Old 02-16-2010, 11:11 PM   #1
fla wildman
fla wildman's Avatar
Question pto winch
did not know if you cloud put a pto winch on the side of a 203 t-case.It looks to me like you could it has the same plate on the side of it that a 4speed top loader tranny does.
83 Chevy 4x4 stepside was a 6.2 stick now 350 auto
86 Cutlass with built 350 street/strip car
85 K5 all stock
2006 F250 6.0 the puller
69 c10 soon to be k30 too far gone to fix
fla wildman is offline   Reply With Quote
Old 02-16-2010, 11:20 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: pto winch
nevermind, it has a pto. Not sure on your application though.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 02-17-2010, 09:30 AM   #3
b454rat
Re: pto winch
Yes you can, just need to find the proper PTO for a 203 case. I don't think the gear mesh is the same between a 465 PTO and a 203. Find a dealer that deals with PTO's, they will be able to tell you.
Old 02-17-2010, 10:37 PM   #4
fla wildman
Re: pto winch
ok now I know it can be done. you ever herd of running a pto winch out the back of the truck.
85 K5 all stock
Old 02-18-2010, 11:30 AM   #5
V30 mongo
Re: pto winch
If you are looking for a pto unit to fit a np203 check out Parker/ Chelsea. A serch and you can downloat there applications manual. it will list the transmission types and the drive gear rquired. The PTO port is a standard S.A.E. 6 bolt as most transmissions have, but the drive gear is diffrent to most transmissions and the proper gear will be needed. If your main transmission is an automatic you will run into the problem of gear clash when you engage the PTO. The best way to run a front mounted PTO winch is to have a manual transmission with a reversible type PTO unit. A winch must be able to wind in an out. Also if you put a single speed pto in the transfer case and think you will use the transmission for reversing the worm and gear must be of the right type (left or right worm) for the winch to wind in with the transmission in a forward gear. All these thing complicate issues as to why most people just get an electric winch, even if a good PTO drive winch will make any electric winch look like a little toy.
V30 mongo is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
