Old 04-21-2010, 12:36 PM   #1
D-Rat
D-Rat's Avatar
hard starting with new Edelbrock when warm
The 1406 on my 400 makes cold starts a breeze...fires up on the first crank every time. The problem is when the truck is warm, it doesn't like to start and usually requires me to pump the gas pretty good while turning the starter. Eventually it catches.
What do I need to adjust? The carb is brand new and unaltered. Let's assume timing is fine becuase this was not an issue with the previous carb, though it did have other issues.
I'm also down on "stab it" power compared to the 730CFM Holley I took off. Ideas?
I'm not crazy about rejetting, etc., as I've never torn one of these down, but if that's the only option, well...
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 04-21-2010, 01:09 PM   #2
Tkmadone
Re: hard starting with new Edelbrock when warm
Sounds too rich. Next hot start don't pump it, just hold the throttle half open and crank. If it starts right up then you are definitely too rich.
Tkmadone is offline   Reply With Quote
Old 04-21-2010, 01:12 PM   #3
71tahoe
71tahoe's Avatar
Your "stab it" power is down because it's only 600cfm.
71tahoe is offline   Reply With Quote
Old 04-21-2010, 01:19 PM   #4
cdowns
cdowns's Avatar
do you have a carb spacer like edelbrock recomends in the instruction booklet so that the fuel doesnt boil
Old 04-21-2010, 01:29 PM   #5
mclairmo
Is the choke plate open when it is warm? If not, then the choke is not working and it needs to be fixed/replaced. When you pump the gas, you are actually opening the butteflies and allowing more air to enter, which is what the engine needs when warm. A warm engine should not need to be pumped to start up. However, when the engine is cold the choke plate needs to be closed, which explains why your cold starting is great. A closed choke plate will also kill your power. The cfm is fine for your engine and should not be a source of your "stab it" power issues.
mclairmo is offline   Reply With Quote
Old 04-21-2010, 02:20 PM   #6
Leviticus
Shake and Bake!
Leviticus's Avatar
Are you getting any hesitation on take off? And re-jetting an Edelbrock is quite simple, and can be done while it is on the engine although I doubt this is your starting problem. Edelbrock makes a nice jet kit for this. Also, like Cdowns said, a spacer is recommended.
What type of choke did you get, electric or manual?
even though your last carb worked well, its a good time to check you timing anyways. The PO of my truck had the timing way to advanced and it would be a bear to start in certain conditions.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 04-21-2010, 02:24 PM   #7
CharlieBrown
CharlieBrown's Avatar
Thats what I would guess
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 04-21-2010, 02:33 PM   #8
D-Rat
D-Rat's Avatar
Choke is working fine.
There is no carb spacer. It's bolted directly to the manifold with just the gasket in between. That explanation makes sense.
What part are others running here? How thick? Anyone have one laying around they're not using?
Old 04-21-2010, 02:41 PM   #9
Leviticus
Shake and Bake!
Leviticus's Avatar
Do you have a spread bore or square bore intake?
Thomas Jefferson
Old 04-21-2010, 02:52 PM   #10
CharlieBrown
my truck has a dual plane intake..never boiled
my surburban has a open intake..it boiled until I installed the spacer
1972 Surburban 4x4
Old 04-21-2010, 03:05 PM   #11
D-Rat
D-Rat's Avatar
Not sure I know the difference, but it's one big hole. It's an Edelbrock RPM intake if that helps.
I'm looking at spacers...which is better - open design or 4 hole?
Old 04-21-2010, 03:07 PM   #12
CharlieBrown
use the 4 hole
that should stop your problems..and it will also help you idle circuit
1972 Surburban 4x4
Old 04-21-2010, 03:26 PM   #13
Leviticus
Shake and Bake!
Leviticus's Avatar
If it is one open passage (not divided) than you most likely have a single plane square bore. You should be able to pick up a carb spacer at your local auto parts store/speed shop.
Just make sure it will match your carb and intake. The 4 hole designs should help as well, as Charlie said.
Here is a pic of a spread bore dual plane intake for reference.
Thomas Jefferson
Old 04-21-2010, 03:46 PM   #14
Eddie H.
Eddie H.'s Avatar
I had the same problem until I installed a 4 hole plastic spacer to insulate the carb from the manifold heat.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 04-21-2010, 03:50 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Definitely sounds like a "Heat Soak" issue. I would try the phenolic spacer to remove the heat from the bowls of the carb. I am running one on my stroker engine with the Edelbrock carb and intake.
Frank
piecesparts is offline   Reply With Quote
Old 04-21-2010, 04:28 PM   #16
D-Rat
D-Rat's Avatar
Nabbed a 1/2" one off ebay new with gaskets and studs for $22.99 shipped. Will see how that works. Thanks guys.
Old 04-22-2010, 05:31 PM   #17
AH619
AH619's Avatar
Most of the edelbrocks i have require about 1/4 throttle push with no pumping when warm. I have been told that all these drip a little fuel out the bottom? Sometimes i give mine 1 pump before i start it?
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 04-22-2010, 10:38 PM   #18
JCA1972
JCA1972's Avatar
Hey D-RAT I'm having the same problem with my 1406, I had a 1405 and it would start fine every time, the 1406 takes a while to start when hot, I have an edelbrock performer intake so it has the 4 holes. let me know if that spacer fixes the problem.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 04-23-2010, 01:46 PM   #19
D-Rat
D-Rat's Avatar
will do.
Old 04-23-2010, 01:54 PM   #20
Shyguy
Junior Member
Shyguy's Avatar
Don't me to hijack, but since you all are talking about Edelbrock carbs.
What would be the best one for my stock '73 454 with an manual transmission.
Thank you.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-23-2010, 04:06 PM   #21
D-Rat
D-Rat's Avatar
The 600CFM is marginal for my small block 400 but might work ok on a bigger motor with larger jets. A stock '73 454 is pretty low compression and probably doesn't have much in the way of high flow heads, so you might not get much benefit out of anything larger.
Old 04-25-2010, 11:30 AM   #22
D-Rat
D-Rat's Avatar
Spacer seems to have done the trick!
Old 10-28-2014, 05:14 PM   #23
Crazy
Iv got the same problem, and my motor also diesels when ever i get to my destination and shut it down will the spacer fix this as well.
Crazy is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
