Old 07-13-2010, 11:07 AM   #1
jimig1
jimig1's Avatar
55 chevy pickup 2nd series
I have a 55 2nd series that I just bought about 3 weeks ago. I have been searching this forum and have found some good info. I'm looking to do a frame swap to get IFS. I was doing some search and came across a kit from e-zchassisswaps.com that will let me use the frame of a 73-87 truck. I was wondering if anyone has used this or done a swap with one of these year trucks? I have a truck that I could use to do the modification and it would save me some cash and could finish the truck faster. Are there any draw backs to doing this swap? I'd like to keep the rear about factory height and drop the front a few inches.
55 2nd series Chevy Pickup
1987 Chevy Suburban (parting out)
2004 Chevy Aveo (Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 07-13-2010, 11:34 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 55 chevy pickup 2nd series
73-87 chassis kick up in the rear about 4-5 inches. You will either have to raise the bed floor or live with it higher. You may need to buy off set wheels for the front to bring them in a little. The tries would be at the fender line with a stock wheel and tire. This swap has been done many times but I haven't seen the EZ swap before on a 55 to 73. maybe someone else here has.
dwcsr is offline   Reply With Quote
Old 07-13-2010, 12:20 PM   #3
jimig1
jimig1's Avatar
That is good to know about the bed and the wheels i think that I'd like to see one in person before i go through with it. Thanks
MSRA Member
-George Carlin
Old 07-13-2010, 01:31 PM   #4
jimig1
jimig1's Avatar
Here are some pics of the truck the day that i got it
MSRA Member
-George Carlin
Old 07-13-2010, 01:52 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
the ones i have seen on a 73-87 frame all look like 4x4's. I am not familiar with the ezchassis swap though.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-13-2010, 02:05 PM   #6
jimig1
jimig1's Avatar
I got an email from e-zchassis and they sent this picture of one that used there kit. He is going to talk to the own and see if i can take a look at it up close.
MSRA Member
-George Carlin
Old 07-13-2010, 03:54 PM   #7
55chevy
Car Truck Bike Beer nut
55chevy's Avatar
That is still sitting too high for my taste, they make drop spindles and lowering blocks for those chassis.
Here is a tech article on putting a 47-54 on a S-10 Chassis. http://www.jalopyjournal.com/forum/s...ead.php?t=8491 I tried to find one on 55-59 but no luck
Snow free Florida panhandle, don't miss Indiana winters
94 3500 TD dually
so many cars so little time
72 K5 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 07-13-2010, 08:41 PM   #8
Coronas56
Coronas56's Avatar
That dosen't look like a Minnesota truck........
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 07-15-2010, 02:44 AM   #9
MrSinister
MrSinister's Avatar
that pic should be enough to scare anybody away from that swap, wheels with way too much offset that still stick out like an old minitruck
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 07-15-2010, 02:47 AM   #10
MrSinister
MrSinister's Avatar
seriously why do an ifs swap at all save some dough rebuild the stocker and get disk brakes and drop a few inches with new springs
'56 Big window
350/700r4
9" rear w/disc
Old 07-15-2010, 03:50 PM   #11
pro1955
pro1955's Avatar
Just go find a Camaro, use the running gear and subframe, be happy.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 07-15-2010, 03:54 PM   #12
jimig1
jimig1's Avatar
I really want IFS for a nicer ride I want to get it finished an drive it to a bunch of shows and maybe do the power tour
MSRA Member
-George Carlin
Old 07-15-2010, 04:21 PM   #13
ambryatim
ambryatim's Avatar
The camaro clip will drop the truck about 5"-6" and you will have IFS, then go out back and install the diff inside the leaf springs and be done. Or you could go with Truck Arm suspension. That is what I am doing. Check out my build thread to see how I installed my clip. It is easy to do and probably cheaper in the long run. IMO.
ambryatim is offline   Reply With Quote
Old 07-15-2010, 04:52 PM   #14
pugs
pugs's Avatar
you really dont need the EZ to swap to the 73 and up chassis, just swap out the stock mounts. front will basically bolt up where they are on the new chassis. rear one will have to set and welded once front are and the cab bolted down and leveled f>b s>s. now when i did the swap a few years i notched out the cab from the rear seat rail back on the inside of the rear mounts to lower the cab down as much as possible. also the wheel base is alitle longer on the newer chasis. if you really want to do the chassis swap
go to a 63-72 , 71-2 have disc brakes and and most have trailing arms which is easier to lower the rear and are the correct wheel base
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 07-16-2010, 12:40 AM   #15
ambryatim
ambryatim's Avatar
Here is some good info on a camaro clip install.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
