Old 06-15-2010, 04:47 PM   #1
forestb
forestb's Avatar
Hood locking ideas
Has anybody made a good way to lock there hood?
forestb is offline   Reply With Quote
Old 06-15-2010, 05:04 PM   #2
raycow
Re: Hood locking ideas
Maybe those pins that stick through a hole in the hood with a padlock on the outside will make a comeback. Very retro.
Ray
raycow is offline   Reply With Quote
Old 06-15-2010, 05:16 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an earlier thread on the subject:
http://67-72chevytrucks.com/vboard/s...highlight=hood
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-15-2010, 08:13 PM   #4
bama63
bama63's Avatar
saw a thread a few weeks back guy used a cable hood release with just minor modification and looked really sweet
bama63 is offline   Reply With Quote
Old 06-16-2010, 04:34 PM   #5
forestb
forestb's Avatar
Hay markeb01 thanks for the link. How did you attach the chain to the hood?
Old 06-16-2010, 09:28 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
Sorry could`nt resist
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-16-2010, 10:03 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I had to check, it's been a long time. Seems I drilled a hole in the inner hood support panel above and behind the latch, then attached the chain with a long bolt. This allows the chain to hang in just the right location. On the other side, I double nutted the bolt, the second nut being a Nylok. Like the bolt on the grille support, it would take a long time and be very difficult to detach either connection with the lock in place.
Old 06-16-2010, 10:51 PM   #8
c10Mang
c10Mang's Avatar
c10Mang is offline   Reply With Quote
Old 06-16-2010, 11:40 PM   #9
forestb
forestb's Avatar
Has any body tried connecting the lock to the actual latch? Just a thought.
Old 06-16-2010, 11:59 PM   #10
Sillyoldman
#16876
Sillyoldman's Avatar
I put a Hornet Lock on my '71. Great setup imo. I can take some pics if interest.
Updated URL Amazon.com: Megatronix - HL6 - 6 Foot Mechanical... Amazon.com: Megatronix - HL6 - 6 Foot Mechanical...
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-17-2010, 12:05 AM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
If you mean connecting a padlock to the lower latch plate, that's where I actually had mine until I bought the chrome latch plate. I didn't want to drill any holes in the plating which is when the bolt on bracket was added. Here's a shot of the old plate, with the arrow pointing to the padlock hole:
Old 06-17-2010, 12:45 AM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
lmao
Sick5 is offline   Reply With Quote
Old 06-19-2010, 11:24 AM   #13
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Just some flat bar double nutted to the hood.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 06-21-2010, 11:39 PM   #14
forestb
forestb's Avatar
That is vary close to what I meant but for some reason my hood latch looks allot different than both of yours. I thik mine pulls up instead of forward but I will check.
Old 09-28-2010, 09:49 PM   #15
Sillyoldman
#16876
Sillyoldman, you mentioned you installed the above hood lock - quick question for you: where it mounts in the cab - do you have to use the key every time you open the hood or can you leave the "in the cab" part unlocked so you never really need the key (i.e. kinda like a factory new vehicle interior hood latch)?
Thanks!
jocko
If the hood is locked then the ignition is also cut off. This setup is required to be unlocked to either open the hood or start the vehicle. I went to a car show one time and realized that I had forgotten the lock key. I kept a real close eye on that button all day. It can be installed wherever you like as long as the cable is long enough. It seemed to blend in under the steering column best for me. Here's a few pics. Hope this helps. IIRC I bought the 6' kit.
Old 09-29-2010, 06:15 PM   #16
jocko
jocko's Avatar
great, thanks sillyoldman!
Old 09-30-2010, 11:14 AM   #17
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I need to get a picture of it but my truck had what looks like a factory or dealer installed bracket, that allows a small lock to be placed thru the release handle and the bracket, locking it so you can't release it. It is a stamped piece and bolts into the same location as the latch assembly and looks like something GM made, not some aftermarket/home made setup. I'll try to get pics tonight and post up but it works great.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-02-2010, 11:55 AM   #18
chevy_mike
chevy_mike's Avatar
Sorry for the delay but here is what is on my truck. Again, first time I have ever seen this setup but it does work great. Should be fairly simple to replicate. I think most of the hood release handles already have the hole in it, from what I have seen.
Looking up from underneith
Old 10-02-2010, 01:41 PM   #19
markeb01
Senior Enthusiast
markeb01's Avatar
That is very cool indeed. If it’s not factory, somebody went to a lot of trouble to make it appear so professionally done for something that will rarely be seen. That would be a great accessory for one of the aftermarket suppliers to produce, and as you mentioned it should be easy to reproduce.
Thanks for posting such detailed photos.
Old 11-07-2011, 12:23 AM   #20
C4 Metal Werks
C4 Metal Werks's Avatar
Left my truck outside the shop one night last week and some tweekers cut the battery cables out to sell the copper for drug money so I like what TheDark1 did for a hood lock and made my own version.
C4 Metal Werks is offline   Reply With Quote
Old 11-07-2011, 09:59 AM   #21
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Hood locking ideas
Seen something similar like this one before.
http://www.monkeysee.com/play/8187-H...k-for-your-car
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-29-2013, 11:51 AM   #22
Red4x4
Good Ideas.
Anyone else out there, post what you have done.
Red4x4 is offline   Reply With Quote
Old 12-30-2014, 02:45 AM   #23
HeatBox
Here's a simple but effective lock I put on my '67. I used 1/8 steel and used the factory hole on the support.
HeatBox is offline   Reply With Quote
Old 12-30-2014, 11:30 AM   #24
mafosa
another idea, use a electronic mini actuator. somewhere in your custom trucks everyone has relay.
use the 5th pin to "go hot" when when the trucks parked. ad a toggle to the neg. side to over ride the actuator if you want to work on your truck without activating the electric choke.
or just run it on relayed n toggle system. many ways on this platform.
you can even get rid of your entire springs on the hinges. replace them with heavy duty actuators (metal gear type).
many of them have built in limit switches. these really no way someone can over come two of them to open the hood.
plus, now all you have to do is hit the switch to open your hood.
these are just concepts and ideas.
mafosa is offline   Reply With Quote
Old 02-03-2017, 05:41 PM   #25
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Saved for future reference.
66 C20 Service Truck:
LostMy65 is online now   Reply With Quote
