09-28-2015, 07:27 PM | #476 |
But Found Her 25yrs Later!
Re: Lost My 65
In mocking up for the ps pump, I saw the old GMC V6 Motor mount perch needed to go.
. . Also, here is a pic of the micky-rig fix bracket for the clutch linkage my uncle welded to the frame back in 1984. :-) Nostalgia .
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-28-2015, 08:00 PM | #477 |
Re: Lost My 65
been reading your story, really cool you got it back,i sold mine 20 years ago a 66 stepside, with fleet tail lights and diamond plate in bed,thought it was mine for a second. was curious what paint your using
09-28-2015, 10:21 PM | #478 |
Re: Lost My 65
The paint on it when I bought it back was in pretty bad shape. I also have patch panels I need to do.
So, for now I'm doing redneck body repairs and painting over the existing paint using inexpensive oil-based enamel. Eventually I'll go back panel by panel doing it right with SPI Black Epoxy Primer. I'm still undecided what direction I'll go after that. I do know I don't want something pretty and expensive where I have to worry about every ding and/or scratch.
09-30-2015, 09:53 PM | #479 |
Re: Lost My 65
yea im still undecided whether to just do rustoleum or get epoxy primer, my truck wont be a show truck just a driver
10-06-2015, 07:53 PM | #480 | |
Re: Lost My 65
I should have something for you no later than this weekend.
10-09-2015, 09:44 PM | #481 |
Re: Lost My 65
Digging in.
Getting that ol sm420 out so I can get the th350 in. So excited to finally be doing this swap.
10-10-2015, 12:59 AM | #482 |
Re: Lost My 65
The th350 I have came from summit.
Here is a way I've been considering to mount the tail. http://67-72chevytrucks.com/vboard/s...31#post4216931
10-10-2015, 11:58 PM | #483 |
Re: Lost My 65
10-11-2015, 01:43 PM | #484 | |
Re: Lost My 65
I was 19 when I did the fleetside lights. I just hacked them in there. I do have some fleetside light buckets that I eventually will weld in there. .
10-11-2015, 03:54 PM | #485 |
1961 crewcab
Re: Lost My 65
thanks, that is perfect!
they look like you got them in the right spot. this will help when I do mine, same as you are planning I am also going to use the fleetside taillight buckets.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-11-2015, 04:33 PM | #486 |
Re: Lost My 65
10-11-2015, 05:29 PM | #487 |
Re: Lost My 65
I like that look
10-12-2015, 08:10 PM | #488 |
Re: Lost My 65
Getting ready for the auto swap.
Pressure washed the frame. . . . . Used my leaf blower to dry it off, then pulled it back into the barn. . .
10-12-2015, 09:38 PM | #489 |
The 60-66 GMC/Pontiac guy....
Re: Lost My 65
cool update
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
10-12-2015, 10:29 PM | #490 | |
Re: Lost My 65
It would be kinda neat if it is the 283 I rebuilt myself with a jcwhitney kit back in 85/86. That means my rebuild lasted until that ol guy that I bought it back from blew it up.
. . My earlier post on this: Quote:
10-12-2015, 10:44 PM | #491 |
Re: Lost My 65
What is the casting date on the block?
10-12-2015, 10:45 PM | #492 |
Re: Lost My 65
Where would I find that?
10-12-2015, 10:47 PM | #493 |
Re: Lost My 65
The other side of the block opposite the casting number. . A letter and 3 numbers
10-12-2015, 10:49 PM | #494 |
Re: Lost My 65
Ok,
I'll check tomorrow.
10-12-2015, 10:51 PM | #495 |
Re: Lost My 65
Letter is month.. then a 2 digit day.. then the year digit..
Example E216 would be May 21 66.. since the block is a 60s we know 6 is 66.. :-D
10-12-2015, 11:01 PM | #496 |
Re: Lost My 65
10-13-2015, 01:06 AM | #497 |
Re: Lost My 65
I confuse Pontiac info with chevy sometimes.
This is from a chevy site. Casting Date* Small block casting date is located on driver side rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails. Casting Date Example: E038*- (E = Month, 03 = Day, 8 = Last digit of model year (1978)). Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
10-16-2015, 06:44 PM | #498 |
Re: Lost My 65
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-16-2015 at 09:02 PM. |
10-16-2015, 09:01 PM | #499 |
Re: Lost My 65
10-21-2015, 09:56 PM | #500 |
Re: Lost My 65
I've been spending a lot of time in the 'Engine & Drivetrain" section of the forums. I don't know much about automatic transmissions. I bought a summit th350 from a local guy. Included was the flexplate and torque converter. As I started mocking things up, I noticed the flexplate he included wasn't going to work. Fortunately I still had the larger flexplate left over from the 79 donor I had from my 66 service truck build.
. From my research in these forums I learned depending on which flexplate you needed, determined what starter you needed. Fortunately I had the correct starter also. . Next I started reading up on torque converters. I first checked to see if the torque converter he including would bolt up to my larger (14") flexplate. It did. . . . So now my only concern/question is what stall torque converter do I have. I'm going to take my chances and see how it goes. . I've also been reading... related to the stall of the torque converter is my engine/cam. My engine has quite a lope to it, and it requires premium octane.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-21-2015 at 10:04 PM. |
