Old 07-04-2010, 05:40 PM   #1
vectorit
What?
vectorit's Avatar
Home made burb headliner
Well, I have finished most of the hard work on my head liner board project.
I still want to replace one panel, since it is just barely working. I need to cut out a new one that is about 1/2" wider length wise, but I think it will hang in there for the up coming Brothers truck show.
What do you think?
Chris
1968 K20 Suburban
vectorit is offline   Reply With Quote
Old 07-04-2010, 10:14 PM   #2
rsavage
rsavage's Avatar
Re: Home made burb headliner
Looks great. What did you use to hold the panels up on the metal cross bows? Are those the stock plastic/chrome pieces painted white or something else?
65 GTO 389, tripower 4 spd PS PB AM/FM, Posi PHS documented
70 GTO convertible numbers matching 400, 4 speed
65 Fairlane hipo 4 speed. One of 750 hipos made in 65
69 Blazer 4 WD. Latest restoration project
2018 Durango 392 Hemi SRT 0-60 4.4 sec, 12.9 1/4 mile
rsavage is offline   Reply With Quote
Old 07-04-2010, 10:19 PM   #3
vectorit
What?
vectorit's Avatar
I had to ditch the OEM metal cross bows... They just made everything much more difficult.
With the material I used, there is quite a bit of tension to hold everything together.
I really tried to go all out using the original bows, and even spent a wad of cash on good original plastic retention strips. But in the end it just didn't work out.
Chris
1968 K20 Suburban
Old 07-05-2010, 12:02 AM   #4
Jwill41
Jwill41's Avatar
what material did you use? it looks great and I need to try something with mine.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-05-2010, 12:15 AM   #5
vectorit
What?
vectorit's Avatar
Cutting the boards to fit snug is the key, once you get the board cut right and fitted. All you have to do is use the original center anchor screw, that will keep the board secure. Then use the white plastic strip to secure the next board butted up against each other.
This sheet board was pretty good to work with, flexible enough to work with and gives a little with warm temps.
When I did mine, I laid out the 4x8 sheets on my driveway in the sun. After that, they were "easier" to work with, but I was by myself so if you have a helper you will be so much better off!
I made a lot of mistakes/damage just because of the floppy-ness of these things, and being on my own trying to get things to fit right.
If only I had two or three other arms!
Chris
1968 K20 Suburban
Old 07-06-2010, 12:26 PM   #6
Average Joe
Average Joe's Avatar
Nice work as usual! Thanxs for the pics.
Average Joe is offline   Reply With Quote
Old 07-06-2010, 08:45 PM   #7
PortHeadlight
PortHeadlight's Avatar
Glad the template was somewhat helpful.... and you put up the same kind of FRP material that I had in mind. Looks good. Gives me inspiration. Thanks for sharing! aka "Mr. Meyers."
PortHeadlight is offline   Reply With Quote
Old 07-06-2010, 09:00 PM   #8
Jwill41
Jwill41's Avatar
thanks for the info. I have got to do something eventually.
Old 07-07-2010, 08:22 PM   #9
jbclassix
Junk Yartist
jbclassix's Avatar
subscribing so I can remember this
jbclassix is offline   Reply With Quote
Old 07-15-2010, 01:26 AM   #10
dougo
dougo's Avatar
Turned out real nice, has a clean look. Good job!
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 07-15-2010, 09:20 AM   #11
eagleuh1
eagleuh1's Avatar
Wow, that came out looking real good.
eagleuh1 is offline   Reply With Quote
Old 07-16-2010, 01:30 PM   #12
BIG ORANGE
BIG ORANGE's Avatar
Not bad, looks real nice!
Thats the very same material I used back in 2001 on BIG ORANGE
However I had to go with the original OEM bow's!
The rig got 3 best interior awards in 2yrs!
I also put insulation board behind the headliner for sound deadning!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-16-2010, 02:10 PM   #13
vectorit
What?
vectorit's Avatar
Thanks!
It will be a long time before I get any kind of award for best interior on my burb... Doing 3 bench seats is pretty expensive, and on top of that no one is making OEM style covers for a 68 burb yet. So I am rockin the horse blanket cover in the front, and dirty original covers on the back two for who knows how long.
