Old 06-14-2010, 03:25 PM   #1
Bulldoser65
Wiper motor or 65 C10
Seems the switch is missing from the back of the turn knob.
I am going to just wire up a toggle switch so I can get it working, so I can have wipers when Im driving in the rain.
The wires going to the wiper motor are Yellow and Blue. Which one is the ground and which one is the power, so I know which ones to tap into for the toggle switch.
Was out working on it right now, but didnt want to test it out without knowing.
Thanks,
John
Bulldoser65 is offline   Reply With Quote
Old 06-14-2010, 09:06 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Wiper motor or 65 C10
http://www.persh.org/pickup/Wiper-washer.htm
try here...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-14-2010, 09:42 PM   #3
raycow
Single speed wiper? Yellow is power. Blue is grounded at the switch to turn it on. Note that the motor must also be grounded through its mounting, or else it won't park.
Ray
raycow is offline   Reply With Quote
Old 06-14-2010, 10:36 PM   #4
Bulldoser65
Yeah Im pretty sure its the single speed. Now I just gotta figure out which is which on the toggle switch, as it isnt marked(the package it was in wasnt ethier).
I will look to see if its grounded aside from those wires.
Thanks,
John
Old 06-14-2010, 10:37 PM   #5
Bulldoser65
Does anyone have a pictures of the switch and wires that go onto the back of the turn switch and go from that to the motor?
Old 06-14-2010, 11:59 PM   #6
raycow
The toggle switch doesn't care which terminal is grounded. Just connect the blue wire to either terminal and run a wire from the other terminal to ground.
The stock rotary switch only has one terminal. It is internally grounded through its mounting.
Ray
Old 06-15-2010, 06:54 PM   #7
Bulldoser65
Ok, thanks man.
I will get it done and post up after I do.
I just got another fan belt and need to change that also.
Old 06-16-2010, 06:16 PM   #8
Bulldoser65
Got the toggle hooked up. Seems to work good. Looking forward to being able to see when its raining while Im driving to work.
Old 06-16-2010, 07:00 PM   #9
raycow
Glad to hear it worked out for you.
Ray
Old 06-17-2010, 10:13 PM   #10
Bulldoser65
Thanks.
I just did a quick job on it to make sure it was going to work the way I wanted. This weekend, Im going to do it again and make the wiring look better.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
