Parking Brake for 1965 C10
Does anybody have a photo of the stock parking brake lever mechanism that was used on a '65 C10? I am refering to the mechanism that fastens to the cross member under the cab.
The figure in the maunals and the one in the LMC catalogue leaves me scratching my head. Pictures worth a thousand words.... Thanks |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Parking Brake for 1965 C10
Mine is now modified with a TH-350 , but I still have the old parts and can take a pic on the shop floor and you might get a rough Idea. You sent me a pic of your linkage a while back and it was close.
I went with a new crossmember for the automatic and it mounts a little foreward of the original mount for the three speed. I had to get creative and fabricate. As long as it pulls the E-brake cables evenly i think my adaptation will work.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Torn between 66 and 78
Just took my crossmember out. I will go snap a pic for you.
Is this what your looking for?
Another with a flash:
A better view..
Bob |
Exactly... thanks guys!
So the good folks at GM used the leverage applied by this mechanism to amplify the hand brake mechanism force. Looks like I have some fabricating to do. Could some body tell me the length of the lever arm from its pivot to where the rear brake cable attach, and from the pivot to where the hand brake cable attachs? Armed with this data I can fabricate a similar arrangment? Thanks again. |
I can give you my measurement using Bobs pic as a reference.
The bottom horizontal lever is 10" long. The Center pivot is at 5". On the right is another lever that attaches to the ebrake handle (you can see it in my pic, Bob's doesn't have it). That pivot for that is at 3/4". The middle vertical bar is 5 3/4" long. My first pivot moving towards the rear is at 1 1/4". The second pivot is at 1 3/4" from back end. The spring hole is at 1/2". The top horizontal bar is 5 1/2" long. The pivot is at center. The 2 rear cable holes are at 1" from ends. I hope that helps. Any clarification needed just LMK. Quick note. You can see it in Bob's pic, the vertical bar has holes through out the length of it. Last edited by CSoliz; 01-03-2010 at 09:53 PM. |
The picture by Big Fenders is what I had in my 64 with the 3-speed.I made a similar arrangement using the new crossmember. The swivel part is a must have to keep the pressure even on both brake drums.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 01-03-2010 at 10:12 PM. Reason: Additional post |
Great thanks for the dimensions and photos.
My remaining question: In the enlarged photo below the bottom 10" long lever, it pivots at the far right hand side, correct? Doesn't show up well in the pictures. Thanks again. |
Here you go John. Hope it helps some.
Big help, thanks CSoliz.
Well, that's a bit strange.. I wonder why they didn't simply put a pivot on the left side. In any event thanks for the detailed information. I will attempt to make something similar. Thanks again. |
#13 |
#14 |
But Found Her 25yrs Later!
Another pic, and a link to another thread of a fabbed version:
http://67-72chevytrucks.com/vboard/s...13#post5380713
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 Service truck build: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#15 |
The last post (before yours) was over three years ago and the OP is banned now, anyway...
#16 |
Thanks,
I know the OP. - Nice Guy. I was searching for info on this topic, found this thread to be a good compliment to the other. Threads may get old, but the content is still valuable. No reason to start a new thread, if an existing older one has applicable information. Posted via Mobile Device
#17 |
Yeah, I've seen him on another board I'm on, I was just curious as to why you posted the link to the other thread here when you weren't in it. Just seemed kinda odd to reply to a three year old thread with a link to one you weren't in. Noble cause, though, I get it.
Nice truck btw, I remember reading about you looking for it, I was probably more surprised than you were when you found it! |
#18 |
Thought I'd revive this rather than a new thread.
Has anybody interchanged the '66 intermediate cable with the 63-65 front and rear cables? Or do I need to buy all new 1966 cables front to back? Thanks, Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
#19 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Snowbound, I did just that and you will have to "rig" the cables. It would work for a little while but if it were me, I would just buy all og the proper 66 cables.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#20 |
Along with the cables don't forget there is a 1/4" support rod running forward at an angle to the RH frame where it begins to curve upwards at about the rear cab corner. There are also a couple of brackets that the cable to the brakes run through. The E brake forward cable attaches to one bracket from the left and the support rod attaches to the other from the right. Consider the cable to the brakes in a U and the E brake cable tugging from one side of the U and the rod from the other. Sure looks a lot simpler than the 65 set up but you would need the right parts.
#21 |
Didn't know there was an intermediate cable. Rear cable one piece attached at each brake and running forward in a U shape. Cable from E brake handle tying in to U cable. Or am I wrong? Will have to take another look out in the cold to confirm.
#22 |
I bought the '66 rear cables and they are definitely WAY shorter than the '65 rears. About 3 feet compared to 6 feet for the '65.
They are Raybestos parts and they had them on the shelf. Brian
#23 |
Yes, I forgot about the two short cables with outer jackets back at the backing plates. My other old car of different brand doesn't have those.
#24 |
I know its a factory safety brake,does anybody really use them?i have a 4 sp manual and planning on parking in gear.im just having trouble finding the parts i need.is anyone out there tried removing everithing completely?thx for your help
#25 |
It's not just a parking Brake, it's an Emergency Brake. If you're fluid brakes go out at 55 mph, you don't have to downshift yourself to a stop. You just pull the E-brake.
Do not leave home without it!
Thread Tools | |
Display Modes | |
