Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-17-2010, 09:47 PM   #1
jgreene0717
Jason
jgreene0717's Avatar
71 C-10 Big Block Swap
Sold the small block to fund the big block swap. Here are the specs and some pics of the new rat.
454 .030 over
GM Steel Crank
GM Double Dimple Rods with 7/16 fasteners
TRW Forged Dome Pistons L2349F
781 Oval Ports with 2.19 1.88 valves
Lunati Hydraulic Roller 282/290 .600/.600 #60212
PRW 1.7 Ratio Rockers
Edelbrock Performer RPM Airgap
Holley 750 HP
jgreene0717 is offline   Reply With Quote
Old 03-17-2010, 11:53 PM   #2
70stroker
70stroker's Avatar
Re: 71 C-10 Big Block Swap
Looks awesome man. When ya gonna have it in and running.
I just put my bbc in my truck tonight
70stroker is offline   Reply With Quote
Old 03-17-2010, 11:56 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Good looking truck and nice motor - glad to see the BBC's are getting some love!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme
1965 Chevy Bel Air Wagon (daily driver), 350/TH350, factory a/c - and it works!
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/4.10's
2005 GMC 1500 ccsb, 5.3L/3.73 G80, tow pkg
2006 GMC 2500HD, 6.6L/6 spd, 6" lift, 35's
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-18-2010, 08:22 AM   #4
jgreene0717
Jason
Cleaning up the firewall and frame rails for paint before installing. Should have it painted and the engine installed this weekend I will post some pics when it is in.
Old 03-18-2010, 09:01 AM   #5
djracer
djracer's Avatar
Kool we can stress test the turbo 350 and 12 bolt soon.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-20-2010, 11:34 PM   #6
jgreene0717
Jason
Update got the firewall painted and engine installed. Have to get a convertor and headers so hopefully I will have it going soon.
Old 03-21-2010, 01:13 PM   #7
djracer
djracer's Avatar
Looks sweet.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-21-2010, 03:46 PM   #8
fiddy9apache
fiddy9apache's Avatar
theres nothing better than a BB, awesome ride!
fiddy9apache is offline   Reply With Quote
Old 03-22-2010, 10:05 PM   #9
jgreene0717
Jason
Moved motor back 1"1/4 tonight. I did not like how close it was going to be to the radiator or how far is was from the firewall. Should help weight transfer a little anyway.
Old 03-22-2010, 10:15 PM   #10
djracer
djracer's Avatar
sweet bring a bunch of cash tomorrow and you can crank it this weekend.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-25-2010, 12:40 AM   #11
Autometer
Autometer's Avatar
What mount bracket is that? Will it let you go 3" back?
Autometer is offline   Reply With Quote
Old 03-25-2010, 08:20 AM   #12
jgreene0717
Jason
The mounts came from performanceonline.com. In small or big block applications they are made to mount in the forward holes on frame rails. You can use them in the rear most holes on frame for small block installation but the big block will not due to coming in contact with firewall. I moved it back as much as possible form front holes on frame and just redrilled the frame and crossmember to accept new location. It is back 1"1/4 from that point. In order to go back 3" you would have to modify firewall.
Old 03-25-2010, 08:39 AM   #13
bamabaxter
bamabaxter's Avatar
What is the benefit of those....I like the way they look. Stronger I guess since they are tubular. Are they easier to install the engine ?
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 03-25-2010, 10:08 AM   #14
djracer
djracer's Avatar
Many Reasons. For one thing they are much cheaper than oe 72 up mounts. They are 129 for the mounts and the stands and they swap you to a car type mount so you can run solid mounts if you want. I would think they would help a little with hedder clearance and they should be easier to install.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-25-2010, 10:40 AM   #15
jgreene0717
Jason
Dido on what djracer said.
Old 03-25-2010, 10:58 PM   #16
Autometer
Autometer's Avatar
My motor is already moved back 3" but never liked the look of my "custom" mounts. I really liked those.
Old 03-25-2010, 11:12 PM   #17
djracer
djracer's Avatar
Post a pic if you don't mind.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-26-2010, 12:01 AM   #18
Autometer
Autometer's Avatar
This is the only pic I have on my computer. I'll have to go snap a pic of the mounts.
Old 03-26-2010, 07:31 AM   #19
djracer
djracer's Avatar
Is the firewall notched?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-26-2010, 09:02 AM   #20
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hey guys dumb question but how does the trany linkage line up ??? I'm getting ready to do a swap and was woundering if that was an issue??
Hottrucks is offline   Reply With Quote
Old 03-26-2010, 10:19 AM   #21
jgreene0717
Jason
I have not got that far yet on swap but all factory linkage will interchange between big block and small block. The only issue I would think will be header clearance.
Old 03-26-2010, 12:16 PM   #22
Hottrucks
Hottrucks's Avatar
thanx I'm putting a caddy in mine so when I slide things in I thnk the linkage will be a good point to determine how far forward/back the motor need to be?? I'm going to have to make up a drive shaft anyway....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 03-26-2010, 06:32 PM   #23
Autometer
Autometer's Avatar
[REDNECK]I used a come-along from the clutch hole to a seat mount to pull it in.[/REDNECK]
The cab isn't any good. I have another cab to use that i'll have to do a better job of notching the firewall.
Old 03-27-2010, 11:23 AM   #24
Shyguy
Junior Member
Shyguy's Avatar
Good looking 454s.
We just put a '74 454 from a C-30 into my '71 lwb stepper. We had to use the BB mounts out of a '75 to get the header clearance for the style hooker headers I have.
This is not a power machine though, it is hooked to old style 4 speed transmission with an open 3.73 rear.
We could not use any of the pre-drilled holes and be able to mate up to the transmission.
I did not realize I would have a heat soak problem with my starter running headers so now I have to get a mini starter. I should have though since I know others have had the same problem.
We used the BB radiator shroud out of the '74, but had to modify it some to clear the crank pulley, power steering pump and alternator.
I still have not got around to taking pictures, I guess I better add it to my to do list.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-27-2010, 12:16 PM   #25
Autometer
Autometer's Avatar
Get a snap on heat shield first to see if that'll do the trick.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
