Old 10-17-2010, 07:41 PM   #1
yote1234
yote1234's Avatar
are 3.08 gears good with 200r4?
im just trying to get an education! im almost done with my restoration (72 cheyenne factory 350/350th 3.08 open) and was kinda thinking about changing out the th350 for a 2004r. i would like the lower rpm at 55-75mph. also looking for better mpg. just wanted to get your imput on if i will loose/gain performance,mpg ect.
1984 k10 short wide
1968 camaro 327
1965 chevelle malibu 283
1968 honda minitrail z50a #377
1966 uh1-d huey bell 204
yote1234 is offline   Reply With Quote
Old 10-17-2010, 07:43 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: are 3.08 gears good with 200r4?
for what I have heard, no, its to low. 3.54-3.73 is what would make it more efficient with the 2004R.
Smitty
71 C10 283/3SPD (I know its not original but I like the motor) 4 Whl Disks,Dakota Dash,Moved Fuel Tank,Frame Off
71 GMC 1500 Sierra Grande 350/700R4 3.42 rear, Repainted with my own hands and it looks Freaking Sweet.... http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 Suburban Former military GSA truck,,still solid as a rock! Its starting,,,350/700R4 3.42 rear, Dodge seats.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber...Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one.....Gen 5 5.3/8L90E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
71meangreenc10 is offline   Reply With Quote
Old 10-17-2010, 07:45 PM   #3
bigguy69
dazed and confused
bigguy69's Avatar
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-17-2010, 07:50 PM   #4
yote1234
yote1234's Avatar
i understood the th350 and the 2004r 1st,- 3rd gears are the same? is this wrong?
1984 k10 short wide
1968 camaro 327
Old 10-17-2010, 08:47 PM   #5
clinebarger
Gear ratios of the 2004R are: 2.74 first, 1.57 second, 1.00 third, .67 fourth.
TH350 ratios= 1.52 first, 2.52 second, 1.00 third.
I also recommend running a higher numerical gear than a 3:08 with any GM overdrive.
clinebarger is offline   Reply With Quote
Old 10-17-2010, 09:03 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I think you got 1st and 2nd ratios backwards on the t350.
I will be running a 200-4r and have 3.73 gears. My truck had 3.08's with the first motor and I got 3.73's. They were great with the 383 stroker I just took out...but turned 3k or so on the freeway. With the 33% OD....I'm thinking 3.73's will be about right....though 4.10's might be better fitted for what I'll be doing with it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'16 Kia Sorento - wife's econo-driver
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-17-2010, 09:20 PM   #7
llowlife
I'll let you know in a week or 2 if you are still interested. I have a 388 with a 4l80 and 3.08 I suspect I will be going for 3.42 or so this winter just so I can get some more snap but for now it was a posi in teh truck when I bought it.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 10-17-2010, 09:27 PM   #8
bubba327
HOW long until spring??
bubba327's Avatar
Do not forget that tire size makes a difference also.That going from a 235/60/15 (26.1") to a 235/70/15(28") is difference of over 200 RPM at 55 mph. Find a Free online RPM gear calculator and plug in your numbers to get RPM's
In my 64 with the 235/60/15 tires and TH350 with 3.73 gears , I am screaming at 65 mph and freeway 75mph is Impossible.
Just bought a 3.07 rear end to install.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-17-2010, 09:32 PM   #9
clinebarger
[QUOTE=68GMCCustom;4245909]I think you got 1st and 2nd ratios backwards on the t350.
Whoops
Old 10-17-2010, 10:12 PM   #10
yote1234
yote1234's Avatar
soo it looks like 1,2,3 gears the same with higher 4th. ...........
thanx... for the reply...
