Old 02-09-2010, 08:43 PM   #1
tmarkjr
dana 44-5F closed knuckle front end
Anyone know where to get replacement parts for this diff. Looking for knuckle seals, gaskets etc. Thanks
tmarkjr is offline   Reply With Quote
Old 02-09-2010, 09:01 PM   #2
70BLAZERX2
Re: dana 44-5F closed knuckle front end
If you do have the closed knuckle front 44 you are better off ordering the front knuckle seals for a 1968 1970 jeep wagoneer...gladiator...ect i got mine from jc whitney..for my 69 K/20 front c/k 44 and these are the same parts...fit perfect
70BLAZERX2 is offline   Reply With Quote
Old 02-09-2010, 09:06 PM   #3
tmarkjr
Thanks, I'll check them out.
Old 02-09-2010, 09:09 PM   #4
70BLAZERX2
I know its wierd, but this way you can get them...and they were not that much anyway...it is still a dana44 no matter what it was in,unless a ford front then its reverse rotation high pinion.
Old 02-09-2010, 10:07 PM   #5
tmarkjr
Found them thanks again. Anything else on the knuckle I should get. I never took one apart, I only worked on 44's with ball joints 1975 up.
Old 02-10-2010, 01:31 PM   #6
70BLAZERX2
get an older book for the 68-70 trucks..I do have some of them if you cannot find them..I could e-mail you some exploded pics if needed..I have a factory service manual for these trucks
Old 02-10-2010, 06:57 PM   #7
tmarkjr
I am ordering the service manual today. Pics would help if you can send some. LMC truck doesn't have the parts i'm looking for. Any other parts places you know of? Thanks again.
Old 02-10-2010, 09:39 PM   #8
1969K10
1969K10's Avatar
i picked up a book called the chevy owners bible, or something similar to that. I was the most info on a closed knuckle axle i had seen at the time.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-11-2010, 06:36 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Try www.quad4x4.com Part #QU40188
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-12-2010, 02:47 AM   #10
72shortbed12
Is there a any difference in the dana 44 open knuckle front axles? My 72 k10 has the dana 44 with -5F in the lower right hand corner. My dads 72 k5 blazer has 44 in the lower right hand corner. Are they different?
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
