Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-25-2010, 07:48 AM   #1
danomano
Codes P0420 and p0430
After trans rebuild I have been getting randomly. I have replaced both upstream O2 sensors and every other week I get the code on onside or the other.
Last thing I have done is clean the MAF sensor and air temp sensor. So far no issues. But if it comes back any ideas?
Oh if this does come back I have heard it can fail you on emission testing I am good for another 9 months.
danomano is offline   Reply With Quote
Old 10-25-2010, 11:08 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Codes P0420 and p0430
Does your truck emit black smoke on startup?
Member Nr. 2770
'69 C-10 SWB; 350/TH400 - under reconstruction.
Old 10-25-2010, 12:00 PM   #3
danomano
No black smoke
Old 10-25-2010, 04:03 PM   #4
clinebarger
clinebarger's Avatar
DTC P0420
Catalyst System Low Efficiency Bank 1
DTC P0430
Catalyst System Low Efficiency Bank 2
Check the post catalyst 02 sensors for wiring damage.
Check for exhaust leaks.
Things that can degrade the catalyst itself..
An engine misfire
High engine oil or high coolant consumption
Retarded spark timing
A weak or poor spark
A lean fuel mixture
A rich fuel mixture
Its hard to believe that both catalyst went bad at the same time, so check it over real good.
1985 Chevy C20 Suburban with a 2004 5.3/4L60E
2006 Chevy 2500HD Crew Cab 6.6 LBZ/Allison 1000
clinebarger is offline   Reply With Quote
Old 10-25-2010, 04:20 PM   #5
danomano
More info.
All spark plugs were replaced two months ago along with cap and rotor. All the old plugs were in good shape.
No other code have been happening. Just one week p0420. I hook up scanner and watch back o2 they appear good so I clear it. Then next week I get p0430. same thing again
I am thinking of running GM Fuel System Treatment PLUS P/N 88861011
or seafoam.
Old 10-29-2010, 09:49 PM   #6
Jimmyg 65
Try ET100 from NAPA it is a fuel tank additive and injector cleaner that will help with carbion build up and a clean engine will help converter efficiency. I was getting a p0420 code also in my truck tried this and cleared codes and no light or code in 1500 miles.
Jimmyg 65 is offline   Reply With Quote
Old 10-29-2010, 11:51 PM   #7
bwood
bwood's Avatar
If this started just after a trans removal/installation, check around the trans bell housing to see if they pinched some wires or unhooked somthing and didn't get it back together. I'm thinking that the harness for both banks originates on the pass side of the engine and then bank 2 runs down the pass side of the bell housing where it hits small protective enclosures where the O2 sensors plugs are and, I'm thinking they are attached the the stud/bolts that hold then trans to the engine. Same for bank I except on the driver's side.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 11-09-2010, 09:14 PM   #8
danomano
Think I got it fixed after replace down stream O2 sensor and still get code and having the cats checked I did this to fix it.
I installed two 18mm no foul spark plug holders. One set I drilled out to accept the O2 sensor then screwed that into the stock one. After that I installed back into the exhaust and have not had an issue with it for two weeks. When before it would happen again after a day. Part number 42009 at autozone in the HELP section.
Old 11-11-2010, 11:58 PM   #9
bwood
bwood's Avatar
If this is what fixed it, you just masked the problem. Chances are one of the issues in Clinebarger's post are killing the cats.:
"Check for exhaust leaks.
An engine misfire
A lean fuel mixture
A rich fuel mixture "
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
