Old 03-19-2012, 09:28 AM   #201
CuRtdOgG
CuRtdOgG's Avatar
Re: maxxy's 81 bagged c10 build
Looks good man
CuRtdOgG is offline   Reply With Quote
Old 03-23-2012, 02:14 AM   #202
maxxxy
maxxxy's Avatar
Originally Posted by CuRtdOgG View Post
Looks good man
Thanks Curt!
I wanna see how yours is coming along!
Ok so a little progress doing odds and end little things.
Ordered a new thornbeck bros. tubular transmission crossmember
Tore out the A/c unit because as much as I'd hate to spend the money, I think I'm gonna eventually get that vintage air under dash setup.
Pulled out the old trans xmember.
Installed some billet brake, accelerator, and e-brake pedals.
Plus other random small things.
I have a question, does anyone know how to shorten e brake cables?
And also I've decided on the next big step of my project, I am going to section my crossmember 1.5".
It's either this, or "Z"ing my fame probably 2inches.
The reason I am thinking about the section, is because it is more self contained and I can remove it and transport it to a sandblaster or welder much easier than moving the whole truck. Plus I think it's less things I need to get like metal plates and such. But if someone can shed enough info to sway me, I'm all for it.
Oh and does anyone know where to buy sandblasting material locally? I picked up a little sb gun for $12 bucks at attwoods so I thought if give it a try. Lol
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-23-2012, 02:18 AM   #203
mineralgrey01gt
Damn man, truck looks like mine almost. I say z the frame. Mine is if you want some pics of it and such I can get them for you. Also before you ask I didnt do the work myself. I purchased the truck bagged already.
mineralgrey01gt is offline   Reply With Quote
Old 03-23-2012, 11:43 PM   #204
luifer76
luifer76's Avatar
Originally Posted by maxxxy View Post
Got my truck out of the barn and washed months of dirt off!
Here's a picture.
Nice!....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 03-24-2012, 09:22 AM   #205
mooseknuckles
mooseknuckles's Avatar
x2 on "z'ing" the frame....but I'd go 3" to make it worthwhile...in case you decide to get bigger wheels etc...
mooseknuckles is offline   Reply With Quote
Old 03-28-2012, 12:24 AM   #206
maxxxy
maxxxy's Avatar
Woah mineralgrey! They're like twins! Lol.
Well since I took out the a/c, I replaced the small front tires, now I'm running 235/70/15 all around.
Today when I got home from school, I did a little work...
The crossmember is out!!!!
It's too late to turn back now! Haha.
I figure as of right now I'm going to section the crossmember 1.5".
I chose to do the x-member instead of the Z because I'm not wanting really an extreme drop, and this will keep my lca's from dragging off. And if I want to z it later, I can either just do a small Z or sell the crossmember. I like the peace of mind that this is a reversible option, even though I don't think this truck will ever see stock again.
Max
Max's bagged 81
Old 03-28-2012, 09:57 AM   #207
luifer76
luifer76's Avatar
cool glad to see you getting some work done on the truck bro looking good....
Old 03-28-2012, 12:02 PM   #208
made2drag
made2drag's Avatar
great idea! if you had to sell it one day, no one would ever know it was sectioned....i dont think you'd sell it after all this work though. and i wouldnt blame you.....sweet truck, you've got skills man, keep the pics coming!
made2drag is offline   Reply With Quote
Old 03-30-2012, 12:57 AM   #209
maxxxy
maxxxy's Avatar
I took the crossmember to the car wash and removed about 5 lbs of grime! Lol
Then I tried out my $12 sandblaster from Attwoods. It did pretty great for the price. It took the old paint right off. Though it had trouble getting the surface rust off, and couldn't remove dirt or grime at all. But overall it works. Then I drew on all my marks so it's ready to cut and weld! I'm gonna wait til early next week when this guy is gonna help me use his plasma cutter.
Max
Max's bagged 81
Old 04-02-2012, 10:26 AM   #210
made2drag
made2drag's Avatar
dude, your accomplishing a ton of complicated mods! i wish i was brave enough to section mine. great progress, keep us updated with pics. what color are you going with on the truck?
Old 04-02-2012, 10:32 AM   #211
mineralgrey01gt
This build is coming along nicely. Great work man, wish I had those skills
Old 04-03-2012, 10:04 AM   #212
luifer76
luifer76's Avatar
looking good maxxxy... keep them pics coming...
Old 04-05-2012, 04:23 PM   #213
maxxxy
maxxxy's Avatar
Got something in the mail today!
Max
Max's bagged 81
Old 04-05-2012, 07:44 PM   #214
luifer76
luifer76's Avatar
nice!...
Old 04-13-2012, 07:32 PM   #215
maxxxy
maxxxy's Avatar
Thanks!
I guess it's too late to turn back now!!
Max
Max's bagged 81
Old 04-13-2012, 08:12 PM   #216
baclay9
I don't know anything about this stuff so could you explain something to me? How is this going to allow you to get lower. Shouldn't the bottom of the crossmember have been brought up not the top brought down? I'm just not seeing it I guess...
baclay9 is offline   Reply With Quote
Old 04-13-2012, 09:15 PM   #217
joe231
joe231's Avatar
Bringing the top down brings the bottom up in relation to the frame
The piece cut down is where the frame sits on the crossmember so this brings all the suspension higher which lowers the truck...
CHEVY ONLY
Old 04-13-2012, 09:33 PM   #218
maxxxy
maxxxy's Avatar
The three bolt holes on the outside on each side is the surface that bolts to the bottom of the frame. Moving that section down will allow you to slide the entire assembly up on the frame rails.
Max
Max's bagged 81
Old 04-13-2012, 10:01 PM   #219
baclay9
I see it now. Thanks for pointing that out. I just couldn't put it together.
Old 05-01-2012, 10:24 PM   #220
maxxxy
maxxxy's Avatar
Got my crossmember all welded up!! It's all welded then I ground down all the welds and it looks pretty good.*
The first picture is of some reinforcement I welded into the bottom to better support a jack.
Max
Max's bagged 81
Old 05-01-2012, 10:58 PM   #221
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the crossmember Max. Lot of time and work but I'm sure it'll be worth it to you.
mcbassin is online now   Reply With Quote
Old 05-01-2012, 11:49 PM   #222
mcboomport
mcboomport's Avatar
Very nice job!
mcboomport is offline   Reply With Quote
Old 05-02-2012, 02:06 AM   #223
Nobaddaze
Nobaddaze's Avatar
That x-member is looking awesome man!!! Excellent work.
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 05-03-2012, 11:34 PM   #224
broey
Square
broey's Avatar
awesome work on the pancake!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-15-2012, 12:35 AM   #225
maxxxy
maxxxy's Avatar
Thanks guys! I appreciate it. The crossmember took a lot of work but hopefully now I won't drag my lca's off! Lol
Now I've run into a different dilemma, my crossmember won't fit into my sandblasting cabinet!!
Max
Max's bagged 81
1981, bagged, c10, custom, oklahoma
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
