Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-27-2010, 12:25 AM   #1
bowtie5
'89 350 tbi 5 speed stalling and surging idle
Hello everyone and thanks in advance for your help.
I have been experiencing a surging idle with stalling at stops or as I slow down. I have a 5 speed so I dump the clutch and the idle drops very low and rough.
Had this problem when I bought the truck. I did plugs, wires, cap and rotor. Had bad fuel pump and I replaced filter with it. Took it to a shop to diagnose the idle and it had a map sensor code. Shop replaced map sensor and egr, as well as a new water temp sensor and 205 degree thermostat. Didn't stall for quite a while, but the idle was still a little low at stops.
There are currently no engine codes showing. Fuel consumption seems to be quite terrible lately too.
Hope I have given enough info. Thanks again.
bowtie5 is offline   Reply With Quote
Old 10-27-2010, 01:00 AM   #2
54 jimmy
54 jimmy's Avatar
Re: '89 350 tbi 5 speed stalling and surging idle
check you throttle body gasket for a leak. an easy eay is to spray 2+2 carb cleaner at the base of the throttle bodyif it stalls out that means the gasket is bad. ot the pcv valve opening in the throttle body could be plugged that would cause back pressure in the motor an couse it to run crappy. these are the things i ran into on my s10. they are basically the same. hope this helps.could also be a vacume leak.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver)
1996 chevy k1500 reg cab 4x4(daily driver/wife's winter beater)
2002 gmc envoy xl (wife's daily driver)
54 jimmy is offline   Reply With Quote
Old 10-28-2010, 09:42 PM   #3
ChevyTech
A common cause of an idle that hunts up and down on these trucks is a lean fuel mixture, usually from low fuel pressure. The fuel pressure must be tested with the engine running. An IAC sticking and a worn distributor can also cause idle issues.
There are multiple failures that can causes the TBI trucks to have low fuel pressure other then the fuel pump.
The IAC (Idle Air Control) controls the air passing through a throttle pate bypass passage.
The IAC (and computer) control the idle speed.
The IAC (and computer) is what gives the engine a “fast idle” speed when started cold.
The IAC also supplies more air to compensate for the extra load when the A/C is on. If you have A/C and turn it on while listening carefully you should be able to here the IAC controlling the idle as the A/C clutch engages and disengages.
When the engine does start, does the engine have a fast idle that slows down as it runs? The IAC (idle air control) is what gives the fast idle speed when started cold.
Does the engine start well without the gas pedal being pushed down at all?
Old 10-30-2010, 09:26 AM   #4
bowtie5
Thanks 54jimmy for the advice. I sprayed carb cleaner aroung all vacuum lines and tb base with no change. PCV is new and working properly.
I do not have A/C to test that part.
When I start in the morning it doesn't seem to run any higher than when it is warm. Other than cranking a few seconds longer than I like, it starts fine. I never press the pedal when I start the truck. I assumed that it didn't do what a carb does. Other than the constant surging it runs fine. It doesn't surge from normal rpm to a higher rpm, it goes from a normal rpm to a low (rough) rpm.
Paying as much attention to the problem as I can lately I have noticed that the roughest idle and stalling happens after a hot restart. For example going to a store. I will come back out after 10 or 15 minutes and start the truck. It will idle very rough and stall each time I slow for stops signs or lights for a good 2 miles or so. After a few miles it goes back to just the surging.
Is there a way for me to test the IAC or distributor? Like I wrote before the shop hooked up the computer and showed everything running normally.
Thanks again for the advice.
Old 10-30-2010, 01:02 PM   #5
54 jimmy
54 jimmy's Avatar
check your ign module under the distributor cap. mine would run fine untill it got hot the it would just stall/die and wouldn't start again untill the mod was cooled down. mine had a hole burned right through it. your local auto parts store can test it to tell you if it is bab. last time i replaced one they were like 25 bucks.
Old 10-31-2010, 02:50 PM   #6
ChevyTech
Check the coolant temp sensor on the intake manifold. The computer uses the coolant temp to determine how much fuel to inject and how fast the idle speed should be.
There is test information posted at the thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=379142
Old 10-31-2010, 02:55 PM   #7
ChevyTech
I still think it is possible that the IAC is not working well.
When started, the RPM should raise, and start to slow down as the engine runs.
After the engine is shut off, and before it is started, the IAC should open somewhat. When the engine is cranked, and if the IAC does not open at all the engine will usually “load up” or “flood.
IAC passages can get plugged up with carbon or muck. The IAC units get erratic as they get old and stick. Use care when cleaning the IAC. The IAC should not be cleaned with carburetor cleaner or other harsh chemicals. If the chemicals get down inside the IAC, it will damage it.
To clean the IAC, you should remove it, and use a wet rag to wipe the tip of the plunger, while holding it with the plunger pointing DOWN. Be careful, the IAC will break easily. It is aluminum. Clean the passages in the TBI unit while you have the IAC removed.
You can remove the IAC to clean out the passages in the TBI, but use care, the IAC can turn very hard and you could damage the IAC removing it.
I do not suggest unscrewing the pintle (plunger). If you don’t get in back in far enough, the IAC can get damaged if the “pintle” (plunger) bottoms out in the TBI, when you screw the IAC back in.
Usually the IAC does not go bad electrically, but it is common for them to stick and stop moving.
The IAC is a stepper motor and uses short pulses of electricity on the wires to move its position.
