Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-10-2010, 09:43 PM   #1
racin69z
racin69z's Avatar
A couple ?'s about Nason Epoxy and Kirker Epoxy primers
Hey guys,
The first question I have is about the Kirker enduro prime epoxy primer. For less than $100 for two sprayable gallons, is it too good to be true? Is it a good enough product to trust as the foundation for the entire paint job? I can get it in black, which would be nice, because I will know when to stop blocking the slick sand and Nason 2k Urethane. I also like the idea of black for rock chips on the undercarriage. I hate to see grey primer when the black paint chips off.
Second question, if i buy the kirker, I am going have a gallon of the grey nason sitting there which would be good for sealing right before paint. BUT, the tech sheet does not mention thinning it more for use as a sealer. I called the tech line and the guy acted like it was unheard of to thin an epoxy down for use as a sealer. I know the kirker and PPG primers can be done that way. Has anyone thinned the Nason down for use as a sealer?
Lynn
racin69z is offline   Reply With Quote
Old 05-11-2010, 01:49 PM   #2
8mpg
8mpg's Avatar
Re: A couple ?'s about Nason Epoxy and Kirker Epoxy primers
I have used their stuff and its easy to spray. My truck has been sitting in pieces over the last couple years with a mix of epoxy primed areas and their 2k. Holding up really well. The epoxy primer sands really easily. I really like it. The 2k is ok, doesnt sand quite as well, and you need a bigger tip to really spray it. Id recommend a cheap primer gun from Harbor freight just to spray the 2k. Id go with a 1.7mm tip.
Primer color really depends on what color you are going to paint your truck. I wouldnt use a black primer under a white paint job, etc..
8mpg is offline   Reply With Quote
Old 07-27-2011, 10:19 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm highly leaning toward SPI, but.......
How do you feel about kirker epoxy a year later?
Anyone else is free to weigh in also.
66 Service truck build:
Old 07-27-2011, 11:10 PM   #4
shortbed70
shortbed70's Avatar
If your truck sits inside out of the weather I would be totally fine with epoxy prime but if it goes outside the sun will break down the bonding agents (turns chaulky) and will absorb moisture. I used eastwood's epoxy prime after blasting and then body work then 2k (mar-hyde primer) over it all..Mines been setting for two years and no troubles. I think 2k is 2k and epoxy is epoxy just really depends on the prefrence. I like to use one line of primers from bare steel to ready for paint.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-28-2011, 12:32 AM   #5
LostMy65
LostMy65's Avatar
How about the Kirker brand?
Any negatives or positives?
Old 07-28-2011, 08:08 AM   #6
racin69z
racin69z's Avatar
I used the both the kirker and the nason on my truck. I liked the kirker. It sanded more like a urethane than it did a epoxy. But, I didn't sand too much because I didn't want to go back to bare metal. I liked that the kirker was black because I could see where I was at and not go to the metal.
Lynn
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
