Old 07-27-2010, 03:16 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Engine mount adapter options
Please keep this thread specific to options available for engine mounting.
I'll start off by posting measurements and diagrams for the least expensive option: adapter plates. These plates will bolt to the LS block, and allow you to use the factory mounts that were on your SBC/BBC block, and bolt them up to the LS block.
The first diagram is a comparison of the mounting boss location on both the SBC/BBC and the LS blocks. RED is the LS mounting pattern, BLUE is the SBC/BBC pattern.
The measurements are taken from the machined bellhousing flange on the back of the block, where the transmission bolts to. From there, we measure forward to:
1] The rear bolt holes on the LS pattern, and
2] The center, or lower bolt hole of the SBC/BBC pattern.
Of the following three adapter plates in the drawing, numbers 2 and 3 are the most common.
The plates run from around $25 for 1/4" steel, up to $160 for polished aluminum. If you have access to some scrap 5/16" x 4.25" flat bar or 5/16" plate and you have a drill and a a tap & die set, they are very simple to make.
Here are the dimensions for each of the mounting configurations:
(As viewed on the drivers side of the block)
From MY experience, #2 worked best for the 73-87/91. Let me describe my original setup:
1985 GMC 1/2 ton SWB 2wd. 305/TH350C. The TH350 had a 9" tailhousing.
By using the #2 plate, all I had to do to mount the transmission (a 4L60E) was slide the trans crossmember about 2" and drill a couple holes on each side. Easy stuff.
These plates put everything in a position to where the shifter linkage was in the proper place, and the driveshaft installed without modification. I am using a mechanical clutch fan, and it sits centered front to rear, as well as up and down, within the fan shroud.
The one issue with using the #2 plates comes when you are going to use the LS's AC compressor in it's original low location. Here is the problem I ran into:
Basically, the forward ear of the adapter plate interfered with the compressor bracket. The green triangle is where the clam shell mount from the old SBC was supposed to go. I determined that moving it to the location of the red triangle would solve the problem. Then cut the excess off at the white line. Essentially, I would be modifying the #2 type plate to be just like a #3 plate.
Now everything will fit:
Then I added an extension to the engine stand so that the rubber mount would have something to bolt to:
Another option would be to add a bracket to the crossmember, and move the engine stand back about 2". Member menace121978 did this with his. He welded a piece to the crossmember. You might be able to do this with a piece of angle iron that is bolted to the crossmember as well:
Here are a few guides to use if you plan on making your own adapter plates:
Comparing the right side plate for use with and without the LS AC compressor:
Car Shop, $45.95
http://carshop.carshopinc.com/produc...id/86959/LS1GM
Swaptech multi-position plates, $99.95
http://tpiparts.net/inc/sdetail/16936
Trans Dapt through Year One, $65.95
http://www.yearone.com/serverfiles/f...hid=613AA79244
Pacific Fabrication, 4x4 crossmembers/mounts. No other info on them other than these pics:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-27-2010, 03:51 PM   #2
glock35ipsc
Re: Engine mount adapter options
Other options include a kit from BRP Muscle Rods that includes new engine stands and block mounts, transmission crossmember and mount, and mounting hardware.
$489.00
67-72: http://www.brphotrods.com/mm5/mercha...gory_Code=CNV9
73-87: http://www.brphotrods.com/mm5/mercha...ory_Code=CNV10
88-98: http://www.brphotrods.com/mm5/mercha...ory_Code=CNV11
Bob
Old 07-27-2010, 04:01 PM   #3
glock35ipsc
Early Classic Enterprises has a kit as well that incluses rubber mounts, hardware, and appears to include stands. It is listed as a 63-72 kit.
$219.00
Go to http://www.earlyclassic.com/catalog....gory=New+Items and look for the kit on this page, or search for part number #911-GenIII.
Bob
Old 07-27-2010, 06:18 PM   #4
menace121978
menace121978's Avatar
Great job Bob nice list of options there!
just something to keep in mind when picking which option your going to take... the adaptor plates modded like above (Fred Mod) have been proven that you CAN use the factory a/c compressor in the factory location on the LS engine. no need to run a high mount system with brackets, etc. etc...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-27-2010, 07:27 PM   #5
glock35ipsc
Yeah, I guess I left that important little tidbit out!
AC compressor in it original location, no frame notching, and no aftermarket AC relocation kits required.
Bob
Old 08-06-2010, 02:48 PM   #6
foamypirate
foamypirate's Avatar
Good info, Bob! Thanks!
foamypirate is offline   Reply With Quote
Old 08-06-2010, 06:32 PM   #7
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
How about some info on a way to use Corvette mounts? I think they might give a little bit more room for exhaust.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 08-23-2010, 12:30 AM   #8
eagleuh1
eagleuh1's Avatar
Glock35IPSC, where'd you get those AC compressor hose ends that are bolted to the compressor? I'd like something like that. Thanks.
eagleuh1 is offline   Reply With Quote
Old 08-23-2010, 05:44 AM   #9
menace121978
http://docsblocks.com/search.asp?pg=...=&stype=&scat=
"Dennis the Menace"
Old 08-23-2010, 10:29 PM   #10
glock35ipsc
Thanks brotha!
