Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1973 - 1987 Chevrolet & GMC Pickups Message Board > Projects and Builds
Old 04-20-2012, 09:54 AM   #101
JRANGER
JRANGER's Avatar
Re: 74 K/5 Screamin Green
looking good man
Gemini - 1978 GMC C15 High Sierra - 305 c/e
Floors -First Time Floor Panel Start
Build -http://67-72chevytrucks.com/vboard/s...d.php?t=505748
Electra - 1967 Mustang Coupe - 302/w 3 speed Build
JRANGER is offline   Reply With Quote
Old 04-21-2012, 12:06 PM   #102
glimmertwin01
glimmertwin01's Avatar
welded the front floor section and support in the K5, and started working on the rear support. I took the template from the drivers side i had ( thanks Russ) and cut another base plate. since some of the non flat stamping was still solid ( and was still there) i attached it to the new base. its pockey looking but its basically solid... slowly cutting out the rot or thin areas and replacing with solid material. then attaching it in its location on the truck to ensure good fit and function. the thing should be as strong if not stronger than the original since it will end up "boxed". It is a PITA but i want the K5 to be stiff and solid. after that gets re installed i will have to do the same with the Torque (rocker) box. i will be sure to save my templates for this when i go back to make the front section of the long missing drivers side rocker box.
first 3 pics my new floor the last 2 the rear support piece
67/68 K/20 "The BEAST"
73 K/5
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K30 CUCV M1008
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 04-26-2012, 05:07 PM   #103
glimmertwin01
I finished the rear Cab support reconstruction and got it covered generously with POR15
73 K/5
74 K/5
86 K30 CUCV M1008
Old 04-29-2012, 06:05 PM   #104
glimmertwin01
rebuilt the torque box today, had to go back to Fab Tech 201.. cut out the rot and patched also re constructed the missing area under the cab support...
(see pics 1,2&3) the last ones are the completed plate all POR15'ed
the final trick will be using the right box as a guide for the left one that is long gone...
73 K/5
74 K/5
86 K30 CUCV M1008
Old 04-29-2012, 06:47 PM   #105
Gordonr1973
Home Built '87
Gordonr1973's Avatar
You are a very good welder, looks great so far!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-29-2012, 09:19 PM   #106
glimmertwin01
thanks, i try, i feel im better with fabrication than the welding.... a truck like this is a challenge since much of the key structural components are not available... it fact there arent many full removable top 2nd gen K5's around
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-01-2012, 07:36 AM   #107
glimmertwin01
more progress.... test fitted the rear support and sectioned in the mid outer floor drop....
tomorrow test fit the newly reconstructed torque box...
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-01-2012, 08:51 PM   #108
glimmertwin01
removed the right door and installed a brand new rocker. then re installed the door to keep the weather out till i can get the "new" door prepped for install.
i still need to make a small patch for the rear floor by the "B" post. i think im am going to use a spare "drop in" style left front floor for the channel inside the rocker. kinda hate ruining a good patch panel but it has to be done. after the work it took on the drivers rear floor this should be a one piece deal
the last pic is of my inner fender. a little patch, welding and POR15 it should look like new
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-01-2012, 08:52 PM   #109
JRANGER
JRANGER's Avatar
looking good man
Old 05-01-2012, 09:24 PM   #110
Nothinghead
Nothinghead's Avatar
That is an amazing amount of work you have done so far, and it looks really good!
I have to ask though, what happened to the black tub you were going to put on 2 years ago? Did the deal fall through?
79 Blazer 350 TH350 part time 4wd
Nothinghead is offline   Reply With Quote
Old 05-01-2012, 09:56 PM   #111
glimmertwin01
no i built a different rig....
see this link
http://67-72chevytrucks.com/vboard/s...05#post4604005
i have to get the tranny worked on as it dropped 3rd n 4th gear but other than that it rocks.... im in between jobs so im gonna have to sell it
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-02-2012, 06:29 AM   #112
Nothinghead
Wow, 3 blazers?! I am jealous.
Too bad it has to go.
Old 05-02-2012, 09:49 AM   #113
glimmertwin01
i think im gonna be sellin the 73 and the 72
I picked up a 73 K2500 burb and a 74 K20 custom deluxe theres threads for them too
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-02-2012, 08:31 PM   #114
glimmertwin01
completed the floor today. the rear section is not available for my truck ( only the 78 up floor) so i took the channel area out of a drop in left side panel and measured cut, measured again bent. test fit trimmed etc..... i got it to fit decent and welded it in.... finishwd off the floor undeneath ( painting etc) sealing holes then PORed the patches and such..
I am DONE with the fabrication and reconstruction... ( besides some small patches to the wheel tub and the tub mount under the battery.)
here are some pics
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-02-2012, 08:33 PM   #115
glimmertwin01
now the finished product all painted
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-03-2012, 07:45 PM   #116
glimmertwin01
Torque box installed! the door shuts sweet.. the last major surgery is R N R the rear quarter.... and of course cut down the donor door.
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-06-2012, 06:19 PM   #117
glimmertwin01
I got bored Friday and thought id practice welding skills on the wheel tub. the area between the rot and the battery bolt area was paper thin so..here you go... LOL and a fresh coat of POR 15 its satin but is glossy when wet
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-06-2012, 06:24 PM   #118
glimmertwin01
cut and installed the new "used" pick up door.... the track on the tinted window was crap so i had to re install the clear window for now.... it fits and shuts like new.... i am amazed for a chineeze repop. nice gaps not sure if the come thru on the photos , I also removed the beat front bumper so i can clean up and paint the core support and hang the fender back on with no interference. I have a brand new GM front bumper for this truck....
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-06-2012, 06:28 PM   #119
glimmertwin01
I did some forensic investigation on the rear quarter. i chipped and scraped thru the top coat primer and bondo to get to the original color. and it was Green with NO white in the middle. OK on that note does anyone know the width of the spacing of the upper and lower trim? im looking for a measurement center of top band to center of bottom band. Thanks///
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-06-2012, 09:36 PM   #120
butch86
butch86's Avatar
man nice work that thing had some serious cancer and your doing a hellofa job with surgery. coming along nice
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-08-2012, 10:37 AM   #121
walkerb
walkerb's Avatar
Just found this. Looks good. I like that your goal is to have this thing looking as stock as possible!
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 k20 350 longbox soon to be a long stepside
2012 CUMMINS 2500 4x4
walkerb is offline   Reply With Quote
Old 05-08-2012, 08:18 PM   #122
glimmertwin01
that is correct.. I see you are close by, perhaps we can do some parts swaps ? im always looking for stuff...
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-10-2012, 06:01 AM   #123
walkerb
walkerb's Avatar
I work in Fairport so Im in the city everyday. Im up for parts swaping. I got a ton for pickups.
Old 05-11-2012, 09:42 AM   #124
glimmertwin01
sweet PM me a way to get in touch... I need some stuff for my 74 K20
73 K/5
74 K/5
86 K30 CUCV M1008
Old 05-11-2012, 09:49 AM   #125
walkerb
walkerb's Avatar
hahaha.... How do I pm? And yes Im serious.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
