Old 10-17-2010, 04:56 PM   #1
Mattman2010
Mattman2010's Avatar
85 GMC Sierra Classic 1 Ton Crew Cab
I just got this 1985 GMC Sierra Classic 1 Ton Crew Cab.
Drive train - 454/th400
A/C, Power Locks, Power Windows, Cruise, tilt column, factory am/fm radio, hydro boost brakes
Pictures
Rusty Areas
Plans:
Drive train - Converting it to 4x4 (6.2 Diesel/Th400/np205) Swapping in a 6.2 diesel for better gas mileage.
For now I will just run the 454 while I work on doing some rust repairs. I will be stripping it down to the frame at some point.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 10-17-2010, 04:58 PM   #2
Mattman2010
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
So far I have the qjet pulled off of the engine to rebuild it. The carb is really dirty, and it is flooding and having trouble staying running.
Build Thread
Build Thread
Thread
Old 10-17-2010, 05:14 PM   #3
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Good looking project the rust could be worse.
what does the emblem say over GMC on the tail gate band?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 10-17-2010, 05:38 PM   #4
Mattman2010
Its the dealerships tag that they put on the trucks when they where new on the lot. Its the Roper GMC/Pontiac dealership which is in Joplin, MO. I think the dealership is still in business, but I found in the glove box the business card for the guy that sold the truck back in 85.
Build Thread
Build Thread
Thread
Old 10-17-2010, 05:39 PM   #5
GmtGmt
GmtGmt's Avatar
how thats cool
Thomas
Old 10-17-2010, 08:42 PM   #6
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Cool man! Do you have any smog or emissions testing up there?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-17-2010, 09:12 PM   #7
Mattman2010
No we do not. This 454 has all kinds of emissions **** hooked up. I would take it all off, but the plan to drop a 6.2 in this thing kinda makes it pointless for me to do all that work to it. I just want to get it running for now so I can enjoy it till the tear down.
Build Thread
Build Thread
Thread
Old 10-17-2010, 10:39 PM   #8
Matt Man
Matt Man's Avatar
wait it has a diesel gauge bezel on it? was it originally a 6.2 diesel?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 10-17-2010, 11:43 PM   #9
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Well that's good that yall don't emissions testing. I think that would be the first thing I would remove, but you could just remove the belt and bend the tubes over on the manifolds.
Oh nice! I didn't notice that but it doesn't have a 80lb oil pressure gauge so I think someone swapped in that bezel.
Tony
Old 10-18-2010, 12:03 AM   #10
Jonboy
Slots go on anything!
Sometimes the SES light is up there, where the Glow Plugs and Water in fuel light are on a diesel.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-18-2010, 08:18 AM   #11
Mattman2010
Sorry, but what about the bezel makes it look like a diesel bezel? I am pretty damn sure the build sheet in the glove box says it came factory with a 454 but I cant remember off the top of my head. This bezel has a "Check Engine" light, Not sure what that is for seeing as it is not computer controlled. Does that have something to do with the emissions stuff?
Does a TH400 have any vacuum lines or kick down cable? There were only a cruise and throttle cable hooked up to the carb, no kick down like a Th350. I am also not sure where the vacuum advanced for the distributor goes on this carb. It looks like it hasn't been hooked up for a long time.
Build Thread
Build Thread
Thread
Old 10-19-2010, 07:18 PM   #12
Mattman2010
Well the carb is really dirty, and so I think it will be best to drop the gas tanks to make sure that they are clean on the inside. I am also replacing all of the rubber lines and putting filters on everything to catch any dirt. I am also going to replace the line that goes from the fuel pump to the carb with hose so that I can put a inline filter so I can see if any dirt is getting up toward the carb.
Build Thread
Build Thread
Thread
Old 10-20-2010, 01:29 PM   #13
Matt Man
Matt Man's Avatar
All 6.2 diesels i have seen have had that bezel in it, because those lights are for water in fuel and the glow plugs, but somebody could of swapped that in their. nice truck.
Old 10-20-2010, 01:36 PM   #14
GmtGmt
GmtGmt's Avatar
yep never seen any emission trucks with that bezzel, only 6.2 diesel trucks
Thomas
Old 10-20-2010, 01:52 PM   #15
Mattman2010
What about the bezel makes it like a 6.2 bezel? The little screen part at the top?
Build Thread
Build Thread
Thread
Old 10-20-2010, 01:55 PM   #16
GmtGmt
GmtGmt's Avatar
Yes if you take a light you should be able to see what it say in the two screens
Thomas
Old 10-20-2010, 05:48 PM   #17
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Here you go, were you asking where the one above the filter goes to also?
Man that thing is dirty, I was almost ashamed to show it. The cummins will be prettier.
Tony
Old 10-20-2010, 06:36 PM   #18
Mattman2010
Thanks for the pictures, but that doesnt help me haha. There are so many damn vacuum lines its confusing, Im just going to start hooking them up haha. The diagram on the air cleaner is hard to follow compared to the actual engine. I want to take all the emissions stuff off, but there is so much that it would cost me more than I would want. This engine wont be in here to long.
Build Thread
Build Thread
Thread
Old 10-20-2010, 06:47 PM   #19
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Well maybe I misunderstood, what do you need pictures of?
Tony
Old 10-20-2010, 08:21 PM   #20
Mattman2010
No, you got it right, its just the fact that I have a million more vacuum lines on mine so it doesnt really help me. I think I got it all figured out.
I tried to drop my gas tanks, but I was fighting rusty bolts, so I am going to have to wait and get my truck down to my grandpas shop and work on it. But I have a bunch of stuff to clean up from my k10 first haha.
Build Thread
Build Thread
Thread
Old 10-20-2010, 08:38 PM   #21
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Lets see a picture of yours.
Tony
Old 10-20-2010, 08:54 PM   #22
Mattman2010
This is the only picture that I have. You cant tell much, but it has all of the emissions stuff, and some kind of emissions thing that runs off the belts.
Build Thread
Build Thread
Thread
Old 10-20-2010, 09:27 PM   #23
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I believe that's the rarely seen "smog pump" that ive only heard rumors of around these here parts.
Tony
Old 10-20-2010, 09:51 PM   #24
str8axle55
My 86 K30 w/350 also has that dash bezel, I`ve also seen others. What are your plans with the roof rust? Good looking rig though, be nice w/4WD.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 10-20-2010, 10:07 PM   #25
Mattman2010
Well I am planning on buying another crew cab without a title and a 6.2 diesel and I will cut out the top of the doors on it and weld them into this cab. I will be taking the diesel out of that truck and putting it in this truck.
Build Thread
Build Thread
Thread
