though. Keep the info flowing. What stage are you at in your build by the way?
http://i894.photobucket.com/albums/a...m/IMG_0501.jpg
eagleuh1 is offline   Reply With Quote
Old 02-14-2013, 12:52 PM   #9
solidaxel
solidaxel's Avatar
THANKS Thealien for all the GOOD info!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-08-2016, 12:36 PM   #10
Andy69Blazer
Found this adapter on ebay.... Think you can use it on pump or box to change to old school compression.
http://www.ebay.com/itm/161997290924
Andy69Blazer is offline   Reply With Quote
Old 04-08-2016, 01:47 PM   #11
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Old power steering hoses to the new LS Pumps
Here is a link from what I found back when I did mine.It shows pictures of the valve and what you have to do.
http://67-72chevytrucks.com/vboard/s...d.php?t=627585
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-08-2016, 03:55 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
I used those on the Yellow '70 when I put the later steering box on it and they worked great.....
LockDoc
Leon
Old 04-08-2016, 04:50 PM   #13
Andy69Blazer
Thanks for info^^ FYI: Back in the 70's the cars and trucks had a different orifice in the pumps. If you want easy steering you use one from a big car like a Cadi... If you want more firm steering the truck one's were smaller orifice and they are interchangeable even on old pumps from late 60's.
Old 04-20-2016, 02:07 PM   #14
Andy69Blazer
Found some info to share on 5.3 swap using TH400.... To hook up vacuum line to tranny modulator there is a factory vacuum port on the passenger side of the intake that is not used. You have to snap off the plastic plug and there is a hose barb fitting to hook your 1/4" vacuum hose!!!
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
