Old 07-17-2010, 01:05 AM   #1
iroc12valve
Home Made obd scanner ??
on my 1991 crew cab (square body like a suburban) it is running like a diesel and the check engine light is on, I remember someone telling me that on safari's up to 1995 you could use a short piece of wire to jump the connectors where you would normally plug in a scan tool and then the engine light would flash xx many times slowly and then xx many times quickly ( like morse code almost) which would give you a code # (for example 2 long then 3 short for # 23)
I assume this works on the trucks too but i dont remember the exact spots to "jump"
Also if any one has a link to how to decipher the codes E.G. code 23 bad ign coil, that would be much appreciated
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 07-17-2010, 01:16 AM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Home Made obd scanner ??
stick a paperclip in the A and B terminal on your OBD connector under the steering wheel,
while looking at it, A will be the upper right, and B will be the one just next to it, to the left,
turn key on, and start counting the enging light
63chevyll is offline   Reply With Quote
Old 07-17-2010, 01:54 AM   #3
iroc12valve
Thanks You
do you happen to know where to find out what the codes correspond to (other than in those chilton manuals i cant find mine right now)
and some K5's lol
Old 07-17-2010, 01:58 AM   #4
63chevyll
63chevyll's Avatar
if you post the codes we can help you out,
ill be outa town this weekend, but post them anyway
Old 07-17-2010, 02:11 AM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
When doing this, DO NOT START THE VEHICLE!!!
Each code will flash 3 times before moving on to the next code.
First and last code to flash will be code 12 which will be *(pause)** (long pause) *(pause)** (long pause) *(pause)**
a bit of a longer pause will happen before the next trouble code will flash, again 3 times. Once all trouble codes have flashed it will flash code 12 again.
It'll continue to do this as long as you have the key turned on and the paperclip plugged into terminals A & B.
Heres a listing of the codes I found online for ya.
GM OBD-1 Diagnostic Trouble Codes
For 1995-previous model year EFI-equipped GM vehicles. NOTE: Some codes not supported on all models, consult your specific vehicle's service manual for the correct trouble code list and description for your application.
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 CI Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-17-2010, 02:30 AM   #6
iroc12valve
The internet really is a valuable tool, Thank you very much
I nominate this thread for a sticky so that these codes/procedures will be easily located by all
and some K5's lol
Old 07-17-2010, 10:05 AM   #7
68 TT
Still plays with trucks
68 TT's Avatar
If it doesn't flash a code 12 then the ECM / PCM does not self check good and you need another one.
I had one where the circuit board broke free of the case and was in limp home mode that wouldn't flash a code 12.
67 C10 Suburban The Ant Farm http://67-72chevytrucks.com/vboard/s...82#post6095882
69 C10 shortbed stepside project 45 ACP http://67-72chevytrucks.com/vboard/s...13#post4899613
69 K20 lwb TBI 400 4L60E NP208 square body chassis http://67-72chevytrucks.com/vboard/s...=1#post3955165
68 Camaro SS / RS 500hp 439 inch big block T-400 http://67-72chevytrucks.com/vboard/s...d.php?t=528952
79 Malibu TPI 350 4L60 3.73 gears
68 TT is offline   Reply With Quote
Old 07-17-2010, 10:22 AM   #8
BGRAFX
I tried the paperclip method on my 91burb and couldn't figure it out so I went to the auto parts store and they will do diagnostics test for free.
BGRAFX is offline   Reply With Quote
Old 07-17-2010, 10:26 AM   #9
Keith Seymore
Keith Seymore's Avatar
Good info, guys.
Do I also understand correctly that you can't do this on a '96 and up vehicle (specifically a '97 Suburban) because of more stringent OBD requirements?
K
Chevrolet Flint Assembly
1979-1986
1986 - Present
Old 07-17-2010, 10:29 AM   #10
BGRAFX
Correct if I'm wrong but I think it only works on OBD1 plugs as the 95 and newer trucks have a completely different plug OBD2
Old 07-17-2010, 10:36 AM   #11
BGRAFX
Here is a website for obd-codes http://www.obd-codes.com/faq/read-gm...codes-free.php
Old 07-17-2010, 01:48 PM   #12
63chevyll
63chevyll's Avatar
paper clip only on 95 AND OLDER, 96 and newer needs a scanner
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
