Old 03-14-2010, 11:16 PM   #1
anythingonwhlz
1950 GMC 3100 rear end advise needed
I just got a 1950 GMC 1/2t SB 3100 w/ sometype of a 6lug drum rear end thats already an open drive line. Its works great but I would like to switch to a 5 lug wheel pattern,so what rear end would bolt right up to my new 1950 GMC w/ minimal if any modifications. I would like to remain drums all the way around. And also can I just switch to 54 drums in order to change the front to a 5 lug wheel pattern and will that be a direct swap in the front?
Thanks for any advise given to me in advance
1963 409 Impala
2009 HD Roadglide
1970 396 2wd Blazer
1972/67 Bagged 2wd Blazer
1968 396 2wd Panel
1972 396 2wd Short/step
1996 4wd Bagged Tahoe
anythingonwhlz is offline   Reply With Quote
Old 03-14-2010, 11:44 PM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: 1950 GMC 3100 rear end advise needed
That would be a very unusual truck. 3100 is a Chevy model designation. A GMC 1/2-ton would be a 100.
Most people swap the rear from a Camaro or a Chevelle or maybe an S-10 4x4. Others will suggest a Ford 9 inch or 8.8 but those will not match the proposed lug pattern on the front.
If there is a 5-lug rear that will simply fit without modifying the mounting pads I don't know which one it is.
Do you have the hubs, drums and backing plates to convert the front? If not it might be cheaper and certainly easier to find parts to convert to disk on the front.
You need to switch the bearings and the backing plates too, and may need to redrill the holes in the backing plates. Its been many years since I last did this swap and don't remember the details.
I prefer a disk brake conversion because I believe it results in a safer vehicle using easier to maintain parts and if you shop carefully does not cost a lot to do.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 03-14-2010, 11:45 PM   #3
mobileortho
mobileortho's Avatar
Here's a copy of an article that was posted here a few weeks ago. I'm not aware of any direct bolt on replacements for the front that won't require the use of an adapter, but there are a ton of aftermarket kits available for the AD.
Robert C.
1950 3600
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 03-14-2010, 11:49 PM   #4
anythingonwhlz
Steve
Thanks for the info. Then it must be a GMC 100 I thought it was a 3100 series. I really dont want to have to do alot of mods to swap the rear end. I was hoping there is a simply drop in and bolt up 5 lug rear end. As for the front didnt realize alot also needed to be done. I thoght I could just slip on a 5 lug drum,am I wrong?
Thanks again
1963 409 Impala
2009 HD Roadglide
1970 396 2wd Blazer
1968 396 2wd Panel
Old 03-15-2010, 12:39 AM   #5
Steve@OldSub.com
Unfortunately there is no drop in and bolt up 5-lug option. The link Robert posted shows a number of approaches others have taken. And I didn't see anything there that surprised me in any way.
The stock rear was about 62 inches wide wheel mounting surface to wheel mounting surface. If you get much narrower than that the tires will rub the bed, much wider and they will stick out of the fenders. So you want to find a rear that will put your wheels and tires inside the wheel well with enough clearance both inside and outside.
Well you said '54 and I limited my thinking to '54 car brakes. The '51 to '54 Car has Bendix type brakes which are different than the Huck brakes a '50 has.
I've never swapped Huck brakes but its possible that 5-lug Huck drums and hubs would be almost that easy. Those would be '49 and '50 Chevy car brakes.
I've not tried this particular swap but that could be easy to do without the backing plates though you may still need to match the bearing sizes.
I last did this type of swap in the middle 70's and I'm a little fuzzy on some of the details especially the bearings part... If I'm wrong I'm sure someone will come along and correct me.
Like I said before, I prefer the disk conversions for the front these days. I can't imagine doing all that work and still having drum brakes. Especially Huck drum brakes...
Steve@OldSub.com
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
