Old 08-20-2010, 07:48 AM   #1
motornut
78K & 79C Jimmys
motornut's Avatar
Death of a Plainsman
Well this truck just gets more interesting.But i figure i'll start a thread as i'm gonna start doin work on the truck,
John http://www.youtube.com/user/TheMotornut
1978 Suburban4X2-hit while parked RIPzez
1978 GMCJimmy4X4-350/203http://67-72chevytrucks.com/vboard/s...=421767&page=4
1979 GMCJimmy4X2-305/350http://67-72chevytrucks.com/vboard/s...=1#post5200107
1987 Suburban4X4-writeoff hit while parked RIPzez
1988 Suburban4X4-writeoff hit while parked RIPzez
1989 Suburban4X2 - square igloo/SOLD
2002 Fleetwood
2005 Malibu hit by City bus,2nd time a write-off(01/15/16)
2010 Dodge Van-writeoff hit while parked(01/14/15)
Now I just buy shorter trucks!
Love em low,but get me higher
motornut is offline   Reply With Quote
Old 08-20-2010, 01:21 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 1985 TBI Canadian Plainsman
So far fixed electrical stuff,rear end,new deer lights ,got 6 lights for the roof but went with the 4 on bumper after seeing some get torn off.Seats back broke,i fixed them,they broke,i switched them,tubes are to thin.Decided blue will do for now.
2002 Fleetwood
Old 08-20-2010, 01:26 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
had to weld in the inner brackets from my 89 for the front buckets
2002 Fleetwood
Old 08-20-2010, 07:54 PM   #4
bharrison1
bharrison1's Avatar
uhhhh nice project but that kinda looks like a dead body in the trash bag behind the dog !!!ya gotta hide that stuff before ya take the pictures man ha ha!!
bharrison1 is offline   Reply With Quote
Old 08-24-2010, 11:30 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
It's ok none of my ex's are missing lol
2002 Fleetwood
Old 08-24-2010, 02:32 PM   #6
bharrison1
bharrison1's Avatar
ha ha good
Old 08-24-2010, 04:31 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
? Where would someone find the serial numbers on a frame of this truck,and i've tried to get the number off the back of the block......can't get close tried tinfoil.....any other tricks
2002 Fleetwood
Old 08-24-2010, 10:38 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
When i bought this truck i never thought about the tbi other than i was the same as my 87 4x4 sub.It smokes when it starts after sitting a week or so.....till it warms up.i've been told that this truck should not have a tbi in it.It was ordered from the factory by Vacation Customs from Texas with 1 rpo"rear seat not desired"2nd row.the seats that came were all custom made.......anybody else seen a rather factory looking tbi in a 85
2002 Fleetwood
Old 08-24-2010, 11:28 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
What is the 8th digit of the VIN number? If it is a K then this is a TBI 350 from the factory.
67 C10 Suburban The Ant Farm http://67-72chevytrucks.com/vboard/s...82#post6095882
69 C10 shortbed stepside project 45 ACP http://67-72chevytrucks.com/vboard/s...13#post4899613
69 K20 lwb TBI 400 4L60E NP208 square body chassis http://67-72chevytrucks.com/vboard/s...=1#post3955165
68 Camaro SS / RS 500hp 439 inch big block T-400 http://67-72chevytrucks.com/vboard/s...d.php?t=528952
79 Malibu TPI 350 4L60 3.73 gears
68 TT is offline   Reply With Quote
Old 08-25-2010, 06:31 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
W no it just looks factory like my 87 it's registered as a C20 ,this is why i wana know where to check the frame #s
2002 Fleetwood
Old 08-25-2010, 08:57 AM   #11
68 TT
68 TT's Avatar
Top side of the driver side frame rail right about where the steering gear box is should be a partial VIN that you can get to easily. Could be the other side instead, not enough caffeine yet this morning.
