Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-24-2010, 06:57 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
New project
1987 S-10 will be Forged 385 , TH350 , 9" Ford caltracs truck on 275 / 60 / 15 drag radial .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-24-2010, 09:23 PM   #2
djracer
djracer's Avatar
Re: New project
I thought we had talked you into a full size truck.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-24-2010, 11:05 PM   #3
Captainfab
60-66 Nut
Re: New project
Cool....Are you going to have a build thread?
Old 04-24-2010, 11:31 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Yea , i just couldn't do it . I am not funded for making alot of power so i have to be light .
I will put together a build thread . This will be my forged 383 set up with 150 in the fogger and 150 in the plate to start with .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-25-2010, 09:55 AM   #5
shawnt
shawnt's Avatar
Re: New project
I dont care if it's full sized or not. Nice project
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 04-29-2010, 05:07 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Found out last night that the block needed 2 sleexes at .030 and 1 at .040 . I spent $670 on SRP pro series pistons , so 2 sleeves it is . I m also dropping off the cam for clearencing tomorrow . Crower sportsman rods and eagle lightweight 4340 crank all balanced . My neighbor came over yesterday and ask if i would help him haul off an old transmission . Turns out it is a 73' TH 350 out of his truck . He had the dealership rebuild it and the service tech talked him into a 700r4 swap and did it as a side job . Turns out the trans has only been sitting 3 years and has low miles . I'll shoot some pics of the current state of the motor and try and update .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-29-2010, 05:36 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: New project
looking forward to the updates....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-30-2010, 12:34 AM   #8
djracer
djracer's Avatar
Re: New project
wouldn't it be much cheaper to find another block?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-01-2010, 10:08 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well i ask about that . The yard i got the block from doesn't have anymore 4 bolts and they only exchange . I would have to drop back to a 2 bolt main . I made 484 with this top end on a 355 . I don't expect alot more HP , but more torque and the assembly should handle 800 HP . So close to 500 on motor and 250 more nitrous , i need a 4 bolt . My machinist ( a good friend and a high school buddy ) has assured me i will never know it is there and i have run his sleeves before with no problems . Oh , and there is no S-10 build section so i put it here . Hope you don't mind as my primary purpose is to drag race it .
Visual update for saturday .Sorry for the crappy pick of the block it was in the bore machine . Pics of the lightweight forged crank and JE pro series pistons .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-01-2010, 10:36 AM   #10
ripdog28
ripdog28's Avatar
Re: New project
Having a good buddy as a machinist, could have got a 2bolt and had him splay it. Would be better then any stock 4bolt. What ever happened to that 396 you built?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-01-2010, 01:21 PM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Im going to call him bout that as i have a 2 bolt main in his shop that is 4" and never been bored . That would be alot better than the sleeved 4 bolt . Really should have bought an aftermarket block , but then i would end up with a big inch small block , which isn't a bad thing . I mean i already bought good stuff . The price would have been the same all i needed was a block . Kinda stuck with a 383 now or start from scratch .
I sold the 396 with the Luv . The guys that bought the truck are strictly grudge racers so im hesitant to discuss it as it is their race program now . I will tell you that is runs good and is out of the Houston area . The truck has been repainted as the new owners have a body shop . They just bought a proven combo with all my notes and repainted it and showed up in a different area as unknowns .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-01-2010, 06:29 PM   #12
ripdog28
ripdog28's Avatar
Re: New project
Nice, that little thing had to be a bit scary.
69 c-10 BBC
Old 05-02-2010, 10:40 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
It would move around due to the short wheelbase , but i think it made me better as a driver . The truck really reacted to "jerk shift" and the break over point or point of no return ( when sideways) was quicker than a longer truck . Tire pressure was pretty critical as sidewall flex was important . The truck didn't have power steering so you either had to man handle it , chop it ONCE , or lift . Most of the time i would just make the shift and the loss of torque would bring it back in line even if i shifted early . It was a fun truck .
Got the new rim combo on the gray truck today and did a suspention lookover .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-08-2010, 12:05 AM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I ended up listing the old body for my golf cart on Craigslist and the guy who is to replace the ends on my 9" shows up to buy it . Well a little horse trading and he is going to replace the ends on one housing and narrow another housing for the golf cart body .
Ordered the converter and dropped of the trans local for a rebuild . Here's a link to the converter . Hoping i didn't go to tight , but still street worthy .
http://transmission-specialties.com/...products_id=56
Also looking for opinions on this companies converters . Going parts hunting tommorow also .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-11-2010, 09:38 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Sleeves are in and its ready for final hone . Also took a picture of the rods .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-25-2010, 06:20 AM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
My Machinist called me this afternoon and told me he just knocked the last piston in it . I usually assemble them ( motors) , but i think He's pretty proud of this one . This is one of the best pieces i have ever built . He said the deck was so far off his machine couldn't cut it . It was .018 in the front and .031 in the rear . It's zero now . Told me bring the rest of the stuff and we'll finish it up sometime this week . Matt called me this afternoon and told me Kenny Hubbard (another local all around good guy) is ready to build the trans , so i gotta haul that to him coming up . Been working on small stuff like pre plan for radiator . Researching the A/C parts needed to convert to 134A . Also got all the stuff together to build Rick's center section . Looking like i will have some time next week to relax and get busy . This type of work is relaxing and gives me a sense of acomplishment .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-25-2010, 07:14 AM   #17
djracer
djracer's Avatar
Re: New project
you are putting air on the race truck?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-25-2010, 09:09 AM   #18
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Yea , it has air , so im keeping it . It will see some street duty with drag radials and it's light enough those couple of extra pounds won't hurt to much + im getting older . Hopefully i have enough vacuum for power brakes .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-26-2010, 03:14 AM   #19
team39763
Re: New project
How much does it weigh?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 05-28-2010, 08:16 AM   #20
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I will scale it soon and let you know .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-02-2010, 09:33 PM   #21
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well i got the shortblock back and the timing cover and balancer on . The lifters are in and the oil pump and windage tray should be in tommorow .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-03-2010, 01:21 AM   #22
noonzor
Re: New project
looks like a fun project, subscribed!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 06-03-2010, 09:34 PM   #23
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: New project
Nice project- looking forward to hearing it. That's my favorite color, grey.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-11-2010, 07:10 AM   #24
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Not much of an update , but a new picture . i welded up the oil pump pickup and installed the pan . Got a new copper washer for the oil plug . The heads are on and torqued . Timing chain cover wasn't my first choice , but i had it and it was new in the box . Hoping to have the intake and valve train buttoned up by the end of the weekend . Headers and mounts should be here soon . Plaining the install the weekend of the 25th .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-11-2010, 11:04 AM   #25
custom70
custom70's Avatar
Re: New project
Looking good, that thing should be fun to drive.
custom70 is offline   Reply With Quote
Thread Tools
Display Modes
