Old 02-22-2010, 11:25 PM   #1
smallblock kid
smallblock kid's Avatar
1966 Chevy 4x4
Well i figured beings im getting ready to final build my 66 ive been driving to school for a year now i might as well start a thread. I bought a 1966 chevy 1/2 ton lwb with a 250 straight 6 and a 4spd for $400 last spring. When i first bought it it was only running on 2 cylinders i rebuilt the head and fixed all the wiring to get the lights and signals to work and havent done much since then. This past summer i ran onto a great deal on rockers cab supports and fenders and i bought it all. So now i have everything to fix it but then i ran onto a 1977 shortbed 4x4 for $300 and so im going to part the body out. Ill keep the frame and axles it has 3.08 gears which helps because i am considering putting a cummins under the hood. Im hoping the body swap shouldnt be too hard but the end result should be a sweet truck and i love being different. I am the only one at school that drives anything older than 1975 and i love it.
smallblock kid is offline   Reply With Quote
Old 02-23-2010, 12:05 AM   #2
smallblock kid
Re: 1966 Chevy 4x4
My 66 which will hopefully be 4x4 soon
The 4x4 donor
1966 chevy 1/2 ton freshly rebuilt 350 stock cam performer intake 600 cfm edelbrock 4spd behind it
1986 chevy 4x4 1/2 ton 350 700r4/208 2in lift blocks 31 at tires
Old 02-23-2010, 02:05 AM   #3
Captainfab
60-66 Nut
Re: 1966 Chevy 4x4
You'll have to do a bit of fab work to put that '66 body on that '77 frame BTDT. IMO it would be easier to use your '66 frame and just adapt or build spring mounts utilizing everything from the '77 except the frame.
Either way you go there will be help available here, just ask.
Old 02-23-2010, 01:36 PM   #4
DPowers
DPowers's Avatar
Re: 1966 Chevy 4x4
Welcome to the forum- sounds like a good project you got there.
DPowers is offline   Reply With Quote
Old 02-23-2010, 01:42 PM   #5
Tazfink
Tazfink's Avatar
Re: 1966 Chevy 4x4
Putting a Cummins under the hood.... Sweet! My only concern would be the strength of the frame and axles. If you are looking at doing any pulling with it, maybe upgrade to a 3/4 ton frame and axles. Just a thought.
"Rust does NOT look cool." - Me
"Patina is earned, not made." - Old Hot Rodder.
Cylinder Index
The Cylinder Index (or C.I.) is a measurement device in which the total number of internal combustion engine cylinders (working or non-working) owned by an individual (single-cylinder chainsaws, lawnmowers, 2-cycle, 4-cycle, multi-clinder diesels, trucks and farm tractors) are tallied. The Garage Logician who attains a C.I. in excess of his age is revered. - Joe Soucheray, Mayor of Garage Logic.
Tazfink is offline   Reply With Quote
Old 02-23-2010, 04:14 PM   #6
smallblock kid
Re: 1966 Chevy 4x4
ya i considered doing that but from everybody ive talked to its gonna be easier to build body mounts on the 77 frame for the 66 cab then put the 4x4 under my frame and im not putting the 6bt thats found in the dodge trucks im putting a 4bt in it so it should be fine
Old 02-24-2010, 03:53 AM   #7
Franks Fab Shop
Franks Fab Shop's Avatar
Re: 1966 Chevy 4x4
right in the middle of doing the same!
Franks Fab Shop is offline   Reply With Quote
Old 02-24-2010, 10:50 PM   #8
smallblock kid
Re: 1966 Chevy 4x4
sweet are you using a 70s frame?
Old 02-25-2010, 12:22 PM   #9
Franks Fab Shop
Re: 1966 Chevy 4x4
yes its a 1974 3/4 ton, fo' by fo' shortened 17" from long bed version, although now that i've got the burb body on newer chassis, i wish i had only shortened it 15-16" due to the fact that it seems, to me anyway, that when these 60-66 trucks are 4x4's the front axle just looks like its a bit back towards firewall to me.
i'm going to run this as with "stock" style leaf front and rear,but eventually i'm going to 4 link, coil over front and rear,still 4x4, prerunner truck it.
mainly cuase i'm a desert guy, so haulin azz through woops in an old sub is gonna be fun and cool! also i'lll be able to pull out a coil spring (theres two stacked springs per corner on the shocks i'm gonna run), which will slam it in the weeds to go low and slow on cruise night if i feel the need.
Old 02-27-2010, 02:17 AM   #10
smallblock kid
Re: 1966 Chevy 4x4
Well today was somewhat productive but it wasnt great. i blew a tire out on the 66 on the way home from school luckily i had a spare at home and got the truck home i pulled the doors off and started to get the front clip off i hopefully can pull the front clip off tomorrow and then sell it and the doors and the hood. but i really need to work on our 2001 ford f350 diesel that we are trying to get running and once i get it running ill start driving it to school and start really tearing in to this build but baseball starts soon so im only gonna get to work on it on the weekends
Old 06-13-2011, 12:01 PM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: 1966 Chevy 4x4
Updates?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-03-2011, 10:26 AM   #12
smallblock kid
Re: 1966 Chevy 4x4
sorry eveythings been kinda crazy the last 4 months or so with graduating finishing up baseball season and getting a new job but i ended up buying a 62 4x4 and im going to use the frame from it and the axles from the 77 but beings i missed driving my pickup so much i had a 350 laying in a 1 ton and decided to rebuild it and put her into my pickup ill try getting pics tonite and keep this updated
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