Old 08-25-2010, 12:25 PM   #12
68 TT
68 TT's Avatar
W is a 454 VIN so it looks like somebody swapped out the drivetrain, most likely the whole chassis as it should be 8-lug too if it is registered as a C20.
Who knows what was going on in this things history but as long as it works and has a clean title it doesn't really matter.
Someone may have bought it as a drivetrain donor to convert their truck to 3/4-ton and upgrade to a 454 too and just put all their parts into the Suburban to make it whole again and get some of their money back. I have seriously considered doing this with my 78 K20 to get EFI and overdrive plus more street friendly gearing.
Old 08-25-2010, 04:31 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
visited a few gm truck dealers round here today told shhh.Customs musta missed that but they have seen it before from custom conversion places or aftermarket setups with the year being even earlier but not a C for a K ,but to consider myself lucky as the "etest exemptions finish up here with the use of carbs(86),and are still required with TBI(87)"and they cannot reccomend bypassing any smoggy"but that tbi is better then carb".............................................after using/breaking the nice custom seat backs i would switch the seat around to another and repair it later, but with not all that thick tubing "if i could rebuild the fronts and put a catch/ratchet on both sides and a few more springs",till i sat on the factory blues ,much better now i'll just find factory brown...........the glue holding the house carpet they used baked and burnt explains that funny burning smell,but thats a tall hump my 89 short hump carpet didn't fit............and it had a rpo codes for front bench/ and rear seat not desired,so no belts or seat catches when they flip back or supports to lean forward,used 89 stuff cleaned up.all front/rear custom seat bases were drilled where needed and bolted threw the rear support factory holes,wait till ya see the third row attach with no belts even anywhere a sign ,if a part was not required by rpo i found a bolt tho on the sides,and belt bolts but the installed lappers were again with washers and bolts .......
2002 Fleetwood
Old 08-26-2010, 10:14 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
wondering if these marks are norm,i can see writing says eng change 51?Can't remember if my blues had all of those,i know it had some.check out the 3rd seat hookup.
2002 Fleetwood
Old 09-01-2010, 05:43 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
So it would seem a vin switch has occured,i can't risk investing in it till this is cleared up.Called P.O. said thats what he bought 4x4 never questioned it till getting safety done to sell it, garage ordered by vin and tuneup etc were wrong.Vin says 454 3/4 ton..........truck is 4X4 1/2 ton.Went to three gm dealers told no numbers on frame/yes there is hard to find they have an wide area to look.one told me just call gm they will do it......after giving my vin ,name ,phone#,said there is #s but only gm trained can find them and i would threw them setup appointment to have the numbers checked at my local dealer.....yup ok i'll get right on that
2002 Fleetwood
Old 09-03-2010, 07:21 AM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
yup we got vin issues here,when i bought the truck i got a used info package,with 3 other owners.the second prev owner was called bla bla bla "no the truck wasn't gold"says the wife i'll get my husband to call you back tonight.........now 48 hours no call back
this vin plate sure looks replaced,and someone told me this sticker should have a vin in it?
2002 Fleetwood
Old 09-03-2010, 08:56 AM   #17
Keith Seymore
Keith Seymore's Avatar
The VIN plate is attached with rosette style rivets, which normally is a good sign (because they are not readily available).
VIN decodes as follows:
1 - Country of origin - USA (make sense, since all Suburbans were built in Flint MI)
G - General Motors
8 - Seems like this should be a "C" for Chevrolet
G - Brake system 8100 - 9000
C - series, 2wd
2 - 3/4 ton
6 - Suburban
W - engine code (I didn't check)
4 - check digit (randomly calculated value)
F - model year, 1985
F - Assembly plant - Flint MI
numerical portion of VIN corresponds to build sequence number
The sticker has been messed with; pulled off and replaced. You can tell because the "typed" notes should be legible, and yes it should show the same VIN as above.
To answer your earlier question: no TBIs on fullsize trucks in '85. We've had this discussion before and I can answer with confidence, because I 've had conversation with the GM Powertrain guys who did the calibrations for these TBI engines. They have said no TBIs until 1987 model year.
