Old 01-06-2010, 01:50 PM   #1
keenan
keenan's Avatar
paint code??
does anyone know what color 4544AD paint code is?
my inside of my cab is red along with other give aways from where the orginal paint is comming through but i would just like to be positive. My glove box door is orginal
keenan is offline   Reply With Quote
Old 01-06-2010, 02:06 PM   #2
68 50th
68 50th's Avatar
Re: paint code??
Paint code 4544AD would be a two tone red and white.
Red 514 or 70704 and White 521 or 2185.
Here's where I got the answer: http://www.tcpglobal.com/autocolorli...truck-pg01.jpg
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4 DD
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
1987 Volvo FL 611 towtruck/carhauler
1955 Ferguson TEA-20 tractor
1984 Chris Craft Scorpion 210 Chevy SB engine
68 50th is offline   Reply With Quote
Old 01-07-2010, 02:49 PM   #3
keenan
keenan's Avatar
Re: paint code??
thanks man i figured so by the paint showing thru but thanks for the reassurance. i mite paint it tht same color but with metal flakes in it
Old 01-07-2010, 02:51 PM   #4
keenan
keenan's Avatar
Re: paint code??
how did u get those answers tho?
Old 01-07-2010, 04:27 PM   #5
68 50th
68 50th's Avatar
Re: paint code??
Edit
Mats..
Last edited by 68 50th; 01-07-2010 at 04:35 PM. Reason: Sent reply by mistake before it was finished.
Old 01-07-2010, 04:33 PM   #6
68 50th
68 50th's Avatar
Re: paint code??
Your paintcode reads 4544AD, sometimes it is typed like that and sometimes with only 3 digits.
If it is a 6 digit code like yours you should skip the first and last two digits to get the 3 digit code, 4544AD. Thats how I learned it from this board.
You will find the 544 code in the upper left corner of the text sheet UNDER RPO PAINT CODE.
544 is BASIC COLOR 70704 and BODY TWO-TONE COLOR 2185. On the paint chip sheet you will find those codes as red and white.
Mats..
Old 06-20-2010, 01:45 PM   #7
MikeB
MikeB's Avatar
Re: paint code??
I wonder if 70704 can be crossed to a Duplicolor number? Their chart has a section for "1998 & prior years", but it only lists 4-character codes.
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's http://67-72chevytrucks.com/vboard/s...d.php?t=775449
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 19 years! This is the very first car or truck forum I joined.
MikeB is offline   Reply With Quote
Old 11-22-2014, 10:36 AM   #8
Redline novdog
Redline novdog's Avatar
Re: paint code??
I subscribed, because my paint code is also 4544AD. I had a hard time finding it also. Then the text sheets are hard to read.Hopefully just getting old!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-22-2014, 11:09 AM   #9
71swb4x4
71swb4x4's Avatar
Re: paint code??
To clarify, your paint code is 544. The first digit, and last two digits are not part of your paint code.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-22-2014, 06:18 PM   #10
SS Tim
SS Tim's Avatar
Re: paint code??
67-68 paint code 544 trucks were actually 514 Medium Red body and 526 Off-White roof. The 521 bright White is only correct on the 69 up trucks as a two-tone contrast.
http://paintref.com/cgi-bin/chipcrea...GM&model=Chevy Truck
SS Tim is offline   Reply With Quote
Old 11-22-2014, 06:42 PM   #11
davepl
davepl's Avatar
Re: paint code??
Just FYI, the interior parts codes are not really accurate. They're close enough for a repair job, but as an example the console in mine was blue injection-molded plastic. It's kinda close to the dash color, but not that close. The color code IS the same as the dash. So when Pebble Beach calls, do a color match without relying on them.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-23-2014, 11:54 AM   #12
Redline novdog
Re: paint code??
Thanks all for clarifying. I was 99.9% sure the interior color is factory ( red ) I imagine it is the same color as the exteriorName:  HPIM1728.jpg
Size:  66.1 KB. Someone painted the exterior black, so I had no idea it came with a white roof! the front of cab and inside the fenders are also red.
Old 11-23-2014, 03:01 PM   #13
SS Tim
SS Tim's Avatar
Re: paint code??
Unfortunately more clarification is needed here because you have a 67.
Generally in 67 the interior metal was painted to match the trim (red, blue, green or the default fawn). In 68 it simply carried over the exterior color into the inside.
From the picture your truck certainly looks like a factory red interior to me! It should list red trim on the glove box SPID.
The factory exterior code is for a red and off-white conventional two-tone as I posted earlier. At this point you could go with a different or solid exterior color and still keep the red inside if desired. Among my favorites is off-white or white (solid) with a red interior.
Finally if you are doing a two-tone, 67 were generally a drip rail up and back paint vs the later pattern where the doors tops and pillars are off-white/white as well. There is a thread in FAQ with more. Even more if you do a site search.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