I will be running a 200-4r and have 3.73 gears. My truck had 3.08's with the first motor and I got 3.73's. They were great with the 383 stroker I just took out...but turned 3k or so on the freeway. With the 33% OD....I'm thinking 3.73's will be about right....though 4.10's might be better fitted for what I'll be doing with it.[/QUOTE
please keep me posted... thx
in thinking it will be the same in 1st,2nd,3rd with better overdrive.. keep me posted also.. thx
1984 k10 short wide
1968 camaro 327
Old 10-17-2010, 10:38 PM   #11
yote1234
yote1234's Avatar
i guess what im saying if i had changed my 350th to a 200r4. in 1st,2nd and 3rd gears the performance shouldnt change at all, but at hiway speeds in 4th it should save rpm's and fuel.
it's a very stock truck not a speed demon... dave
1984 k10 short wide
1968 camaro 327
Old 10-18-2010, 01:50 AM   #12
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
i dont really understand why my 85 iroc came with 2.73 rear gear, 700r4 and 245/50r16 if everyone says 3.08's are too numerically low?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 10-18-2010, 05:26 AM   #13
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Wow that is really high geared! Was OD usable? If so it probably was because a camaro is quite a bit lighter and more aerodynamic. Most people who have done the OD 3.08 combo with trucks like ours tend to lose MPG because they say the motor is chugging too hard to push the brick-like aerodynamics down the highway.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-18-2010, 07:27 AM   #14
CE20934
CE20934's Avatar
Two words: fuel economy. With that tall of a rear end coupled with that deep of an overdrive, the engine would be barely ticking over during flat cruising/fuel economy testing. Low RPM + light throttle = high mileage. When I bought my '89 Caprice, it had a 305/700-R4/2.73 & 235/60R15s.* 2000 RPM was 81 MPH, so 55 wasn't even 1500.
Come to think of it, there was even a 2.56 available for the B-bodies. My Gramma's '88 has that one.
*From the factory, it was a 305/200-4R/2.73 with 205/70R15s.
'67 C20--427 tall deck/SM420, 4.10 HO52 ($15,000 and counting beater)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (It's faster & handles better than any whale has a right to--and I love it! )
'01 Cavalier--The wife's car. At 170,000 miles, it goes from Point A to Point B more reliably & more efficiently than my truck ever did or ever will. However, it's not nearly as much fun to drive. Puttputtputtputt
CE20934 is offline   Reply With Quote
Old 10-18-2010, 08:00 AM   #15
rsavage
rsavage's Avatar
I have a 70 Burb with 3.07's that I put a 200 4R in. For non-highway type driving, I don't use OD, just 3rd with a dash switch to lock up the torque converter when it shifts into 3rd. On the highway, the OD works fine. It turns about 1750 rpms at 66 mph on 235/70/15 tires. 3.73's would be ideal, I think, but your 3.08's will work if used as a 3 speed auto when not on the super slabs.
65 GTO 389, tripower 4 spd PS PB AM/FM, Posi PHS - given to my son in NC 4/18
70 GTO convertible numbers matching 400, 4 speed
65 Fairlane hipo 4 speed. One of 750 hipos made in 65
69 Blazer 4 WD. Latest restoration project
2018 Durango 392 Hemi SRT 0-60 4.4 sec, 12.9 1/4 mile
rsavage is offline   Reply With Quote
Old 10-18-2010, 10:43 AM   #16
yote1234
yote1234's Avatar
the problem is most all my driving is under55mph. rarly get on the freeway.
so i guess i'll keep the 350t.h. and save the money! yea! save the money!
thank you all for your repllies! and opionions! great info... dave
1984 k10 short wide
1968 camaro 327
Old 10-18-2010, 10:44 AM   #17
turp mcspray
turp mcspray's Avatar
I think the 200 has a .67 overdrive. Multiply that, times any gear ratio, and you will see what it would be equall to with a th350. (Example...3.08 x .67 = 2.06. .67 x 3.73 = 2.50) 3.08s would be great if you have a TON of low end torque to pull it in overdrive, or want to cruise at 100 plus all day! But then wind resistance would wipe out any mileage increase anyway.LOL!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-18-2010, 12:10 PM   #18
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
you could always just leave the th350 in and put like 2.73's or 2.56's in the rear end. It would have the same effect.
My 68 impala has a 396 325hp, th400 and 2.56 rear gears. Gets 18mpg in town.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 10-18-2010, 12:52 PM   #19
yote1234
yote1234's Avatar
ahhhh... yea just stick with the 350th. thanx guyz.........
1984 k10 short wide
1968 camaro 327
Old 10-18-2010, 06:35 PM   #20
brothers69c-10
Suburban Hick
no problem man
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