If the IAC sticks as does not move as it should for each pulse, the IAC count will get off because the computer does not know the actual position of the IAC, but the ECM tracks the commands it has sent to the IAC and assumes it has moved every time it has been sent a pulse.
IAC testing:
Terminals A to B should be 40 to 80 ohms
Terminals C to D should be 40 to 80 ohms
Terminals A to D should be infinite
Terminals B to C should be infinite
I suggest only using a digital (high impedance) ohm meter for doing these tests.
Old 11-01-2010, 06:31 PM   #8
bowtie5
Thanks for all the help guys.
I ended up pricing an IAC and felt it warranted just going ahead and replacing it. Unfortunately it runs exactly the same.
The coolant sensor was replaced within the last 6 to 9 months I believe, but it sure sounds like the problem. When I start it in the morning it does idle, but doesn't seem like it is on any high step or anything.
Stalling still there at restart. I will check out the coolant sensor test and give that a go. I also found a NAPA that will give the module a test. I know it isn't a definative test, but it's worth a shot. I am sure once I pull it I will at least get a good look at any burns it may have.
Thanks again for all the expertise!! I will get back with the results.
Old 11-01-2010, 08:22 PM   #9
463
463's Avatar
i think there is a relearn for the iac when ever it's been unpluged. not sure on what it is for the truck relearn.
Trueman
463 is offline   Reply With Quote
Old 11-01-2010, 08:48 PM   #10
463
463's Avatar
i 2x posted
Trueman
Old 11-02-2010, 09:20 AM   #11
k5hart
k5hart's Avatar
Could it be the dreaded EGR problem?? I know mine idled like that when it had a bad and then incorrect EGR valve on it.
I would go with Chevytech's recommendations at a minimum. He is VERY good and methodical at diagnosing things via the board (which is hard).
Keep plugging away at it and walk off when you get mad. Eventually you will find the problem. I know this from experience.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-02-2010, 01:03 PM   #12
AverageJoe
I had these problems and solved them by buying a new intake and a CARB
AverageJoe is offline   Reply With Quote
Old 11-02-2010, 07:52 PM   #13
ChevyTech
Thank you for the kind words K5hart.
Something is wrong.
You replace the IAC.
The IAC should always speed the engine up at least some, when starting the engine, even if it is warm.
The passages could be plugged. The ECM could be bad. The wiring between the ECM and IAC could be bad.
Just because you replaced the pump does not mean the pressure is good. There are multiple failures that can causes the TBI trucks to have low fuel pressure other then the fuel pump. It could have a fuel pressure regulator problem.
Just because the pump is new does not mean it is good.
I suggest only using OEM (Original equipment manufacturer) fuel pumps. I have seen so many pumps from other manufactures fail in the warranty period or just after the warranty is up that I suggest only using an OEM pump.
Took it to a shop to diagnose the idle and it had a map sensor code. Shop replaced map sensor and egr, as well…
The exhaust could be restricted. Does it sound unusually quite? This would explain the poor fuel mileage too.
If the IAC seemed to be working ok, I would say you should test the fuel pressure with the engine running.
Old 11-02-2010, 08:34 PM   #14
bowtie5
Thanks k5hart. I have put a new egr on. I push up on the diaphram while it is running and it stalls. That is the quick test if it is operating I have heard. I may be overstating the symptoms a bit. This is by no means a reason to park it. It is still my daily driver and I love the truck. Just want it as right as I can get it. You are right, chevytech is the walking, breathing chevy encyclopedia.
Believe me averagejoe, I have thought about grabbing the edelbrock carb and intake combo in the garage, but all of the horror stories I have heard stopped me quickly. Thanks
Hi Chevytech. I am very appreciative of all of your expert advise. I don't want to make any mistakes in my descriptions that will mess up your train of thought. So let me go back a bit.
As far as the cold idle speed... I don't have a tach and the previous owner thought flowmasters that exit in front of the rear wheels was a neat idea... so There may be at least some difference in idle speed at startup. I have a tach that i am going to zip tie to the cowl to verify this for you.
When I replaced the IAC I didn't take the time to check and clean all of the passages. I will do that tomorrow when I hook up the tach.
No exhaust restrictions that I can feel. If you rev it up a little it will blow your hand off the tailpipe (sidepipe).
I guess I need an inline fuel pressure gauge for that test? My buddy at the shop could handle that for me I suppose. What fuel pressure should I be looking for?
Once again I don't want to over exaggerate the symptoms. It does surge and occasionally stall on restarts. Fuel consumption is about 10 to 12 mpg. But it is a running ,driving truck. Just enough wrong that I think it needs addressing. I did forget about one thing I observed.... It sometimes deisels when I shut it off after a long drive. By long I mean not a short 5 minute drive. Anything over 20 minutes or so, Not terribly, but for a second or two it does run on. I checked the timing was at zero with the connector unplugged, after the map, egr, etc was done at the shop. I will recheck that tomorrow with my other tests.
Thanks very much everyone
Old 11-02-2010, 09:05 PM   #15
ChevyTech
The TBI fuel pressure specification for small block Chevy’s is 9 – 13 PSI with the truck running.
TBI engines should not “diesel” (run-on) when shut off because there should be no fuel. Make sure the injectors do not drip fuel when it is shut off.
When you replace, remove and cleaned an IAC, or unplugged the IAC with the key on, the ECM may need to relearn the IAC position. This will not happen without driving the truck and meeting specific conditions or taking other steps the cause it to relearn the idle.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
