Old 10-26-2010, 01:45 PM   #26
Oilbrnr
Oilbrnr's Avatar
Re: Silver Dollar
Originally Posted by mrhino View Post
Brendan from Lt1swap. $75 and I had it back in a couple of days. I had a few issuse at start up (Injectors stuck from sitting)and I contact him and he help me out.
What did you do to un-stick them?
When you worked on the harness, did you remove most of the loom for easier access?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 10-26-2010, 04:17 PM   #27
mrhino
Re: Silver Dollar
It might be easier to go to this thread to see what i did with the injectors, has some good suggestions plus what I did and pictures.
http://67-72chevytrucks.com/vboard/s...00#post4258000
Yep, I pull off all of the loom, but waited till got to each branch before cutting it open
First I took all the wires out of the blue and red PCM connect that I was not going to use. Then one at a time pulled untill I had them back through the harness till It came to where the harness would branch off. then work on that branch untill the the unwanted wires pulled out with their pigtail. Taped that branch back up to keep it together. (check out all the orange tape on the harness) Then move on down to the next branch and so on. hope that made since.
I wish I had better pics of the harness before and after it was done, but I dont.
mrhino is offline   Reply With Quote
Old 10-28-2010, 10:22 AM   #28
mrhino
Re: Silver Dollar
Fuel tank install. tried to use a blazer tank, but found it hang down to low. I would have been draging it across speed bumps. I couldn't afford a Custom made one for $500 or more. so after searching a came a across a jeep tank. made it fit. its only a 15 gallon tank., but with the 5.3 getting 20 some miles to the gallon it shouldnt be a problem. And it doesnt hang low in fact with the bumper on you can barly see it.
Ran pressure hose from the tank all the way to the engine, using push lock AN fittings at the rail and back to the tank for the return line.
Put the cab on to start the mock up process. had to add the fuel level sending unit for my classic instrument gauges.
the tank hangs 10" from the ground.
Old 10-28-2010, 10:33 AM   #29
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
Nice job. looking like a truck again
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-28-2010, 01:01 PM   #30
Puropedo
Re: Silver Dollar
Great job! Where did that "jeep tank" came out of?... A cherokee? Did you use the stock jeep tank fuel pump?
Puropedo is offline   Reply With Quote
Old 10-28-2010, 02:26 PM   #31
mcbassin
Still Learning
mcbassin's Avatar
Re: Silver Dollar
Ditto?^
How is it mounted in there?
mcbassin is offline   Reply With Quote
Old 10-28-2010, 02:36 PM   #32
HOGDADDY
HOGDADDY's Avatar
Re: Silver Dollar
Subscribed this looks interesting and your doing helluva nice job.
HOGDADDY is offline   Reply With Quote
Old 10-28-2010, 05:16 PM   #33
franky69c10
chevy runs deep
franky69c10's Avatar
Re: Silver Dollar
Nice look'n good anymore info on the tank what year and type of jeep did u get it from
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 10-28-2010, 07:19 PM   #34
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Silver Dollar
nice man! I cant wait to see it!
John
1999 Toyota Tacoma 4x4
Old 10-30-2010, 10:19 AM   #35
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
That Jeep tank was a great idea. I wish I'd thought of it. It could have saved me some $$$.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-30-2010, 10:58 AM   #36
nastyc10
nastyc10's Avatar
Re: Silver Dollar
Your doing a great job! Keep at it.
nastyc10 is offline   Reply With Quote
Old 10-30-2010, 01:01 PM   #37
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
What size tires are you using? I am trying to decide between 18" and 20" wheels right now.
67 5.3L Build
Old 10-30-2010, 03:05 PM   #38
duramax_4
duramax_4's Avatar
Re: Silver Dollar
looking good! I like the new motor in old truck. should run good. good to see another person from indiana doin a project
1972 Chevy 3/4 Ton 4x4
2001 Chevy Duramax 3/4 Ton 4x4
1972 Chevy Nova 468 BBC
1944 International K-11
1965 Chevy C-10
duramax_4 is offline   Reply With Quote
Old 10-30-2010, 03:55 PM   #39
mrhino
Re: Silver Dollar
After doing tons of searching, I came up with 87-90 jeep wrangler tank. it is a fuel injection tank so it did have a baffle inside. it measures 25x 18.5 x 11. it fit in the rear area there with no cutting or modifying of the frame. I did however have to use a piece of angle iron across the back to have something for it to rest on.
