Old 08-27-2010, 12:28 AM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Wiring diagram for power seats and heaters
Hi all, I'm looking for the wiring diagram for a 99-07 set of Tahoe seats. I'm needing to figure out the seat heater wiring and also need the part number for the terminals inside the connector. Thanks for any help.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer (Are they ever really done?)
2005 Malibu
2011 K1500 Suburban
2010 2SS/RS Orange Camaro
red71cheyenne is offline   Reply With Quote
Old 08-27-2010, 08:26 PM   #2
truckdude239
truckdude239's Avatar
Re: Wiring diagram for power seats and heaters
driver side for the heated part
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-27-2010, 08:28 PM   #3
truckdude239
passgaer side heat
David fuller
Old 08-27-2010, 08:28 PM   #4
truckdude239
drive side move
David fuller
Old 08-27-2010, 08:29 PM   #5
truckdude239
passager side move
David fuller
Old 08-27-2010, 10:45 PM   #6
red71cheyenne
Back in the sticks
Awesome!!! Thanks very much!
2005 Malibu
2011 K1500 Suburban
Old 08-29-2010, 01:53 PM   #7
red71cheyenne
Back in the sticks
Ok, this is a dumb question, but where is the heater on off switch located? Is it on the seat or dash? Thanks, Jeff.
2005 Malibu
2011 K1500 Suburban
Old 08-29-2010, 03:09 PM   #8
truckdude239
probley in the dash
David fuller
Old 08-29-2010, 05:58 PM   #9
clinebarger
On my 04 Chevy 1500 there on the door panel right above the window switches.
clinebarger is offline   Reply With Quote
Old 08-30-2010, 07:42 PM   #10
red71cheyenne
Back in the sticks
Cline, could I get a pic of what yours look like? There are a few choices out there to choose from and I want something close. Thanks, Jeff.
2005 Malibu
2011 K1500 Suburban
Old 08-30-2010, 07:43 PM   #11
red71cheyenne
Back in the sticks
Originally Posted by truckdude239 View Post
probley in the dash
I wondered if some were in the dash. The only pics I could find of them there was in an Avalanche or something.
2005 Malibu
2011 K1500 Suburban
Old 08-30-2010, 08:20 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
I have had several heated seats and they are all in the door panel.Heres the set up in my wife's 07 Denali
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-30-2010, 11:03 PM   #13
red71cheyenne
Back in the sticks
Thanks for the pic. The ones in my Camaro are on the dash. They look different than that, just hi/lo settings in one button.
2005 Malibu
2011 K1500 Suburban
Old 10-18-2010, 10:35 PM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Anyone know where the heater relay is? I'm guessing up on the inner fender in the engine compartment. Also, where is the Thermistor? My guess is in the seat itself. I purchased a set of 03 Tahoe seats off ebay about 3 years ago, and I hooked up the movement but not the heat. I did get the memory and heat controls with the seats too.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-04-2013, 05:25 PM   #15
RED 1970
Sorry for bringing up an old thread but I'm having issues with these exact seats. I purchased them to go in an 89 K5 Blazer. I have the power hooked up but haven't figured out the heat yet.
I have the seats only. Is there anything special about the switch for the seats? From the gauge of the wire used in the 16-pin connector I'm guessing the seats will get the power from a relay in the seat, and there is only the one power source.
Is it as simple as applying a 12v signal to one of the pins to trigger the seat heaters? Is there anything else I need to add?
Here's the 16-pin connector:
RED 1970 is offline   Reply With Quote
Old 01-04-2013, 08:03 PM   #16
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I only have the movement hooked up on mine.
Old 01-22-2013, 12:17 AM   #17
cpetersen
cpetersen's Avatar
I have a 06 with the memory seats. Everything goes through the switch on the door. I lost movement in the driver seat, it stopped about half way back. I can't even get to the rear bolts to get the seat out to check anything out. Anybody know how to over ride the system for the seats? I think i lost a module. The module controls the pass seat heater also, we changed the switch in the door it didnt help. We lost the heaters in both seats. Im going to hate to take it to chevy. I have a feeling it could get costly. I would be curious to see where the relays are too?
cpetersen is offline   Reply With Quote
Old 01-23-2013, 08:10 PM   #18
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
If you can get to the wiring connector pull it apart and put 12v to the orange and black wires. I think. I don't remember which color is for the power movement. Use a battery charger with some wires for leads, or use a cordless drill or other power tool battery 16v or less to touch to wires in the connector under seat. Do not touch the yellow wire with power!! Yellow is for airbag.
Old 01-25-2013, 12:42 PM   #19
cpetersen
cpetersen's Avatar
Thanks for the info. I will try it tomorrow, hopefully i can get to the connector. LOL, its probably on the backside. Hopefully this will help the guy who started the thread too. If i can get the seat moved i can get to the rear nuts. I found a module on GMdirect for $367., If i buy it from the dealer it $507...If i have them do it it $90 for the scan and $165 a hour to fix it. I'm also going to test the relays also.
Old 01-25-2013, 01:02 PM   #20
red71cheyenne
Back in the sticks
Yep, orange and black are movement power. That is all I have done at this point, maybe someday I'll get the door switches and heaters hooked up!
2005 Malibu
2011 K1500 Suburban
Old 01-25-2013, 01:22 PM   #21
cpetersen
cpetersen's Avatar
I may cover the yellow with something, or things could get exciting.
Old 01-25-2013, 07:46 PM   #22
cpetersen
cpetersen's Avatar
I took it to Chevy to have it body scanned. It ended up having 2 clips broke the main harness. of course the orange and the black one. Funny thing was he had to reflash the module because it was all over the place it didnt know what to do? One of the heaters started working and the other wasnt. Raised a red flag with the mech. He said every function goes through the module including the heater functionand there are relays for both seats in the seats. He said sometimes the seats come unplugged that the module will need to be reflashed, which means reprogrammed. Ummmm, might be something to look at?
Old 06-13-2016, 10:34 AM   #23
Rockbottom78
Rockbottom78's Avatar
Hey fellas, on this topic- does anyone know how to tell if the seats I bought are heated or not? Sounds like something I should have looked into when I bought but the guy didn't know anything about them and for $60 I just took them and ran haha. They are leather with all electric control (lumbar also) looks like drivers seat has an 8 pin and passenger has a 4 pin harness. Thanks!
___________________________________________
78' c10 custom deluxe step side. Bagged. 5.3L/4L60E.
07' 1500hd crew cab puller.
Rockbottom78 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
