Old 10-04-2010, 12:30 PM   #1
74chevy4x4
74chevy4x4's Avatar
1974 full time 4x4 to 4x2 conversion
Hi Everyone,
I've looked everywhere for information on this but haven't gotten any help. I have a 1974 K20 3/4 ton with fulltime 4-wheel drive that I need to convert to part-time. It's my daily driver and I only get 11 mpg. I was hoping to bump that up just a little.
I bought the Mile Marker 423 Manual Locking Hubs and the 203 Transfer case kit already. I started on Saturday and to my dismay, found that there are studs, washers and nuts holding on the OEM Hub and not holes and bolts for the Mile Marker hub to bolt on. Does anyone know what I need to do to make this work? Do I need to buy different rotors/hubs or what? Please Help! Thanks!!!
74chevy4x4 is offline   Reply With Quote
Old 10-04-2010, 01:46 PM   #2
royo
royo's Avatar
Re: 1974 full time 4x4 to 4x2 conversion
Can you post a pic of the hub?
nickle and dime
royo is offline   Reply With Quote
Old 10-04-2010, 01:49 PM   #3
74chevy4x4
74chevy4x4's Avatar
I'll try a little later. Suffice it to say that instead of bolts threading into the stock hub, there are studs, washers and nuts holding them on. The Mile Marker 423 Hubs have 6 holes that match the rotor hub, but the studs are too short to use the washers and nuts from the stock setup.
Old 10-04-2010, 07:43 PM   #4
royo
royo's Avatar
Wonder if there is a way to replace the studs
Home » 4X4 Locking Hubs » Mile Marker 4X4 Locking Hubs
Product ID: 423
Manufacturer: Mile Marker
Mile Marker #423 Manual Locking Hubs Dana 44 Heavy Duty with 6 Bolt Flange
Mile Marker 4X4 Manual Locking Hubs #423 - Chrome - Fits Heavy Duty Dana 44 axles with external 6 bolt flange. These Hubs fit Chevy, Dodge, International Harvester, Jeep J20 Pickup 1974-1977 (6 Bolt 19 Spline) and Ford 1/2 and 3/4 ton trucks with a Dana 44 HD 19 spline axle and external 6 bolt flange mount.
>> These are the hard to find Heavy Duty hubs that replace worn out Spicer hubs as well as others <<
nickle and dime
Old 10-05-2010, 08:40 AM   #5
74chevy4x4
74chevy4x4's Avatar
My thoughts Exactly. Those are the hubs: Mile Marker 423's. Here are a couple of pics of the stock hubs showing the washers and nuts.
Old 10-05-2010, 12:06 PM   #6
madmopar
This guy has got to be stopped
madmopar's Avatar
why cant you reuse the nuts/washers on the studs with the MM hubs. Is the flange on the mm hub thicker than the stock flange? From the above pics, It doesn't look much different.
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 10-05-2010, 12:12 PM   #7
74chevy4x4
74chevy4x4's Avatar
The base on the new hubs is thicker. The studs aren't long enough.
Old 10-05-2010, 12:55 PM   #8
Adams74Chevy
Adams74Chevy's Avatar
My '73 has the conversion on it from a PO, the hubs are Warn hubs but I'm pretty sure they removed the studs and used bolts of the proper length. I'll have to look this evening when I get home.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 10-05-2010, 06:14 PM   #9
68chevyfuelie
68chevyfuelie's Avatar
You should be fine taking the studs out, and using bolts of the proper length. I believe some Chevy Dana 44's came with bolts holding in the drive flange. Also, Dodge Dana 60's used an external drive flange that was held in place with bolts. Studs are arguable stronger, but on a Dana 44 you're going to break something else before you shear off 6 drive flange/hub bolts. My two cents.
68chevyfuelie is offline   Reply With Quote
Old 12-29-2010, 03:34 PM   #10
74chevy4x4
74chevy4x4's Avatar
Just an update:
First of All, Thanks for all the help everyone! I appreciate it.