There is a flange all the way around the tank about a inch wide, so I drilled 1/4 holes in each corner and just bolted it in place.
There were a few problems with putting this tank in. when I put the tank in I did it with the bed off and because it went in from the top when I put the bed on, the it hit one of the bed braces underneath. so I had to trim that back a little. Iv since concluded if I had mounted it from the bottom it most likly would have cleared. The fuel fill is only 1". and it is was right where the cross brace was as well. The only place I could find a 1" fuel fill hose, was McMaster Carr. (one could always just have a new fill welded on.) Anyway it worked out for me, but could be a problem for other installs.
The sending unit is a stock GM I think I used one from a 85 c/10. I of coarse had to modify it to fit my fuel pump and sock on it.
By the way thanks for all the encouraging compliments, I appreciate them!
Old 10-30-2010, 04:02 PM   #40
mrhino
Re: Silver Dollar
18's all the way around, fronts are 245/45 18 and rears are 255/45/18. take a look at my profile, there is a photo of my last truck(the blue one) I had 20's all they way around on that, and I didn't care for it. I thought it rode like crap.
Old 10-30-2010, 04:24 PM   #41
Puropedo
Re: Silver Dollar
What kind of fuel pump are you using?
Old 10-30-2010, 09:58 PM   #42
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
That's what I'm thinkin'. I would rather have a more comfortable ride and not have to worry about denting rims than have the bling of the 20's. I was actually looking at 255/45-18's all the way around as an option.
67 5.3L Build
Old 10-31-2010, 09:23 AM   #43
mrhino
Re: Silver Dollar
I Had looked at so many at the time I dont remember for sure what kind of vehical it was for. Going back through my notes, I think I used one from a 94 Impala SS with a Lt1.
Old 11-01-2010, 12:48 PM   #44
djw32
Re: Silver Dollar
Inside the tank or external fuel pump?
This truck looks great.
djw32 is offline   Reply With Quote
Old 11-01-2010, 01:50 PM   #45
coop34
Re: Silver Dollar
I used one of these tanks as well. Fits like a glove! The only problem that I had was that the PSI on the in-tank fuel pump didn't work with my TBI 5.7L engine. I ended up welding the correct fuel pump to the jeep fuel pump housing.
coop34 is offline   Reply With Quote
Old 11-01-2010, 02:03 PM   #46
mrhino
Re: Silver Dollar
so you used a jeep sending unit?
Old 11-01-2010, 02:04 PM   #47
mrhino
Re: Silver Dollar
Internal and thank you.
Old 11-02-2010, 10:33 AM   #48
mrhino
Re: Silver Dollar
After scraping the junk cab and bed that came with my chassis, I found a guy selling a so called "Rust Free" body on craigslist. let me tell you Nothing is rust free in Northern Indiana. (just south of Ft. Wayne for you Indiana guys). So with my doubts, I drive down to look at it, and low and be hold, this man has a Complete rust free body. (Ah side from a little surface rust) everything from the core support to the tailgate plus it had been dipped and primed. It has a few small dents and dings but nothing major. He told me He brought it home from Arizona and was planning on restoring his old truck, but couldn't find the time. The body had been sitting in his pole bar for 9 years. The only problem I had, was it was a long bed. I thought aw hell I just cut it. I saw them do it on Trucks. cant be that hard. right?
Once the chassis was done. I put the cab on and started mocking everything up. engine wiring, steering column, Master cylinder.
Core support, Radiator, Hoses, etc.
heater box, where to mount the computer?
Installing the gauge cluster, and then finally mating all the electrical, together.
Old 11-02-2010, 12:40 PM   #49
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
Nice! Great score on the sheetmetal and I love those gauges.
Old 11-02-2010, 02:10 PM   #50
coop34
Re: Silver Dollar
mrrhino - actually, I think I ended up using the sending unit from a 90 chevy and cut it down because it was too tall. Did your sending unit/fuel pump assembly fit ok? Where did you decide to mount the computer? I mounted mine just above the heater box.
5.3, boss 338, house of kolor, lsx, tank
