Old 02-02-2010, 09:30 PM   #1
BlueJeep
BlueJeep's Avatar
My version of the s10 swap
I've posted bits and pieces of my swap here and there, but I'll put it all together here in one place now. Over the past 6-ish months, I've been working on swapping my 49 Chevy 1 ton onto an s10 frame.
It started out with a really clean (for Iowa) 1949 Chevy 3800 I bought from a farmer who had used it to haul produce to the farmer's market. It hadn't been run in about 5 or so years, and the block was said to be cracked in the original 216. The truck had a stake bed put on it when it was brand new and the tailgate removed....and stored. What I ended up with was a near perfect 9 foot bed that is perfectly straight, and an absolutely perfect tailgate that had been stored in a barn for 60 years!!
Here's what I hauled home:
And here's the donor, a 1995 s10 that was purchased to donate a front clip, and after doing so has sat behind a barn for the last 5 years. 207,000 miles on the TBI 4.3, 4L60, and it ran great! This would provide the chassis, engine, transmission, and any other part I could salvage off it and use on the 49.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-02-2010, 09:31 PM   #2
BlueJeep
BlueJeep's Avatar
Re: My version of the s10 swap
I'll leave out the boring details of parting out the s10 and pulling the body off the 49.
I wanted to use bushings to mount the body, but didn't want to pony up for the s10 poly body mount bushings, so I ordered some Energy suspension poly bushings for a Jeep CJ-5. 2" in diameter, 7/8" thick with a 1/2" hole...perfect. I then used pretty much the same procedure as everyone else to determine cab placement. My cab is 3.5" off the frame, and level with the flat portion of the frame under the cab. I built my mounts out of some 3x5 3/16" wall rectangular tubing I had left over from another project. Since the body bushings were shorter than the "hat channel" for the rear cab mounts, I made some simple 1/2" spacers out of a chunk of steel so the channel wouldn't rub on my mounts.
Moving the cab:
Sitting on the frame:
Up till now, that's pretty much the same as most have done.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-02-2010, 09:31 PM   #3
BlueJeep
BlueJeep's Avatar
Now here's where mine is different than the rest I've seen. I wanted this to be a little different than most, so I chose to leave the extended cab wheelbase alone. What this would give me is a box that is longer than a shortbed, but slightly shorter than a 3/4 ton bed, and way shorter than my original 9 foot bed. I purchased some junk short bedsides off craigslist for mockup, and some OK 3/4 ton bedsides to use once I figured out how long I wanted it. Since I'm very particular about how the wheels sit in the wheelwells and since I had complete control of where this was...might as well get it exactly where I wanted it.
Here's figuring that out:
I wanted the longer bed because I plan to use the truck for my all purpose hauling, summertime truck duties, etc. I also wanted a steel bed floor. I had planned to use an 88-98 floor, when I saw a guy use an s10 floor on another forum. This was perfect, it allowed me to re-use more of the s10 and the bed mounts were already there for this!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-02-2010, 09:32 PM   #4
BlueJeep
BlueJeep's Avatar
Next up, moving the engine back. Again, since I have control over where everything ends up, I wanted to make this right too. I determined that it needed to go back 7", to maximize my radiator clearance and still leave adequate distributor clearance (I decided I didn't need 8+" of distributor clearance).
Engine in stock location:
And my new frame mounts to use the OEM s10 rubber mounts:
Getting there:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-02-2010, 09:33 PM   #5
BlueJeep
BlueJeep's Avatar
Back to the bed, I determined that for my setup, I needed to cut 2.375" from the front of the 3600 bed to fit the wheelbase of the extended cab s10...so I did. Also cut down the running boards to fit. Now with the running board bolted to the rear fender, and the rear fender bolted to the bedside on jackstands, I could determine where to place the bedside:
By this time, I'd decided that I'd like the ability to haul plywood, etc. so I would need to get rid of my mini-tubs:
From this:
To this with parts from another s10 bed:
http://67-72chevytrucks.com/vboard/s...d.php?t=384736
And now without my mini-tubs, I needed 1" spacers to get more clearance for my 4wd s10 rear axle:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-02-2010, 09:33 PM   #6
BlueJeep
BlueJeep's Avatar
Next up, pedals and booster. Here's where I found that the 94 up s10's aren't as good of a parts donor. The pedal hangar was integrated into the firewall, whereas the older s10's had a pedal hangar that could be unbolted. I had a buddy who parted out an s10 earlier in the year, so I got some parts from him. Used the pedal and booster from an '89, and it worked slick. Also used an older steering column, as it fit the look better than the '95's big plastic one.
