Old 06-28-2010, 01:18 PM   #1
GMC1968harrington
Death Wobble
I have a 1968 GMC 1500 2wd and it has a death wobble from hell when i hit a bump in the road. I assume it is caused by wheel bearings, tie rods, ball joints, and pitman arm and sterring box. Should i replace it all or just start with obvious. I recieved this truck from my father in law and it has been in their family since 1972 so i do not want to do things half assed.
GMC1968harrington is offline   Reply With Quote
Old 06-28-2010, 01:22 PM   #2
barryvanhook
barryvanhook's Avatar
Re: Death Wobble
Look at the last 9 words in your original statement ... that might be the best advice you might receive.
Barry
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 06-28-2010, 02:31 PM   #3
Shane
Shane's Avatar
Re: Death Wobble
worn ball joints are notorious for the dreaded wobble ...
Shane is offline   Reply With Quote
Old 06-28-2010, 03:23 PM   #4
cdowns
cdowns's Avatar
Re: Death Wobble
if you wait for it to fail piece by piece you may end up with nothing and the crusher gets what left of the twisted wreckage
Old 06-28-2010, 03:30 PM   #5
Prerunner1982
Prerunner1982's Avatar
Re: Death Wobble
I had DW on my 82 and ended up swapping out all tie rods, ball joints, pitman arm, idler arm and control arm bushings. Might as well do it all while you are there, rather than having to keep taking it apart when you replace another part later still trying to fix it.
Prerunner1982 is offline   Reply With Quote
Old 06-28-2010, 03:31 PM   #6
grs
Re: Death Wobble
Take it to a shop and have them inspect it. It could be an idler arm. And you should also renew the brake system as soon as possible.
grs is offline   Reply With Quote
Old 06-28-2010, 03:39 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
Re: Death Wobble
Each time I buy one of these old trucks to fix up I take it to a shop to have a safety inspection done, of course it helps that my oldest son is a safety inspector where he works.
As stated above it is best to fix everything at once, but sometimes the budget gets in the way.
Some things are easy to check and replace like the idler and pitman arms and normally will not require a re-alignment.
Bottom line-make sure the truck is safe!!!
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-28-2010, 03:46 PM   #8
Prerunner1982
Re: Death Wobble
If it was a newer vehicle or a different problem I wouldn't have said just replace everything, but in an old vehicle if one joint is going out, there is a good chance that the others are too.
Old 06-28-2010, 04:05 PM   #9
johnechi
johnechi's Avatar
Re: Death Wobble
I replaced everything from the idler arm, center link, tie rod assemblies, pitman and gearbox. Now it handles like new.
johnechi is offline   Reply With Quote
Old 06-28-2010, 04:13 PM   #10
GMC1968harrington
Re: Death Wobble
Thats what i thought just thought i would check.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
