Old 02-16-2010, 02:05 AM   #1
Baged72
Baged72's Avatar
Stock 1972 sbc 400 specs?
Just curious what was the horsepower and torq in a stock 400 from 1972?
My motor is no longer stock but im wondering how much i might have added to its original numbers...
I am talking about a 400 sb not the 402 bb.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 02-16-2010, 08:35 AM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Stock 1972 sbc 400 specs?
I believe it's about 265hp, and 400 lb.ft on the torque.
bigsnookmaster is offline   Reply With Quote
Old 02-16-2010, 10:37 AM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
And just so you know, the 400 small black wasn't available in these trucks.
HP and torque can vary quite a bit depending on the application.
67 gmc custom lwb dakota truck
69 swb 4x4 project
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-16-2010, 12:31 PM   #4
Baged72
Baged72's Avatar
The 400 didnt come in these trucks??
What did they come in then?
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 02-16-2010, 12:37 PM   #5
OhOneWS6
OhOneWS6's Avatar
In 72 small block was a 350, big block was a 402 that was badged as a 400
OhOneWS6 is offline   Reply With Quote
Old 02-16-2010, 01:20 PM   #6
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
The 400 sbc came in alot of the impala's, station wagon's & so forth. They are a real torque motor so check your heavier car's. I have an unmolested 72' 2bolt 400 out of my Papaw's 72' Impala out in the garage that I plan on building one day for a 73' Camaro project. Hang on to your 400 as they are getting pretty rare and you can make some super fast reving torque out of these motor's. JMO.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-16-2010, 01:40 PM   #7
Baged72
Baged72's Avatar
My 400 is already in my truck, it has aluminum intake, 240/430? comp cam, 600 holley, headers, HEI Ignition, Comp Cam Roller Rockers, Double Roller Timing Chain, i was just trying to figure out some hp/torq #'s
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 02-16-2010, 01:42 PM   #8
OhOneWS6
OhOneWS6's Avatar
How do you know it's a 400? What are the casting numbers?
Old 02-16-2010, 02:37 PM   #9
Baged72
Baged72's Avatar
I know its a 400 because the original owner told me it was and 2nd i did google the casting numbers but... i dont know them off the top of my head, my truck is up north at my shop.
It is a 400 though.. i researched it many times.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 02-16-2010, 03:05 PM   #10
OhOneWS6
OhOneWS6's Avatar
Those casting numbers should tell you what it came out of. You can use that to look up HP/TQ ratings.
Old 02-16-2010, 03:23 PM   #11
Baged72
Baged72's Avatar
I remember looking up the numbers before but i thought it just gave me a range of years it was produced not what actual car it came in and i could of sworn it said it was a truck motor. Maybe i am wrong...
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 02-16-2010, 03:58 PM   #12
too much stuff
Roadtrip!
The casting number won't tell you what it came out of. You will need the code off of the front pad. That will be a stamped number/letter code in front of the pass side head. That should tell you what it came from. The 400 did come in trucks after 72.
69 swb 4x4 project
70 swb (wifes)
70 jimmy camper
Old 02-16-2010, 08:10 PM   #13
Beuford
Beuford's Avatar
Hi "Baged" I don't think these "Deskyop Dyno" numbers are infalable but I played with a bunch of cams and compression figures and the numbers do reflect the different components wether they are dead on or not. I'm guessing not....but I've played with different grinds and components on several engines and always been satisified with the results. Nothing beats the real dyno.
PM me if you want -I'll send you the print out.
Beuford is offline   Reply With Quote
Old 02-16-2010, 08:39 PM   #14
capev86
the 400 was an awesome engine. only problem is most came equipped with a 2 barrel which seriously limited performance potential. if you are rebuilding one, be sure to have (or have machined) cross drilling in both the block and the cylinder heads to compensate for the siamese cylinders that don't have water jackets for cooling. the 2 bolt engine block is stronger at the bottom end.
my dad put a 406sbc in his 84 burb back in the mid 90's for trailer towing. the truck was a 2wd with 3.73 gear and overdrive and he swapped the q-jet and manifold over from the original 350 and kept the restrictive exhaust for practicality sake. it still ran awesome and got 16+mpg without retuning the carb. the only problem was the engine was a '77 model year and had leftover heads with a cross drilled block. towing our trailer on a test run cracked the heads. with the proper cross drilled cylinder heads installed the engine performed beautifully on a month long trip out to Yellowstone and back. the burb went like an over sized camaro and was tons of fun on solo runs. we pulled a few years back when my dad junked his (rusty) truck and saved for a project......which turns out to be my 72 burb 3/4 ton with 3 speed column manual and (soon to be) 4.10 gear swap.
the 307 in my truck (and 327) have a 3-1/4" stroke, the 305/350 have the more desirable 3-1/2" stroke and the 400 has a 3-3/4" stroke. if i didn't have my 406 and my 72 burb had a lot more than 74,000 miles i'd put a 400 crank in that 307 and build a good economy stump puller. the 383 is another good example of power with economy. there is a company out there that is building wide skirt small block's that use a special 4" stroker crank (and very big pistons) and you can get a vintage style small block chevy punched out to 472 cubic inches.....ouch!!
capev86 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
