Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-16-2010, 06:05 PM   #1
ebfabman
butt fit butt welded marker lamp install....
butt together fit flush with quarter panel.
Hope you enjoy the pics........
ebfabman is offline   Reply With Quote
Old 09-16-2010, 06:16 PM   #2
paintpyro
paintpyro's Avatar
Re: butt fit butt welded marker lamp install....
Crap Earl, You are killing me. Are you using the scrap COT wings for all this stuff? lol
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 09-16-2010, 07:10 PM   #3
ebfabman
he he he..... got a whole pile of em over here...........
Old 09-16-2010, 07:14 PM   #4
ebfabman
a few more....
Old 09-16-2010, 08:20 PM   #5
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Very nice!
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 09-16-2010, 09:08 PM   #6
E-tek Restorations
Very nice!
Couple questions if I may.... What are the cleeko's holding - is that a patch panel? Hard to see the edge...
Is the tail light panel seperate from the quarter?
What's with the gap at the wheel well?
Did you clean off the burn/heat marks after "spot" welding the marker for the photo? Too clean after welding!
Thanks for posting it all!
E-tek Restorations is offline   Reply With Quote
Old 09-16-2010, 10:12 PM   #7
ebfabman
This is a repair on a 70 suburban. Quarters are not available, at least at the moment. The quarter is made from parts that are available, rear tail light, lower rear quarter, and a door skin. The clecos are holding the quarter in place for mock up so the marker lamp placement is correct. The gaps you see are where the old damaged quarter was cut. Those places will be made up and installed before the replacement quarter is installed. The new quarter will also be flush butt fit, no gap, and butt welded. I'll put pics on here for you to see.
thanks.....eb
Old 09-17-2010, 12:35 AM   #8
Permafrost
Permafrost's Avatar
Very Clean!
Nothing like piecing something together that isn't available whole.
eb,
from what I have seen in this post and others that you've shared; you are a remarkable fabricator!
Too Many Projects:
'50 GMC
'62 Nova drop-top
'68 K10
'68 Chevelle SS
Permafrost is offline   Reply With Quote
Old 09-17-2010, 11:42 AM   #9
primrrd
primrrd's Avatar
Nice work!
primrrd is offline   Reply With Quote
Old 09-17-2010, 01:54 PM   #10
ebfabman
thanks for looking and the positive comments........eb
Old 09-17-2010, 10:02 PM   #11
chas350
As always, nice work Earl!
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 09-19-2010, 04:34 PM   #12
kev2809
low n' slo
kev2809's Avatar
man thats some amazing welding! nice work..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-20-2010, 09:16 AM   #13
tp85
hi earl,
just a question for the master (you)...
the gaps you used seem very small. do you normally use such small gap? or was this just because it was only a lamp mount?
i've been doing my floor pans, rockers, a/b pillar, etc. the past few months, and I normally shoot for a 1/16" gap or so for good weld penetration.
if i run into a gap which is too small, i normally run by body reciprocating saw down the joint. the blade thickness normally makes the gap about right, or sometimes i apply a little force sideways while cutting to make the gap larger.
thanks,
tom
tp85 is offline   Reply With Quote
Old 09-20-2010, 09:37 AM   #14
JimmyFloyd
Going to have to watch this thread. looks like some good information in here.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 09-20-2010, 11:24 AM   #15
ebfabman
No gap needed for penetration. We are welding sheetmetal. Try this, run a small short tack on a piece of scrap. Turn it over and look at it. Did the weld penetrate? How much penetration do you need on thin sheetmetal body panels?
Please don't take me to try to be a smart azz, I don't want to come across that way. I see a lot of guys sort of being lead by by what they're told or what they read and not putting the thought and time in on really how they can improve.
If you read the description of what those little panel camps do, they always say "so and so" gap for good penetration.....well if there is gap and you're filling that gap with weld, you aren't "penetrating" right? I mean, yes you will need some "penetration" to fuse the material together but worry about penetration when you are welding structural stuff and don't worry so much about what it looks like.
Lets stay focused on sheetmetal. I think you should strive for "appearance" as well as a good solid joint. I feel like if you try to concentrate on keeping your work very neat and clean it also helps to control the movement of the panels as you weld. Remember that when you weld the heat expands things, when it cools it contracts but the contraction is more than the expansion. So if there is a gap, you weld across it, with the contraction won't the gap get smaller? If we are concerned with appearance then we will have to deal with the shrinking gap.
Anyway, I'm no expert. I don't even know any metallurgy guys. I do what works for me. I worry about what things look like as well as how they perform. I want to be the best I can be, so I don't care so much what others say. I will continue to refine my skill so that my goals are meant then set new ones.
Please keep practicing and keep trying different things. Set goals. Always work toward getting better and don't compromise.
I am here if any of you need help, but just remember I can only tell you what works for me.
Again, thanks for looking. I will be putting more pics on here as I get things done.....eb
Old 09-20-2010, 02:36 PM   #16
tp85
great info...thanks. i think i am making my gaps too large.
i see what you are saying. so do you aim for no gap or maybe a gap about equal with the mig wire (~.025")?
tom
Old 09-20-2010, 03:24 PM   #17
ebfabman
tom, try several ways and see what works best for you.
ps......show us some pics of your work...might get input from some members, could be useful......eb
Old 09-20-2010, 03:52 PM   #18
Richard H.
Spanked once
Richard H.'s Avatar
tom
With what Efab is saying no matter what your welding with.. stick or mig , the metal will pull or "shrink" because the actual weld does when it cools. If I make a goof cut (to wide) I use removable small strips of metal to keep the gap near my tacks.If it is good and clean ,and your heat is right little to no gap is good.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 09-20-2010, 05:08 PM   #19
tp85
I'll try to get some pic. Floor pan and four bolt area went pretty well...more concerned about body panels.
Old 09-21-2010, 05:20 PM   #20
dfwright
dfwright's Avatar
I would love to hear about your grinding/cleaning process. What do you use to grind down the welds so clean and smooth, how do you prep the metal prior to welding. What do you use to clean those spot welds so clean before grinding.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-21-2010, 07:12 PM   #21
ebfabman
here is a small update should have more tomorrow if I don't get attacked....
Old 09-21-2010, 08:43 PM   #22
kev2809
low n' slo
kev2809's Avatar
i would like to know these as well, mine didnt seem to come out this clean! lol
also, if your not gonna get ready to body work and paint that area right away, what do you spray it with to protect it until you do?
-_--_--_ _________
Old 09-22-2010, 09:09 AM   #23
ebfabman
Thats not hard at all. Its a personal preferance thing. Something that may help, think about gemstones are finished.
Old 09-22-2010, 11:29 AM   #24
dfwright
dfwright's Avatar
So your methods and materials are a trade secret?
Old 09-22-2010, 11:44 AM   #25
my67chevytruck
Under Construction
my67chevytruck's Avatar
Very nice work! can you share what size mig wire you use?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
butt weld butt welding, metal finishing
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
