Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Truck Audio
Old 01-01-2010, 03:52 PM   #1
carter442
88 k2500 stereo wiring diagram needed
just as it says i am needing an 88 k2500 wiring diagram i just bought a stereo for my truck and will be wiring it into my stock harness but i do not have the diagram. so if somone has one i would greatly appreciate it. i believe my truck came with a factory cassette player cause i had one and it had its own harness im not sure if that will change it but im adding that.
carter442 is offline   Reply With Quote
Old 01-19-2010, 07:06 PM   #2
TheSunDanceKid
TheSunDanceKid's Avatar
Re: 88 k2500 stereo wiring diagram needed
these colors go for just about all chevys 86-2002
orange is radio 12v
black is ground
yellow is switched power(thicker gage wire as there are 2 yellow wires)
brown and gray not used CAP OFF WIRE
tan is positive front left speaker
gray is negative front left speaker
lite green is positive front right speaker
dark green is negative front right speaker
brown is positive Left Rear Speaker
yellow is negative Left Rear Speaker(will be the same gage wire as the rest of the speaker wires)
dark blue is positive Right Rear Speaker
lite blue is negative Right Rear Speaker
standard wire colors for MOST after market stereos
yellow is 12v constant
red is switched 12v
black is ground
blue is power antenna (only used if has motorized antenna)
blue/white stripe is remote on (for an aftermarket or factory amplifier)
orange positive dimmer (usally not hooked up cap off)
orange/black stripe negative dimmer (usally not hooked up cap off)
white is positive front left speaker
white/black stripe negative front left speaker
gray is positive front right speaker
gray/black stripe negative front right speaker
green positive rear left speaker
green/black stripe negative rear left speaker
purple positive rear right speaker
purple/black stripe negative rear right speaker
TheSunDanceKid is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
