Old 09-28-2010, 09:21 PM   #1
xpickup
xpickup's Avatar
1954 Chevy / S10
Hi my name is Shannon , I have been watching this site for a couple years and thought I would put my project on here. My own project is a 1948 Chevy panel, but I am building a couple other projects besides my own. I started with just a rusty cab, put in all the panels. I made the firewall and toe board and the patch panels that they don't make because it's a 54'. Then mounted it on the S10 frame. I then made my own bed to the 54' sizes except raised the bed floor 2 inches and narrowed it 2 inches for the 3 inch wider fenders. mounted all the fenders and hood, the made the roll pan and tail lights, splash aprons and the running boards. Right now I'm mounting the bull nosed grill and making/ mounting the radiator support. Truck will have a SBC, 700R4, And a F*** 8.8 3.73 Posi rear. I t has standard front springs and has Summit 3 inch lower leaf spring for the rear. I'll keep posting pictures as I go.
xpickup is offline   Reply With Quote
Old 10-02-2010, 09:58 PM   #2
xpickup
xpickup's Avatar
Re: 1954 Chevy / S10
I got the grill in. If anybody else is doing a 1954 - S10 conversion it is different than the pre 1953. The lower grill needs to be cut to go around the steering box. I need to start on the radiator support next and the hood fitment. Then make new inner wheel wells.
Old 10-02-2010, 10:23 PM   #3
HALFADIME
Exellent job on the roll pan where did you get the tail light's from.
HALFADIME is offline   Reply With Quote
Old 10-03-2010, 07:46 AM   #4
xpickup
xpickup's Avatar
Halfadime, I made them. It's 1/4 red acrylic with drop ceiling diffuser for the prizmatic reflector and you have use to used a special glue because epoxy will not work. I found out the hard way. That way you can make what ever shape and size you want.
Old 10-03-2010, 08:16 AM   #5
masshole
looking great..fab work is awesome. how did you roll the top of the bedsides like that? keep up the good work.......
masshole is offline   Reply With Quote
Old 10-03-2010, 10:35 AM   #6
xpickup
xpickup's Avatar
Masshole, I used 1 1/2 exhaust tubing and welded it to the 16 gauge sides. You have to really watch your heat so you don't warp it out. I have made 4 beds and have it down to a science. I built one for my son to slept in.
Old 10-03-2010, 11:31 AM   #7
masshole
strong work, that bed is crazy..ask your son if he wants to sell it looks like I will have to try my hand at making one the way you did. THANKS AGAIN for all the pics...oh and slow down will ya, i can't keep up!!!!! lol
Masshole
Old 10-03-2010, 12:19 PM   #8
xpickup
xpickup's Avatar
Masshole, if you need anymore info, sizes, or pictures let me know.
Old 10-05-2010, 01:04 AM   #9
99 to Life
99 to Life's Avatar
Great work, glad to see some serious fabricating. I am sure this one will get some attention.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-05-2010, 01:05 AM   #10
99 to Life
99 to Life's Avatar
me again, dang you are from PA too, hell yeah shout out to the east coast "rust never sleeps"
Old 10-05-2010, 06:13 AM   #11
PRWFAB
PRWFAB's Avatar
Hi x york pa here too truck looks good
PRWFAB is offline   Reply With Quote
Old 10-05-2010, 06:13 AM   #12
xpickup
xpickup's Avatar
99 to Life, good to see someone from PA too, not to many. You are right about the rust. It's good that I love doing sheetmetal work.
Old 10-05-2010, 07:08 AM   #13
Pop's C-10
Pop's C-10's Avatar
nice work
Pop's C-10 is offline   Reply With Quote
Old 10-05-2010, 07:41 AM   #14
xpickup
xpickup's Avatar
PRWFAB, What part of York are you in? I'm outside of Emigsville.
Pop's C-10, Thank you.
Old 10-05-2010, 07:53 AM   #15
PRWFAB
PRWFAB's Avatar
West york close to rutters on rt 30. Work in emigsville
Old 10-05-2010, 08:56 AM   #16
xpickup
xpickup's Avatar
PRWFAB, We'll have to check out each others projects sometime.
Old 10-10-2010, 09:52 PM   #17
xpickup
xpickup's Avatar
Here is the latest pictures. I finally got the radiator support made and mounted. Ended up mounting toward the passenger side so it wouldn't sit too high. The fan will be more to the center of the radiator. The lower part of the grill needed to be notch out. Next will be to make the inner wheel wells and the mounts for the front fenders ( there kinda floating there).The panels also need made to get the air into to radiator up front.
Old 10-10-2010, 09:54 PM   #18
xpickup
xpickup's Avatar
a few more
Old 10-31-2010, 03:43 PM   #19
xpickup
xpickup's Avatar
I got the motor and trans mostly mounted. I have to finish welding the front motor mounts when I pull the motor and clean and paint the frame. I am still working on the trans mount, I still have to fish mouth the 2 back braces and make the flanges and frame mounts. I also have to gusset the trans mount bracket. Found an set of coated hedman headers so they will clear the steering. Also going to put a 8 inch dual diaphragm booster with a vette master cylinder under the floor. Then will be able to finish the floor as soon as I add the power feed to my bead roller. Here's the latest pictures.
Old 11-04-2010, 11:45 AM   #20
Kabwe
Certified Car Nut
Kabwe's Avatar
Really nice work man. love the bed.
Kabwe is offline   Reply With Quote
Old 11-04-2010, 07:51 PM   #21
xpickup
xpickup's Avatar
Kabwe, Thank you.
Got the cross member almost done. Pulled the fuel line out and it leaked gas all over the frame. So no welding on that side tonight. Should have pictures next week. I'm not working on it this weekend. My wife and me are going to the King of Prussia mall to do some Christmas shopping for the weekend . We are going without the kids ( we have 3). We haven't done that since 4 years ago! It is much needed!
Old 11-04-2010, 08:03 PM   #22
Kabwe
Certified Car Nut
Kabwe's Avatar
lol. I know all about that.lol My wife and I call HBO Sunday night shows are date night the kids have to leave us alone.lol I have 2 girls so I know what getting away alone means so have a great time.
Old 11-04-2010, 10:53 PM   #23
enick72
enick72's Avatar
great work, love the bed also.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 11-05-2010, 09:03 AM   #24
xpickup
xpickup's Avatar
Kabwe, We have 2 girls and a boy. We try to movie thing and they still came into the living room. The more you tell to watch there movie I think the more they come in! But they grow up so fast, its hard to believe my oldest is 8 and the youngest is 3. Count down for another 24 hours HAHA.
enick72 Thank you.
Old 11-05-2010, 12:07 PM   #25
OrrieG
OrrieG's Avatar
When we had no money and young kids a group of about half a dozen families formed a babysitting co-op. Every week one of the families was designated as the place to drop your kids on Saturday afternoon if you wanted to. It worked out great. We knew every six weeks we would have a house full of kids, sometimes for the evening, sometimes overnight. We always had lots of games, activities, etc. for them to do. This was in the 70's before laser disc's, vhs and dvd's, but kids expectations were different and we were just a bunch of hippies who let them run wild anyway. Tempe had lots of parks and we only lived a couple of block off campus which afforded lots of opportunity for exploration too. Over the three years we did not injure or loose one kid!
OrrieG is offline   Reply With Quote