I was able to pull the studs and do the mods to the hubs and got the 501 mod done to the NP203 transfer too. Good Stuff, but now I've taken it a step further and swapped the NP203 for an NP208 and attached it to a 700R4...what a PITA! Rebuilt tranny from the local Pick and Pull for 50 bucks(and 600 to rebuild and modify for 4X4), the transfer for 140 bucks and associated TV cable, bracket and crossmember mods...wound up costing me about 1500 :-(
Oh well, now my beast is selectable 4X4 or $X2, AND...it's got an Overdrive Tranny!!! Woo Hoo!
Thaks Again Evryone!
1974 K20 Cheyenne Super, 350ci with Edelbrock Valve Covers, Intake and Carb, COMP CAMs XE268h, Headers from Jeggs, 65K Volt HEI Distributor, Mile Marker Locking Hubs, 700R4 Tranny, NP241C Transfer, A/C, tilt wheel, dual 20 Gal tanks.
2003 Honda VTX-1800C, V&H Big Shots, Kury Hypercharger, grips, pegs, Darkside Goodyear Triple Tread Rear Tire, and Chrome Galor.
2005 Chevy Trailblazer(Momma's Car LoL)
Old 12-31-2010, 09:00 AM   #11
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Not to burst your bubble, but how much gas could you buy for 1500? What is the overall gain in MPG? Sometimes with old technology and carbs miles per gallon isn't always a win-win situation if you know what I mean. Don't get me wrong, I'm all for fuel savings if the price is right
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 12-31-2010, 03:11 PM   #12
MTCK
MTCK's Avatar
Cool, got any pics of the swap? Bet you are loving that low first gear and OD.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-01-2011, 04:19 PM   #13
74chevy4x4
74chevy4x4's Avatar
Wink Re: 1974 full time 4x4 to 4x2 conversion
propanemudtruck, I hear ya and it'll probably be a couple of years before I break even on the gas costs, but I love the lower first gear and the fact that I'm not winding it out at 60 mph anymore. I drive about 300-400 miles per week, half on the highway, so the extra gear is nice. even a one mpg increase is a ten percent increase so I guess we'll see. I did weigh the cost quite heavily before I committed to it. I just came into a great deal on the rebuilt tranny and transfer(700 bucks) the labor is what cost me. Unfortunately, my severely sloped driveway was no place for me to do the swap alone, so I had to enlist the help of a mechanic friend and his shop.
MTCK, I didn't get any pics of the swap, but suffice it to say...What a PITA, LoL. we had to mod the crossmember, shorten the driveshaft and change the yoke, plus some other little things like the kick-down cable bracket and transmission line routing.
As I have about 5 grand invested in the truck so far, I'm not too bad off. I don't have any car payments so I can "play" a little, thank God. Momma isn't too worried...yet
Not that I'm posting anything "for sale" but I do have a fully functional NP203 with the 4X2 conversion for anyone needing one and is willing to cover the shipping. I just need to get that heavy beast outta here, LoL.
Old 01-01-2011, 10:55 PM   #14
MTCK
MTCK's Avatar
The best kind of rig is one that doesn't owe you anything! What kind of mileage are you getting now? Do you know what your axle ratio is? I have a 700r4 truck that came with a 2.73 rearend which made the OD about useless.
-Marcus
Project Plow Truck
Old 01-03-2011, 09:39 AM   #15
74chevy4x4
74chevy4x4's Avatar
I am running 4:10 axles so the lower 1st gear really helps getting off the line, so to speak, and as for the mileage, I'm going to run a couple of tank fulls and average it out. I'll update when I have the numbers. Maybe it'll help, maybe it won't but I really like the way the truck feels now; firmer shifts with the rebuilt 700R4, Overdrive at 45 MPH drops the RPMs about 700 at 60 MPH which is where half of my driving is.
