Old 05-12-2010, 05:24 AM   #1
roofingbloke
Tailgate latches
Hi All. Just got off the phone to Mar-k products, they just told me they dont post to the UK, So back to the drawing board,
Im thinking of seat belt fittings male and female, ? has this been done before, if so any pictures or other neat ideas.
Thanks Darron
roofingbloke is offline   Reply With Quote
Old 05-12-2010, 05:28 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Tailgate latches
If you would like, have them ship it to me and I will forward to you. Canadians have problems having American products shipped as well.
Old 05-12-2010, 06:03 AM   #3
Woogeroo
persh's idea page - scroll down and look to the right side...
for tailgate and beds.
A few good ideas for you there.
Wow Products
products/tailgate
Find answers for your 1960-1966 Chevrolet Truck Questions.
Matraca - my 1965 Chevrolet C10 lwb step side
I am unable to reply to send/reply Private Messages since October 2014, so I am not ignoring anyone. Please visit my linked pages above if you wish to ask me anything... I am no longer welcome on the forum, it is a simple fact, nothing more. shadowbanned!
Woogeroo is offline   Reply With Quote
Old 05-12-2010, 07:27 AM   #4
lakeroadster
Stuff that rattles drives me bonkers... and tailgates fit that catagory.
I used these latches from Speedway and mounted them inside the bed. They are rubber and since they are elastic help to minimize squeaking. And at $5.99 a pair they are quite reasonable.
http://www.speedwaymotors.com/Rubber...atch,1581.html
lakeroadster is offline   Reply With Quote
Old 05-12-2010, 07:29 AM   #5
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Tailgate latches
Wow Products
products/tailgate
YOU THA MAN!!!!!!!!!!!!!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-12-2010, 08:06 AM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have the marine latches that were linked above, but chose not to run them on my '56.
I went with these instead..
http://www.pros-pick.com/hiddenlatchkits.html
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-12-2010, 08:47 AM   #7
1Bad62Pro/Street
Not Bad.......
http://67-72chevytrucks.com/vboard/s...d.php?t=355843
Old 05-12-2010, 06:10 PM   #8
roofingbloke
Thanks for the offer, i would like to explore other options before taking you up on you offer, I am kind of a d-i -y guy. if i can use old chevy parts then i think thats the way i will go,
THANKS.PS. Petrol in the UK 1.21 per ltr. 4.5 ltrs to the gallon, ? how much is it in the USA at the moment.
Old 05-12-2010, 06:17 PM   #9
aerotruk63
aerotruk63's Avatar
$1.07 cents Canadian per liter. 4.5 liters/ American Gallon. $4.81 per U.S. Gallon Canadian
Old 05-13-2010, 01:04 AM   #10
Captainfab
60-66 Nut
Gas prices here range from $2.83-$2.95 a gallon within a 10 mile radius. Kinda crazy there's that much difference in a relatively small area.
Old 05-13-2010, 11:57 AM   #11
Bugeyev8
Bugeyev8's Avatar
Here are the ones I did, they are modified late 90s chevy S10 latches with a home made bellcrank and linkage system, the handle is going to be aluminum as soon as I can make it, whole set up cost about 20$ and a few hours
Bugeyev8 is offline   Reply With Quote
Old 05-13-2010, 01:36 PM   #12
SIR
SIR
SIR's Avatar
the latches are from mar-k the cables are from auto zone,the trick is cut the inside lip on the tailgate and weld it up so the cable will fold inside ,out of sight...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 12-14-2015, 03:08 AM   #13
jaredyocum
jaredyocum's Avatar
I used 75 Chevy latch and handle and made my own folding arms, Has worked well for many years
jaredyocum is offline   Reply With Quote
Old 12-14-2015, 03:51 AM   #14
Dismas
I have no pics, but can describe what I did on the tailgate I built for my 66.
used 1" OD pipe, cut to about 8 inches long, 2 pieces.
Welded a cap on one end of each, and cut a slot in the side of each, about 1.5 inches long, and about 3 inches from open end of pipe.
used 2 long, stainless bolts, with the heads cut off, as pis, and found springs at the hardware store to spring load them.
drill and tap a hole in the bolt (pin) to line up with the slot, and use a 1/4 20 bolt to act as a pull handle.
Then you cut a 1" hole on side of tailgate for the pipe, and a slot to align with the slot of the pipe, and weld the pipes in so the pins can go into hole you drill in the bed side in the closed position.
I went one step after this, using some cable and a handle I fabbed up, so I have a pull handle for my latches, to activate both p[ins at once.
Was a completely homemade solution, but is working real well for me.
Dismas is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