Bob
Old 08-24-2010, 05:48 AM   #11
67C10BUB
67C10BUB's Avatar
Thanks for the info. I am currently working on putting a gen 4 5.3 in my 1968 SWB. I think I will go with the ECE system. Does anyone know if the compressor hits with these?
67C10BUB is offline   Reply With Quote
Old 09-18-2010, 02:39 PM   #12
Vandals909
Anyone know the answer to 67C10BUB's question?
Vandals909 is offline   Reply With Quote
Old 09-18-2010, 03:07 PM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Not sure, but depending on what your setup is, the ECE kit may move the motor forward some from where it originally was. Its a very nice kit and everything fit well...I even installed the motor in the frame by myself. I have an ECE kit I've decided not to use. PM me if interested in it. I'm wanting my motor as far back as I can get it, which this kit doesn't do.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'16 Kia Sorento - wife's econo-driver
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-20-2010, 03:12 PM   #14
low_84_inchaska
low_84_inchaska's Avatar
i used the dirtydingo mounts from dirtydingo dotcom
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 10-02-2010, 06:36 PM   #15
74project
hello Sir~
Im having trouble finding out if I my cross member will be in the way with the 5.3 in a 4x4? I found the right mounts through dirty dingo that im going to get but there is still alot of things that are holding me up. If you ever come to vegas email me.
74project is offline   Reply With Quote
Old 10-19-2010, 11:51 PM   #16
85burb
85burb's Avatar
Did the dirtydingo mount keep the engine in factory location i can not look at the pic.
85 chevy k10 suburban LQ4
91 chevy c10 suburban
1964 Vw beetle
1970 vw beetle
2015 Fiat 500 sport (wifes DD)
2006 Chevy 1500 crew cab 5.3
2003 GMC Sierra rcsb 5.3
85burb is offline   Reply With Quote
Old 10-21-2010, 05:49 AM   #17
67C10BUB
67C10BUB's Avatar
I went with the ECE kit and the AC compressor does clear the frame. See my build thread for specifics.
67 5.3L Build
Old 11-17-2010, 10:57 AM   #18
RocketKing
RocketKing's Avatar
These are 6 cyl mounts in the rear holes on the frame. I used the same adapters as glock and trimmed the passenger side in order to make the A/C work. We added 2" of extra metal on the mount and then redrilled the new hole 1 3/4" from the original. Thought you might like the photos and thanks glock for the ideas!
backside
clearance
with A/C
Rex
RocketKing is offline   Reply With Quote
Old 12-11-2010, 08:39 PM   #19
Critter
Future TOTM Winner
Critter's Avatar
Anybody ever used these?
I think the adjustable aspect of it would be nice for me. I plan leave my np205 in place and work forward from there with my nv4500 and LQ4 so I'm not exactly sure where everything will fall. My calculations show it will fall somewhere in the realm of all the adapters posted above but I'm not 100% positive where.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-12-2010, 02:18 AM   #20
85burb
85burb's Avatar
I am using these ones from dirty dingo. They say they are made for 73-87 trucks. They say 2 inches back and one inch forward of factory location. I hope to paint and install and mesure mine maybe tomarrow. They also raise the engine 1/2 inch too.
1964 Vw beetle
1970 vw beetle
Old 12-12-2010, 10:38 PM   #21
85burb
85burb's Avatar
Here they are installed will get measurements next week.
1964 Vw beetle
1970 vw beetle
Old 12-29-2010, 03:23 PM   #22
shenk10
shenk10's Avatar
So which adapter plates do you guys think would be the best for my setup. I am not going to have the ac compressor and would like the engine in the original location. I am also going to run electric fans so I'm not worried about the mech. fan either. For glock and dennis are the modifications to the crossmember just so you can run the ac compressor in the factory location?
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 01-03-2011, 09:11 PM   #23
1BadAction
1BadAction's Avatar
Burb, Looks nice, how do they look installed?
1BadAction is offline   Reply With Quote
Old 01-03-2011, 09:58 PM   #24
85burb
85burb's Avatar
I put them all the way forward and seems to me that it is within a 1/8 inch of factory sbc position. I had thoughts of flipping them around and checking that way. Not sure if that would work but seems to me 1/8 in going to be just fine. Dont acctually remember what way it is off tho.
1964 Vw beetle
1970 vw beetle
Old 01-13-2011, 12:16 PM   #25
mcbassin
Still Learning
mcbassin's Avatar
Thanks Bob for putting this thread together and everyone else that contributes to it.
I found some good info here!
mcbassin is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