K
Chevrolet Flint Assembly
1979-1986
1986 - Feb 2019
Old 09-03-2010, 09:08 AM   #18
Keith Seymore
Those marks are specific to the door trim panel. Date codes, part numbers, mold cavity numbers, etc specific to that base part.
In this context "Eng Change" means that the door trim panel had undergone some Engineering Change (almost all parts do) and is documenting the part change level. Could have been a hole size, trim edge, etc.
It is not "Engine Change" if that's what you were thinking.
K
1979-1986
1986 - Feb 2019
Old 09-03-2010, 09:15 AM   #19
Keith Seymore
I believe that's the previous generation of trucks (67-72).
For these, IIRC - it's on the horizontal top portion of the frame rail, in the vicinity of under the second row seat and I want to say drivers' side (although could be passenger side). Probably gonna take a mirror to see it or ideally take the body off.
K
1979-1986
1986 - Feb 2019
Old 09-03-2010, 02:49 PM   #20
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
yeap passenger side frame rail second row seats
Thomas
1984 Chevrolet C-30 Big Dooley Choo Choo Custom 6.2
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 09-03-2010, 05:54 PM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
got appointment wensday morning at my gm dealer ,or the police,lol or a frame off body job lol will be performed in that order ,if i still have the truck..........found an 83 for sale 2000........but its 2x,but gona go clean out the tool box
2002 Fleetwood
Old 09-03-2010, 06:34 PM   #22
Skratch
Skratch's Avatar
Just a thought as I went through something similar with my truck.
It is very possible that the tub with the VIN is from a different truck all together. And that it was a body swap job that never had all the proper paper work completed on.
I have a truck that was bought as an 87 4wd 1/2t . . . however the frame VIN and body VIN didn't match. But I still got a clean title.
It has an 88 1/2t 4wd frame and driveline, but an 87 tub and the title was for the 87.
Now I have an 89 3/4t 2wd tub on it with the 88 1/2t 4wd frame and driveline.
It can be a serious headache to get it all sorted out and get a clean title . . . I opted for a slightly less difficult procedure and have a clean '00 self assembled title now . . . which allowed me to register it and insure it as normal.
If it ain't broke, then I haven't fixed it yet!
'86 Fiero SE 2M6 (undergoing a Northstar swap)
'87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks)
'90 3/4t 2wd Suburban (Tow Rig)
'94 3/4t 4wd G20 Van (Toasted tranny and rusted)
'96 Deville
Skratch is offline   Reply With Quote
Old 09-04-2010, 06:43 AM   #23
tobiahr
tobiahr's Avatar
If the truck was a Texas native the title stays with the body VIN and a frame and engine swap would not change the title in any way. I did a full body swap on a vehicle and the shop I went to cut and welded the dash into the new body to transfer the VIN.
tobiahr is offline   Reply With Quote
Old 09-07-2010, 11:16 AM   #24
motornut
78K & 79C Jimmys
motornut's Avatar
i have come to realize this is not likely a swap other then the vin plate.the truck was never 2 wheel,or had a 454,or was a 3/4 ton.What i was told is that it is not legal (here in Ont .Ca)to have it regestered to carry more weight then it should.It is still regestered 3/4 ton but only a 1/2 ton,4X4.I was told this truck could be seized on the road or crossing the border as things don't match.With the door Vin # missing and the rpo sticker with the vin removed
2002 Fleetwood
Old 09-07-2010, 10:52 PM   #25
motornut
78K & 79C Jimmys
motornut's Avatar
Thanks ,could it be kept the with the same vin would it be done ok in the USA.
Someone said GM can reissue vins?
lol if it works out maybe this will be the first and only one.
Being ordered for a conversion from the factory.
i just didn't worry bout the engine change etc till NOW
Hope this an't buddys first and last ride
2002 Fleetwood
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
