Old 07-18-2010, 10:22 PM   #1
boat
boat's Avatar
63 rebuild
Whats up guys, I've been on this sight awhile checking out things, and decided to show you my build. This is a 1963 Chevy pickup i've had since 1985 when i was 16. It started out with a 460 ford motor in it, it had to go. I put a 350 in 3 years later and had it painted, drove it till 1992 and parked it. Been setting ever since. I decided to tear it down and give it a new life. http://67-72chevytrucks.com/vboard/a...1&d=1279506104
boat is offline   Reply With Quote
Old 07-18-2010, 10:28 PM   #2
boat
boat's Avatar
Re: 63 rebuild
more picName:  2010 truck 060.jpg
Attachment 611879
Name:  2010 truck 045.jpg
Attachment 611881
Name:  2010 truck 105.jpg
Old 07-19-2010, 07:23 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 63 rebuild
Lookin' good boat
Love the mother-in-law seat LOL
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-19-2010, 07:02 PM   #4
boat
boat's Avatar
Re: 63 rebuild
more pic
Old 07-19-2010, 07:12 PM   #5
boat
boat's Avatar
Re: 63 rebuild
Well down to the frame ,so this is where it starts
Old 07-19-2010, 11:12 PM   #6
boat
boat's Avatar
Re: 63 rebuild
A lot of work went into these pic, cleaning, scraping, grinding, sand blasting,then primer.now its clean enough to work with.
Old 07-20-2010, 01:20 AM   #7
Captainfab
60-66 Nut
Re: 63 rebuild
That's cool that you've hung on to this truck this long....was it your first vehicle? Looks like it was pretty nice before you tore it apart. What's the basic plan this time around? Your truck is the ideal truck IMO.....A '63 Custom Cab, big back window, short fleetside
Old 07-20-2010, 04:07 PM   #8
boat
boat's Avatar
Re: 63 rebuild
I had a 71 nova before i got the truck , I,m going to go with the 2.5'' disc brake drop spindles, 4''/6 drop, to start with.
Old 08-16-2010, 11:00 PM   #9
boat
boat's Avatar
Re: 63 rebuild
trying to decide if i should buy a new fender or go with the replace patch http://67-72chevytrucks.com/vboard/a...1&d=1282013798
Old 08-17-2010, 12:55 AM   #10
Captainfab
60-66 Nut
Re: 63 rebuild
I would definitely patch your existing fender. In fact you should be able to repair that with just a piece of 18ga cold rolled sheet. All you need to do is put that little bit of a curve and the lower body line in it. That's what I would do. You might need that inner support also. The new replacement fenders leave some to be desired and require some work to get them in shape.
Old 09-26-2010, 01:49 AM   #11
boat
boat's Avatar
Re: 63 rebuild
painting the frame
Old 09-26-2010, 02:06 AM   #12
boat
boat's Avatar
Re: 63 rebuild
early classic drop spindles with disc brakes. front end rebuild kit by moog, and 1 '' drop front coil springs and 5 '' drop rear springs. adjustable panhard bar, kyb shocks
Old 09-26-2010, 02:56 AM   #13
boat
boat's Avatar
Re: 63 rebuild
need to find a power steering box
Old 09-26-2010, 09:13 AM   #14
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 63 rebuild
That's looking great Boat
Is that the original trans x member,just moved rearward?(sans lower supports)
If so,what kind of E brake set up did you have?
I'm at about the same stage with mine(also a '63)and need to make a decision soon on what I'm going to use.I'll be running a TH 350.
Thanks,T
member#7816
'61 GMC in progress
Old 09-26-2010, 12:46 PM   #15
boat
boat's Avatar
Re: 63 rebuild
no its not the original trans member .when i bought the truck it had a 460 ford engine in it ,when i dropped the 350 in i used the same cross member just moved it around a little works fine, don,t know what it came out of . as far as e-brakes i never had any cables ran anywhere so i need to figure that one out.
Old 09-26-2010, 12:49 PM   #16
boat
boat's Avatar
Re: 63 rebuild
more pic
Old 09-26-2010, 12:52 PM   #17
boat
boat's Avatar
Re: 63 rebuild
rear end
Old 09-26-2010, 02:51 PM   #18
protrash64
Resistance is Futile
protrash64's Avatar
Re: 63 rebuild
.......lookin' sweet boat!!! Sure nice to work on them with all the easy access. Cant wait to see more progress.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-26-2010, 03:09 PM   #19
boat
boat's Avatar
Re: 63 rebuild
been doing some cleaning while waiting on parts to come in.
Old 09-26-2010, 03:13 PM   #20
boat
boat's Avatar
Re: 63 rebuild
and did put in new u-joints
Old 09-26-2010, 05:43 PM   #21
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 63 rebuild
NIce work!! Subscribed!!
Alan's Classic is offline   Reply With Quote
Old 09-26-2010, 10:33 PM   #22
Ol'63Gmc
Ol'63Gmc's Avatar
Re: 63 rebuild
Thats awesome, Boat! Subscribed for sure!
Ol'63Gmc is offline   Reply With Quote
Old 09-27-2010, 01:00 AM   #23
boat
boat's Avatar
Re: 63 rebuild
sandblasted and painted some parts
Old 09-27-2010, 01:02 AM   #24
boat
boat's Avatar
Re: 63 rebuild
the new blasting box
Old 09-27-2010, 01:11 AM   #25
boat
boat's Avatar
Re: 63 rebuild
got my new power steering box ,just waiting on the conversion kit from classic parts