I got the head liner issue squared away for the most part, and all the side panels done in OEM color and pattern. Plus my carpet, though nice is the wrong color. One of the pitfalls of buying stuff for a burb, before what you actually need is made like they are now a days.
I learned a lot about what actually people are impressed with at truck show's at the last Brothers show, and mostly stock K20 burbs are not one of them.
Maybe it was the show, and what was being promoted.
Though I built my baby for me, so who cares!
Chris
1968 K20 Suburban
Old 06-05-2011, 05:03 PM   #14
kikkegek
kikkegek's Avatar
hi, I am in the middle of trying to fix my headliner in my 86 K20 too...thankfull I found this thread. I am Dutch, so can anybody please explain to me what this FRP material is? and how exactly did you attach the panels to the roof?
kikkegek is offline   Reply With Quote
Old 06-05-2011, 09:52 PM   #15
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
That's an excellent job!
I plan on adding a second headliner lamp in the back of mine.
In fact I may duplicate what you have done on your headliner and it looks very slick!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-06-2011, 12:18 AM   #16
vectorit
What?
vectorit's Avatar
The panels are a vinyl product, and is most often used in bathrooms. Since it is moisture resistant, and is flexible to form on walls.
For your 86, I don't think it may be a good solution. Since on the earlier models like my 68 or the 67 model year, the original headliner was a thin card board like material and it was secured mainly by sitting in a channel along the inner wall of the body. Then there was a single screw in the roof section, that screw helped keep the board bowed up against the ceiling.
The 86 models I THINK used a thicker material, and had foam rubber backed material glued to the board. If there is a channel that the original board fit into along the sides, you may be able to make something like what I did work for your truck.
Chris
1968 K20 Suburban
Old 06-06-2011, 01:54 AM   #17
kikkegek
kikkegek's Avatar
he thanks man!
here's a picture from when we just got it. still a big mess in the back.
and here is a pic where you can see how the trim pieces (top right tan colored) hold the headliner in place. So I do think your solution might work for me. Just need to look into this material here in the netherlands.
was it expensive these frp panels?
hahahaha, and now I understand my own misunderstandig. I read 86 in your sig, while it is 68...but still,great writeup, should be made sticky for more people.
Old 07-03-2011, 10:22 AM   #18
vectorit
What?
vectorit's Avatar
I got everything from Lowe's.
Just need a jig saw, measure tape, and a measuring square.
Chris
1968 K20 Suburban
Old 07-04-2011, 09:04 AM   #19
haskell
haskell's Avatar
Creative, good job.
1969 Chev Longhorn Custom Camper
1955 Buick Century Estate Wagon
1963 Buick Riviera
1953 Chevy 3100 Panel
1967 C-20 V8 4 speed
1951 Willys Jeep Wagon
1964 GMC 4wd Fleetside
1956 Chevy Suburban
haskell is offline   Reply With Quote
Old 07-04-2011, 02:49 PM   #20
rocknss
rocknss's Avatar
Great looking headliner!
rocknss is offline   Reply With Quote
Old 07-04-2011, 09:15 PM   #21
bruin_d
bruin_d's Avatar
Awesome work! I'm going to save this one for when i do mine.
bruin_d is offline   Reply With Quote
Old 08-03-2011, 10:58 AM   #22
haskell
haskell's Avatar
That is a very nice job on the headliner. So little original stuff is out there that original is rarely an alternative.
1963 Buick Riviera
1956 Chevy Suburban
Old 08-03-2011, 01:11 PM   #23
rockc
I would think that someone could repop an original headliner at a reasonable price. That is if there is a demand.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 08-19-2011, 11:11 PM   #24
rockc
I sure would like to have a original new repopped headliner.
Old 08-26-2011, 10:00 AM   #25
Mt Man Chad
Mt Man Chad's Avatar
Some great info here I will use very soon on my 68.
Big Thanks for posting this!
67 CST LWB - Blue/White 327/TH400/Power steering/Buddy Buckets/Speed Warning/4.11 Posi/dogdish. build thread
68 CST SWB - Gold/White 50th anniversary. "010-020" 4 bolt main 383, AFR heads, SCAT forged large journal/TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/4.11 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
