Old 01-20-2010, 03:14 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
'72 Chevy SWB, Project Driver
I got this truck on Nov 13th and only now getting around to starting a build thread. The original plan for the truck was to get it running/driving and use it as my DD while I worked on it(using my motorcycle as a backup DD).
First thing was to get it started, Carb kit, file the points and a battery was all it took! Drove it on the trailer and got it home.
After It was home and cleaned out, I found the seat belts in never/hardly used condition still in the plastic wrap under the seat! A bit dirty but still great condition.
I also found a lot more rust.....Cab roof, bed floor, core support, doors you name it, it was bad. More about that later.
Since this is a driving project I needed someplace clean for gas. Blazer tank went in
You can see the tailgate I got from 1Sik52 in this pic
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-20-2010, 03:18 PM   #2
usmcchevy
usmcchevy's Avatar
Re: '72 Chevy SWB, Project Driver
Then it was time for brakes and a new windshield.............both turned out to be a huge deal for how simple they sound. First when I took the windshield out, half of the windshield frame came with it. I posted how to fix the windshield frame along with the drip rail rust. The general consensus was to get a new roof or a new cab
I was a little down about the windshield frame due to wanting this truck to be a driver, but continued work on the brakes. The front brakes were kind of working so I went after the rear with new wheel cylinders and rear end lines. Thank you whoever did this picture write-up! http://www.pbase.com/nufsed/drumbrake
After completing the install on the rear brakes, I drug my wife to the garage to help bleed the brakes. Still nothing to the rear.... fronts bleed good though. Next day i found all of the brake fluid in the cab from the "good" master cylinder the PO gave me. New master cylinder installed, still nothing to the rear, WTF. So I cracked a line on the frame, found fluid there, but not at the rear wheels. So I pulled the rear brake hose to find it plugged solid. New hose and all was well, better brakes than my 2000 Silverado!
Build thread
LSx Swap FAQ index
Old 01-20-2010, 03:20 PM   #3
usmcchevy
usmcchevy's Avatar
While I was looking for a roof or a cab, one found me Roland from here PM'ed me about a cab he had up by Jackson, MS. A couple weeks and a six hour round trip drive later and I had a new cab..........FREE, Roland is the MAN!!!!!!!!
Old cab going away.
I also wire wheeled the frame and painted under the cab, no pics
on its new home, by the way three guys is barely enough to lift and position a cab......my air cleaner didn't fare so well
Not to mention he also throw in two sets of seats and and a bunch of wiring! THANKS AGAIN Roland!
The cab was stripped of everything, scotch brite or wire wheeled.
Did some repair to the trans tunnel.
And started painting Flat black, Gonna be a rat rod until all work is done
Build thread
LSx Swap FAQ index
Old 01-20-2010, 03:23 PM   #4
usmcchevy
usmcchevy's Avatar
Then started putting back together. Which Is where I'm at now. Waiting on parts! They should be here thursday so I can get more done this weekend
Build thread
LSx Swap FAQ index
Old 01-20-2010, 03:38 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice progress, and props to Rowland for the offer.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-25-2010, 04:25 AM   #6
usmcchevy
usmcchevy's Avatar
Little bit of progress.
New poly cab mounts installed.
New master cylinder and clutch rod boots.
Finished wiring for the most part
Homemade dash pad that came with the cab and gauge cluster installed.
Seats are out of a Freightliner not installed yet, but I think they'll do pretty good. Need to find a center console though.
I go to look at a set of doors on Wednesday, hopefully they are better than what I've got. Ya know, by the time I get done there isnt going to be much of the original body on this truck...............oh well it sure is fun
Build thread
LSx Swap FAQ index
Old 01-31-2010, 08:54 PM   #7
usmcchevy
usmcchevy's Avatar
No real progress this week. I picked up a bunch of parts though. First was a set of 8x15 slots no pics though. Second came all of this.
Solid Passenger side door.
I also got the core support, but still need a hood and passenger side fender.
Build thread
LSx Swap FAQ index
Old 01-31-2010, 09:55 PM   #8
heidick70
heidick70's Avatar
where did u get that blazer tank from?
heidick70 is offline   Reply With Quote
Old 01-31-2010, 10:25 PM   #9
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Trucks looking good. Subscribed!
