Enjoy your truck
Rear axle (not rear end) swap - 6 lug to 5 lug
I am contemplating switching axles in the rear end of my '63 so I can go to 5 lug rims instead of 6 lug.
At least a dozen years ago I swapped out my original '63 rear end (broken pinion gear) for a complete bolt in rear end from a '67 - '72 that had 6 lug axles. Now I want to put 5 lug axles in that housing. I found this older thread http://www.67-72chevytrucks.com/vboa...ar+axle+change but it doesn't completely answer my question. Are there any stock axles that will swap out directly to give me the 5 lug I want? Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2003 Mazda Protege5 2006 Mazda3 2010 Camaro SS/RS 2014 Jeep Grand Cherokee |
Registered Loser
Re: Rear axle (not rear end) swap - 6 lug to 5 lug
I believe CPP has 5 on 5" axle shafts for a direct swap.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. 2014 Silverado Ext cab, 5.3, daily driver. |
71-72 5-lug rears are a different length vs. the 6-lug housings. If you have a 6-lug 67-70 housing, the aftermarket 5-lug swap option is the most efficient way to get it done.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive... like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar. Cubic inches is like Indiana Jones with a cheap pistol.... |
60-66 Nut
![]() ![]() Join Date: Mar 2007
1970 was a transition year for both the 6 lug to 5 lug as well as the overall differential width. Before ordering axles, you might want to measure yours to be certain of what you have. The '63-early '70 were 62" WMS to WMS. The late '70-'87 were 63 1/2" WMS to WMS. If you happen to have the wider 63 1/2 differential, you could use stock replacement axles. If you have the shorter version, you will have to get the aftermarket conversion axles available from CPP, ECE or Summit.
I know you said your replacement rear was a bolt-in. Please look at where the panhard bar attaches to the axle housng. Does it attach to a bracket welded onto the axle tube, or does it attach to a lug that is part of the center casting? The first is stock for 63-64 and the second is the 65-up design.
The reason this is important is that the shaft splines also changed in 65, from 17 to 30 splines. AFAIK, the aftermarket shafts are not available with 17 splines. You can use the 30 spline shafts, but those require that you replace the differential side gears. This is not at all difficult to do, but just be aware that you must order the gears if you have the 17 spline shafts in there now. Ray |
#6 | |
Enjoy your truck
Greg.
Greg,
you are getting excellent advice here, these guys know their stuff. I just did this to my '63 and installed a 30 spline posi unit and new aftermarket 5 lug axles. There is a down dirty and cheap approach, and that would be to redrill your current axles in a five lug pattern?? although I have never done this. Also, if your 63 axle has pressed on backing plates, you're probably going to want to stay with rear drum brakes, as there are no easy aftermarket approached to hang discs that I found. You would have to remove the backing plate and weld on a flange. I defer to captainfab on this. I stayed with drums on rear for this reason, all you have to do is get drums for a 71 to have the 5 lug pattern that fit on the 63 brakes. It is a much more robust drum with cooling fins too.
292 + TKO500 |
Just did this swap in my 65 Panel.
Its easy.... but there are a couple of tricks... watch the video in this thread MANY times before you start. http://67-72chevytrucks.com/vboard/s...d.php?t=399080 |
Enjoy your truck
Thanks for the advice guys.
I have had the rear end apart a few times, so I am no stranger to danger. I planned on staying with rear drum brakes. I have a complete 5 lug front disc set up, but before I put that in I want to have the rear dealt with. I am pretty sure that I have 30 spline, 6 lug axles. I would like to know if there is a stock rear end out there that would be able to donate it's 5 lug axles into my current housing. Would it help if I measured the width of the housing from flange to flange? Greg
#10 | |
Otherwise (and the better choice) there's aftermarket. New, stronger axles w/zero bearing or torsional wear.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive... like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar. Cubic inches is like Indiana Jones with a cheap pistol.... Last edited by SCOTI; 06-21-2010 at 11:45 PM. |
To my knowledge, there were no stock 5 lug on 5" circle that are the right length for that era truck rear end; when they went to 5 lug, they also went to a different length, although I just read Scoti's, and there may be a few very rare ones out there.
But why run an antique axle? New aftermarket is the best choice, except for redrilling your old axles in a 5 lug pattern.
292 + TKO500 Last edited by Heater63; 06-21-2010 at 11:50 PM. |
Reading this makes me realize how lucky I got when I did mine. I just got some axels from a 70-72 truck and slid out the old ones and put the others in...fit like a champ. My 69 has been around the block before I got it, I am guessing my rear end must be the 70 version mentioned above. great info on here, I won't be so quik to tell someone how easy the swap was now.
