Old 03-14-2010, 09:54 PM   #1
mwooten92
mwooten92's Avatar
Exclamation hood release broke at latch. hood is shut. helppp!!!
how can i open the hood with the hood release cable broke. i drove the truck home today for the first time and tried poping the hood when i got it in the garage. knowin that the cable was on its last leg. i barely pulled and it snapped. it snapped right at the latch and dont know how to open it.
any ways to open it?
85 C-10 ShortBoxChevy!
Build Thread of my 85' C-10
http://67-72chevytrucks.com/vboard/s...d.php?t=367919
mwooten92 is offline   Reply With Quote
Old 03-14-2010, 10:05 PM   #2
6772fan
Active Member
6772fan's Avatar
Re: hood release broke at latch. hood is shut. helppp!!!
Depending on what year model it is, you may be able to remove the grill and gain access to the hood latch mechanism.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 03-14-2010, 10:12 PM   #3
mwooten92
mwooten92's Avatar
its a 85 chevy c10
Old 03-14-2010, 10:20 PM   #4
pcmcobra
pcmcobra's Avatar
Same thing happened to me. Get a pickle fork or pry bar, something sturdy enough and thin enough to get under hood. Slowly and gently pry up hood, you will need to get a socket in there (use small swivel head) to remove the two bolts holding latch. Get thos out and hood will come up, dont forget, dont close it again until you replace cable.
This can be done with none to VERY minimal damage. Take your time.
Good luck...this is the reason mine is getting painted.
1986 C10 SWB 6.0/4L80e
2010 GMC Sierra CC
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 03-14-2010, 10:28 PM   #5
mwooten92
mwooten92's Avatar
alright thx hope i can get it open!
Old 03-14-2010, 10:32 PM   #6
oldschool18
oldschool18's Avatar
did it brake under the hood or in the cab
oldschool18 is offline   Reply With Quote
Old 03-14-2010, 10:39 PM   #7
mwooten92
mwooten92's Avatar
it broke under the hood next to the latch for sure. the cable was starting to break near just havent gt a cable for it. it pulled through in the cab.
Old 03-14-2010, 10:42 PM   #8
oldschool18
yeah you will have to pry it up
Old 03-14-2010, 11:45 PM   #9
RuralRoute C-30
RuralRoute C-30's Avatar
Had that happen once on my former 95 Caprice Wagon. Was able to go underneath with a long shafted screwdriver and triggered the latch that way. Wasn't easy.
Maybe a long narrow pipe/conduit if you can snake it up to the latch mechanism. Not sure if a coat hanger wire or something you could make a hook with would work from the grill?
Granted with the Caprice I had the entire service manual set that showed me the latch assembly.
Just a thought...good luck!
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 03-15-2010, 12:31 AM   #10
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
damn, i know how bad it sucks too. i actually had a candy job and couldnt even risk scratchng it back in the day. my dad actually got a cordless drill and got up in there and drilled a hole right behind the latch, in between the bolts that hold the bracket to the latch. then just unlatched it with a big screwdriver. might want to take that on for thought if you have new paint. and i just checked my truck, you will be pushng the lever toward the driver side of the truck.
i also recommend a brand new cable,i stole one from another truck at the junkyard trying to be cheap and it happened again about 4 mos later. good thing the hole was there, but was a b**** to get to up there, my arms kinda fatty.
knightowl73 is offline   Reply With Quote
Old 03-15-2010, 12:38 AM   #11
mwooten92
mwooten92's Avatar
cool, so he drilled up from behind the grill?
thx for the tips
Old 03-15-2010, 01:02 AM   #12
knightowl73
yup from behind, no prob wth the help. i try to
Old 03-15-2010, 02:35 AM   #13
bumslie75
bumslie75's Avatar
you can pry it up and remove the two bolts holding the bottom of the latch to the top sec it happend to me a few weeks ago good luck
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 03-15-2010, 08:50 PM   #14
mwooten92
mwooten92's Avatar
got it open!! used a small airbag to push one side of the hood up and used a long hook tool to trip the latch. got a zip tie tied to the latch so i can pull it till i can get a new cable.
Old 03-15-2010, 08:54 PM   #15
knightowl73
glad to hear it!
Old 03-15-2010, 09:11 PM   #16
RuralRoute C-30
Congratulations!
Mark
Old 03-15-2010, 09:20 PM   #17
ryanbenn1207
That happened to me on a 89 dodge ram, i was able to crawl underneath the truck and use a long crewdriver to trigger the latch. have you looked to see if you can gain acess underneath the truck?
ryanbenn1207 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