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 01-31-2010, 11:06 PM   #10
usmcchevy
usmcchevy's Avatar
The tank came from ebay, it was the cheapest I could find not to mention the free shipping.
http://cgi.ebay.com/ebaymotors/71-72...item5637d2d30e
Build thread
LSx Swap FAQ index
Old 01-31-2010, 11:13 PM   #11
mcbassin
Still Learning
mcbassin's Avatar
Looking Good! Now I see why you hacked up your old cab...that puppy had some cancer.Wow
mcbassin is offline   Reply With Quote
Old 01-31-2010, 11:54 PM   #12
70onB.A.D.'s
70onB.A.D.'s's Avatar
Good Job so far, Keep up the good work!! I believe I will have to subscribe!!
70onB.A.D.'s is offline   Reply With Quote
Old 02-01-2010, 12:22 AM   #13
nuke1
nuke1's Avatar
nice job so far, and a big congrats to the new cab. P.S. nice bikes, a 750 gixxer and a ........ I relate to those.
James
1968 GMC "HAVOC" .
Owner of :FULL THROTTLE CONCEPTS!!!
follow us on facebook, instagram, and youtube.
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
Wife's 72' Chevelle SS: http://67-72chevytrucks.com/vboard/s...=1#post5246230
A 58' chev build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-08-2010, 03:02 AM   #14
usmcchevy
usmcchevy's Avatar
Picked up 2 68 hoods the other day along with a radio delete and a cowl with no antenna hole. I also picked up all kinds of hardware from lowes and got the seats bolted in. Working on rebuilding the drivers side door hinges and repairing my 68 radiator support. Of course I'd have pictures, but thanks to my wonderful dog. I have no computer and can only jump on here quick from my wife's or work I'll get pics up as soon as possible.
Build thread
LSx Swap FAQ index
Old 02-08-2010, 12:54 PM   #15
fishingjred73
fishingjred73's Avatar
Ben here are a few pictures of the 69-72 radiator support patch from Brothers.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 04-05-2010, 12:45 AM   #16
usmcchevy
usmcchevy's Avatar
Long over due for an update, first thanks for the pics fishingjred73.
Next is what I've accomplished over the past almost two months.
I decided to rebuild my core support and skip the brothers patch panel. Turned out ok in my opinion and its now 1/8" metal so it should take a little while to rust out again.
You can also see I cleaned and painted the front frame rails while I was there. I'll do the frame around the engine when I pull the motor to replace it and the front suspension when I rebuild that.
I also gave the old doors a coat of flat black and stuck them on.
Other than that I've just been collecting parts and planning
Build thread
LSx Swap FAQ index
Old 04-05-2010, 07:25 AM   #17
fishingjred73
Lookin good Ben!
James
Member of
Old 04-05-2010, 08:07 AM   #18
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-05-2010, 08:18 AM   #19
lks dcvn
lks dcvn's Avatar
Looks pretty good to me also! I bet you saved a ton of time/money/cursing swapping cabs over than doing the body work on the other one -
lks dcvn is offline   Reply With Quote
Old 04-05-2010, 02:55 PM   #20
Hart_Rod
Hart_Rod's Avatar
Looks great! Will it be ready by Cruizin the Coast?
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 04-05-2010, 04:10 PM   #21
big_al_71
big_al_71's Avatar
you are doing a great job, keep the picts coming....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-05-2010, 07:52 PM   #22
usmcchevy
usmcchevy's Avatar
Define "ready" Done....NO WAY. All rust fixed, probably not. Running and driving, yes
Build thread
LSx Swap FAQ index
Old 04-05-2010, 10:09 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-18-2010, 12:57 PM   #24
usmcchevy
usmcchevy's Avatar
Small update, got the drivers side fender mounted and the door weather strip installed.
And I just placed a $600 order with Mikes Bump and Grind so there should be some pretty good progress in the next few weeks.
Build thread
LSx Swap FAQ index
Old 04-18-2010, 01:09 PM   #25
gcburdic
Restoration Virgin!
gcburdic's Avatar
subscribed!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban
Current Resto: 1966 Mustang-Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