and Photobucket is giving me trouble with the big images, so more tomorrow!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-02-2010, 09:39 PM   #7
chevy49
chevy49's Avatar
no pix
chevy49 is offline   Reply With Quote
Old 02-02-2010, 09:50 PM   #8
sgtusmc
sgtusmc's Avatar
more 6
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 02-02-2010, 10:03 PM   #9
BlueJeep
BlueJeep's Avatar
Originally Posted by sgtusmc View Post
more 6
I saved myself some room at the top for....oh yeah....more pics!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-03-2010, 06:26 AM   #10
nuke1
nuke1's Avatar
That is awesome, i like the way your doin it, great job so far!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-03-2010, 08:31 AM   #11
63 & 64 Bowties
and a few others
Great job. Thanks for sharing.
So, with the cab 3.5" off the frame, how much ground clearance are you ending up with for the front fender apron and the running boards?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-03-2010, 08:42 AM   #12
BlueJeep
BlueJeep's Avatar
Quite a bit...but the tires on it right now are 235/75R15's, which are 28" tall. I'm probably going to swap the front ones out for some 215's, which should drop it an inch. The truck is in storage right now because we've moved; this weekend I plan to bring it home so I can resume working on it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-03-2010, 11:18 AM   #13
bjcaldwe
bjcaldwe's Avatar
Great progress BlueJeep.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 02-03-2010, 11:34 AM   #14
MrTucker
MrTucker's Avatar
Great write up! Having a long bed myself, and considering an S10 swap, it's nice to see how you cut down the bed to fit the extended cab frame, rather than hack the frame to fit the bed. Nice work.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 02-03-2010, 06:14 PM   #15
53GMC
53GMC's Avatar
Great Write up bluejeep!! did you delete ABS or did you not have it to begin with? I would love to delete my ABS but just not sure what steps or rewiring it would take...any advice would be great! and subscribed!!
53GMC is offline   Reply With Quote
Old 02-03-2010, 08:48 PM   #16
BlueJeep
BlueJeep's Avatar
Yep, deleted ABS. Took that big box that sat on the inner fender loose and threw it away, removed all the wiring to the wheel sensors up front, and stripped the wiring harness from inside the cab...pics of that will come later.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-03-2010, 09:04 PM   #17
53GMC
53GMC's Avatar
ok...thank you Blue Jeep...I would love to cut out all the ABS but am not sure what brake lines connect where and what to delete from the harness....im inexperienced with brakes so any and all help will be great help to me...and i tend to do better with LOTS OF PICTURES!! since im a visual kinda learner anyway! thanks again for your post...it helps rookies like me out a ton
Old 02-03-2010, 09:06 PM   #18
BlueJeep
BlueJeep's Avatar
Bear claw latch install. OK, my goal for this one is to have doors that easily open and close, and are safe. I'll be hauling around my kids in this truck and my wife says she'll be driving this to the gym on weekends, so I want the doors to stay shut around all corners. I like my stock turn-down exterior handles, so I plan to keep them and make it work. The only part I'm not quite sure yet is how to lock them. I got the bear claw kit from Autoloc (off Amazon.com) that has the locking feature, which I may or may not use. I don't want power windows, but I kinda would like remote unlocking to make daily driving a little nicer. Any input from others who might have already figured this out is welcomed.