69 SWB 505 BBC/400... almost finished 71 LWB Daily driven work truck 350-4 3 in the floor (SOLD) 85 GMC Jimmy 350/400/NP208 35in Mud Brutes 7in total lift (SOLD) 01 Harley FXDL Screaming Eagle heads,570 gear drives,H-D race ign.,S&S carb and pipes, Baker 6 speed trans low fast mean ![]() http://i.imgur.com/vEQiatx.png |
#13 |
Enjoy your truck
Thanks guys - I appreciate all this information.
I will measure the distance from the backside of the backing plate flange to the centerline of the trailing arm perch. If that measurement is not in my favour, who sells aftermarket axles? I need someone who can ship reasonably to Canada (or has a distributor in Canada). I bought my adjustable track bar from CPP and they only used UPS to Canada. That cost me $17 shipping + $53 in duty - not cool. Greg,
#14 |
Senior Car Nut
![]() Join Date: Jan 2008
Greg63, measuring is advised. Recently there was a post on this subject where someone put the later axles in (like hoppa, above) and they fit, sort of. by that I mean that, on closer inspection, the axles were sticking further out, a fact that was hidden by the wider brake drums. the bearings were obviously riding on a different place on the axle but were still working. pictures were posted of the brake drum/backing plate of the mismatch and of the correct axle/housing, but I can't find the post, sorry.
I don't mean to imply the hoppa's axles aren't the correct length, just that there's this other possibility. found it: http://67-72chevytrucks.com/vboard/s...d.php?t=390680
Larry Last edited by fleetsidelarry; 06-22-2010 at 09:26 AM. Reason: found the thread |
#15 | |
Enjoy your truck
It is 56 1/2" from backing plate to backing plate, 7 1/2" from flange to perch at 9 o'clock position, 9" at the 3 o'clock position and 8 1/4" at the 12 o'clock position. Shorter housing or wider? Greg
#16 | |
I took the measurements off of a 71-72 12-bolt, longer 5-lug housing.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive... like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar. Cubic inches is like Indiana Jones with a cheap pistol.... Last edited by SCOTI; 06-22-2010 at 03:14 PM. |
#17 |
OK, I have a queston that may apply to this thread. I have a 67 with 6 lug and want to go to 5 lug. I got a rear end with the gear i am wanting. It is from a 78. Both are 12 bolt. I am wanting to save the trouble of welding on new axle saddels and having to get a relocation kit for the stabilization bar. Can i shorten my axels on the lathe and swap my entire rear end over?
This would make things easier and cheaper for me. Any help would be greatly apreciated. Thank you, Matt |
#18 | |
60-66 Nut
This could work as long as the splines on the axles are long enough. Do you have your own lathe? If you have to pay a machine shop to shorten the axles and cut a new C-clip groove, you would probably be halfway to the cost of the conversion axles. Be sure to check the axle/wheel bearing surface on those '78 axles, to be sure they are going to be worth putting some time/money into.
#19 |
Thanks for the quick reply Captinfab! No idea on the splines right now and i am still trying to do the math on how much i have to cut off VS were the new end of the shaft will be. I think it will actually not be possiable becuase the ond c clip section will line up in place and not allow the new c clip grove to be strong enough. I will add more info when i get both rear ends apart so taht everyone can learn from my mistakes lol. I hope this makes since.
Thank again! Matt |
#20 |
60-66 Nut
Yeah, I didn't think about the C-clip groove location. The axles will need to be shortened aprox .750". It might be doable.
#21 |
hillbilly
if he did go with a 70-87 rear end and welded the brackets to it, how much trouble do you run into with tires rubbing the inside of the bed and backspacing and all that mess.
-1962 C-10 |
#22 |
Seems like I remember reading that 12bolt axles don't have enough material on them to be shortened. I would investigate further.
#23 | |
http://kieth.smugmug.com/Trucks/66-G...Rfcq&lb=1&s=X3 |
#24 |
![]() Join Date: Oct 2012
Here is where my 5 lugs came from. They even tell you the length so what I did was pulled my original axles out first and measured them to be sure. I also have seen 5 lub axles on eBay from time to time for around $40.
Sounds like he has a new rearend so should not be too difficult. |
#25 | |
I've done the swap both ways. Now that conversion axles are more readily available, I just do aftermarket.
Thread Tools | |
Display Modes | |