Here's the start:
Since the small style bearclaw won't fit between the window track and the "bumpout" on the door, I decided to make the "bumpout" bigger. I cut about 1/4" inside the outline of it, made relief cuts in the corners, and folded it out with a crescent wrench. Then, I made a block-off plate to fit the new opening and with some trimming, welded it in:
Very crude paint job in photobucket to show cuts I made:
As you'll see, I didn't buy the install kit for the latches. I just couldn't see spending the same amount I did on the latches on a bent piece of 18ga. and a caged nut.... Posterboard from Dollar General worked great to figure out what I needed:
With the jamb side, I only got to start in on before we moved and put the truck in storage, so that will progress in the coming weeks. I cut all the spot welds and removed the structure I wouldn't need. I'm going to end up re-working this whole area, to make it conform to the new latches. I no longer need the deep recess that the stock latch used:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-03-2010, 10:50 PM   #19
BlueJeep
BlueJeep's Avatar
Now to wiring. Since I haven't had the truck at the new place to work on, I grabbed my box of wiring to work on. I stripped every single wire out of the s10, so that I could re-use as much as I wanted. I'm going to use all the s10 headlight and taillight circuits, as well as the majority of the underdash and underhood wiring. I've stripped out stuff I didn't want like airbag, ABS, and daytime running lights. This s10 didn't have many options, so that did make it a little cleaner with no power windows, locks, or A/C wires to delete. My future plans include Vintage air, so I looked up the install instructions on their website to see what I would need to keep, and got rid of the rest of the wires from the heater circuit too. When I'm done, it should be pretty clean and fairly basic, and since it's all factory s10 wiring future diagnosis should be pretty easy too. On to the pictures.
Here's the harness from inside the cab, mostly stripped down:
The garbage can of "removed" wires:
airbag wires are easy to spot, they're wrapped in yellow tape:
And lasty, the fuse panel from the s10. If anyone has a 95ish s10, I'm trying to chase down what the circled items in red are for. A fuse fits in them, so I'm assuming they're circuits that weren't used in my s10, but I'm not entirely sure...and I no longer have that little plastic cover with the labels for all the fuses....
This brings me about current. As I get more done, I'll add more to this thread. My plan is to get it running and driving soon after the snow melts. I will have it driveable and John Deere blitz black by the 4th of July, where I plan to take it to Goodguys in Des Moines!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-03-2010, 11:29 PM   #20
53GMC
53GMC's Avatar
i have the fuse panel cover at home and i will be back there on Friday...i noticed those two in my panel earlier (i have a 96) when i was checking all of the fuses out....i can post what they are on mine once i see what they are if that will help you....i love the bear claw installation! wanna do the same on mine one day when i get closer to finished...keep the pictures comin!
Old 02-07-2010, 12:50 PM   #21
49ZR2
49ZR2's Avatar
Bluejeep
Great to see you finally started your build thread. Your build is coming along great! Keep posting those pics.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=372267
49 4x4 build
51 Willys frame off beer getter.
49ZR2 is offline   Reply With Quote
Old 02-09-2010, 06:00 PM   #22
xJoey Dubsx
xJoey Dubsx's Avatar
cant wait to see more!
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
Old 02-09-2010, 06:17 PM   #23
Deenice21
Deenice21's Avatar
Looking Good!!!
1971 LWB C10 - 5.3/350
1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet
1964 malibu ss - ls1/4l60
http://67-72chevytrucks.com/vboard/s...d.php?t=382403
Deenice21 is offline   Reply With Quote
Old 04-14-2010, 08:25 PM   #24
53GMC
53GMC's Avatar
any more work done with the bear claw latches or anything? Want to see more!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
Old 04-15-2010, 10:08 AM   #25
BlueJeep
BlueJeep's Avatar
Yes, I have been making a little more progress. I'll get some pics this weekend but most of what I've been working on is the radiator support and mounting. I took a pretty different approach than any of the others I've seen, and like how it's turned out. Now that it's almost done, I can focus on some of the other things necessary to get it driveable. Taking the driveshaft in to get shortened next week.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Thread Tools
Display Modes
